Topic: ver.3.0 beta 2,3,4,5,6,7 for X-Plane 11
So.. a320 for X-Plane 11 is on beta-test stage.
http://jardesign.org/forum/img/m/22/t/p1b93fb4hq1hjm1cdh1sf31b7gg9b3.jpg
http://jardesign.org/forum/img/m/22/t/p1b93fbjucssjgd7c3o45918bv7.jpg
http://jardesign.org/forum/img/m/22/t/p1b93fc1t4hj1kld1h2sl6s19qtb.jpg
http://jardesign.org/forum/img/m/22/t/p1b93h75041uar1tqr1en9vgp1kic3.jpg
External 3D updated by Felis
Internal 3D and Ground stuff updated by Dron
Systems updated by JAR
What was broken, fixed and improved for XP11 version:
beta 1:
beta 2:
+ objects and textures was reworked according with new material system of XP11. Reworked.
+ redesigned/retextured MCP especially around displays (so you can see all panels layers here)
+ new textures on spots around
+ reduced amount of loaded textures (some are gone)
+ no more any gaps between panels (no flicker on any gaps in cockpit)
+ new reflections
+ now all cockpit screens/lcd panels have new glass with reflections
+ new things in cabin and new cockpit/cabin glasses (inside and outside)
+ some changes in Sky lights in cabine by yours requests
+ reflective ground stuff
+ NavData was removed from XP11 by Laminar Research and this was fixed for a320 (add _navdata with old Aerosoft cycle direct to a320 folder). Fixed.
+ User can select navData source at MCDU Status page. Improved.
+ add Diagnostic plugin, what can help if some installation was wrong (red message at screen if problem happen)
- Perfomance and fuel calculation was broken in XP11 and we will rework it at last stage, after XP11 release.
+ Navigation system was broken and FMGS was reworked to be compatible with new XP FMS.
+ Cockpit buttons night lighting was broken. Fixed.
+ rework ND flightplan path drawing.
+ vertical profile calculation reworked
+ NEW CRZ FL option was reworked
+ Go Around fixed
+ ILS approach fixed
+ Impossible engines shutdown fixed
+ cockpit light fixed
+ SPEED mode unstable fixed
+ LVR CLB flash fixed
+ display brightness improved
+ flight log improved
+ horizontal FD during SRS/RWY fixed
+ "CF" legs drawing improved
+ Rollout mode (Autoland) unstable fixed
beta 3:
+ reflection maps for external 3d improved (thanks Rashid)
+ ECAM buttons light bug fixed
+ brake and clock night lighting (front panel) fixed
+ baro selector work fixed
+ fcu knobs work improved (mousewheel selection work both for classic/comfort manipulators style) - please use MCDU Menu page 2 to switch style
+ not-transparent in-cockpit sunglasses fixed
+ some minor bugs fixed
beta 4:
+ engines start issue fixed
beta 5
+ Ok.. as you may be know, Laminars finish engine tuning inside XP11 and offer retune their engines for all XP developers to get adequate N1, Thrust, performanse and fuel burn.
beta 6
+ BARO knob fixed
beta 7
+ ILS DOTs indication fixed
Download link: out of date
  - be sure, that you use X-Plane 11.00
a320 use NavData from
- All users who bought the A320 AFTER the X-Plane 11 presentation event (October 2016 and later) may use their serials with X-Plane 11. If problems - please http://www.support.jardesign.org
- All users who bought the A320 BEFORE the X-Plane 11 presentation event (October 2016 and later) may update their serials (get new one) to make it worked with both - XP10 and XP11.
This JARDesign service should help for any users, what have a320 from any shop http://jardesign.org/a320-serial-update-step-13/
Update fee is about $19,95 (not include VAT for your country). Sure, you own a320 for X-Plane 10 and may continue to use it with X-Plane 10 simulator with no problem. No update need in this case. Support is continue.
As you know may be, you may use some my tricks from facebook to take a320 for XP10 and make it loadable with XP11. Please note what some old XP10 features not supported by XP11 more and you will get aircraft with not 100% compatible 3D, perfomance and (after saving with new PlaneMaker) FMGS navigation part.
Please note what this time we have beta of X-Plane 11 and beta of a320 ("beta" - product for testing and may not work well, hare errors and so on). If you need release, need stable version, please wait.
Thank you!!!!
Ha, Eugeny, it´s a good pic: Catering on the runway...
Dieter
Thank you Eugeny... presently at work but will surely purchase and install this evening. Looking forward ....
Awesome, bought the upgrade!
One thing I would like to request is: Can you add the correct Aircraft information like Manufacturer and Class? That way it would show up nicely in X-Plane 11's new picker, instead of being at the bottom showing up as "Other"
Will any of the updates made for XP11 be put into an update for XP10?
My first flight with my favorite aircraft was great!
But only the idle power was too low. I think over 40% N1 for taxi is to much. (7 tons fuel).
Dieter
7 (edited by DtRs90 2017-02-16 16:18:35)
I have problem with texture green...why?
http://i63.tinypic.com/2w2h1zl.png
Maybe not the last driver?
Disable "Show clickable regions in the cockpit" setting under General Settings.
Does this mean that development for XP-10 is now dead?
11 (edited by DtRs90 2017-02-16 17:23:49)
it Work fine. Thanks
Question:  Will the BSS sound pack V3 work with this updated BETA version?
I haven't had the chance to try yet.
I think the org store has a version 3.1 of the sound pack currently available for download/purchase
Startup XP11 goto Settings then to General tab and UN-check the clickable regions in the cockpit.
AMD 1090T 3.2 GHZ
16 GB DDR3-RAM
AMD Radeon R9 390 8GB GDDR5
Windows 10 Pro 64 Bit - X-Plane 10 and 11
can someone please help me I cant activate the A320 I get an activation error I sent in a ticket but didn't get a confirmation if it was sent where do I go to freely change my code from xp10-11
I am having the problem where the PFD and ND go blank when using SHIFT + L or K to change time of day from daytime to night time.
Yes it does, i have just installed it but it is v3.1 i have!!!
17 (edited by ilankrt 2017-02-16 20:52:56)
Test flight KBOS-KJFK, XP11, A320 v3b20XP11, XL,FM SkyMaxxPro v.4-2.1 and RealWeatherConnctor 1.1
1. BSS sound pack 3.1 caused crash
2. During taxi: throttle forward a bit too high caused warning "Terrain, Terrain pull up"
3. QNH STD on PFD continue blinking all the time
4. I will be nice to see pilots in cockpit during flight
5. Smoke from AI aircraft engines are looking bed and disturbing as a sort of dark claud in the sky Would recommend to eliminate it. (see images)
All in al seems to be a stable version in all flight situation.
6. Very disturbing the fault design of the pilot headrest !(trying to look out from the right windows at the adjusted sit position (see images)
I have some problems with the Navigraph update. The info in the \GNS430\Navdata seems correct (CRJ200 by JRollon shows the update version) but the A320 shows the A1410 cycle. Anyone is having the same issue?
Great update and fixes most problems you had to trick around for X Plane 11! Still there is annoying problem with QNH. Sometimes it jumps 2 forward and back thus you can't always select correct QNH.
Looks like if you want to fly with HDR OFF, you are stuck with a chrome looking interior....
Panel lighting seems to require HDR as well, except for that right panel light....
All lighting except the dome and the right panel light require an APU or Ground Power....
i paid for my update key and have a reciept number and didn't get anything in my email
Probably a time zone issue.... I'm in same situation.  But it's 3.47 am in JAR world. Be patient.
this is 2nd beta update or the first?
24 (edited by Kari 2017-02-17 15:23:38)
Awesome! Thanks for update, got my serial quick too.
BSS 3.1 did not crash on me yet, works fine so far.
Some things:
ECAM Buttons are black, cant see them at all unless they are selected.
Red overspeed tape does not work at high altitudes
Overspeed warning does not go away even if you slow down
25 (edited by MikeyOT 2017-02-17 16:23:48)
Had a couple of problems today.  Firstly my flight plan would not load as a co-route and gave an error which then locked the FMC so that no other input worked, producing hundreds of identical SASL error lines in the logfile.txt!
Next flight accepted the same flight plan and I was flying happily but at some point while I took a phone call from my daughter I took my eye off the screen so do not know what happened but I then realised that the 320 was flying in a straight line and not following the FMC flight path, even though FD A/Thr and AP were all on.
Lastly there was a problem with the next flight (on the stand) with the Parking Brake.  When I pressed 'B' I simply got "Parking Brake Off...Parking brake On" so I could not move the A/C.
In summary I do not know if any of the above was my fault or not.  I submitted a ticket for the first one and will wait and see what anyone says!
