301
Test flight KBOS-KEWR under real stormy weather condition. A330 v2b6 and XP11vb11.
Apart from flicker of instruments while rolling to runway, the flight proceed without bugs or other disturbances.
302
Same here, although I did have some auto throttle issues but they maybe related to my Saitek Panel
I would love if, when  XP11 is stable, the FMC could be upgraded to incorporate the IAFs for approaches. The FF Boeings do that beautifully.
303
Javier_Aldaz wrote:
Hello everyone,
Just a question. This update is only for X-Plane 11?. Or can I update my A330 on X-Plane 10 with it as well?
Thank you in advance
Javier
This is another product - a330 for X-Plane 11. You can update serial key to make it usable for both products. X-Plane 11 version cant work with XP10 - they are not back-compatible, cause of PlaneMaker format. New format cant be read by X-Plane 10.
304
siege00 wrote:
1. Flt Plan does not automatically scroll when passing waypoints.  This may be by design.
2. I could not enter heading mode while on the ground for preflight.  While airborne I was able to select heading mode.
3. Heading bug on ND did not render while in managed mode to allow for pre-selecting a heading before selecting heading mode.
yes, this is not done
siege00 wrote:
4. Decelerate did not indicate on the PFD when passing T/D. (it's possible that I may have missed it by looking in the wrong place)
Should be
siege00 wrote:
5. In descent phase, the CAB PRESS page of the ECAM did not render correctly.  No needles were shown on the digital gauges.
I will check this. Thanks! // checked - i have it Ok. can I ask you a screenshot of this trouble?
siege00 wrote:
6. At night, the ECAM page select buttons were not illuminated with the rest of the panels. (Did I miss a knob?)
7. Constraints did not print on the ND when selected.  Not sure if this is planned for/implemented or not.
8. Altimeter wouldn't display 30.08.  It displayed 30.09 twice however, Example: 30.07 -> 30.09 -> 30.09 -> 30.10.  Maybe a conversion issue from hPA to inHG.
Yes, that is some kind of incomplete
Thank you for report!
305
http://jardesign.org/forum/img/m/1591/t/p1afb9dmp6ioa1laj16fd10971lpm3.jpg
306
Sorry if this was asked before. the b6 of the A330 in XP11 shows 1 fuel tank only in the Xplane default fuel and cargo settings.
I did not go through the documentations yet but wondering if this is a bug in the A330 b6 or the fuel is meant to be loaded elswhere?
Javier_Aldaz wrote:
Hello everyone,
Javier
I tried to update and got a response that my serial was not valid - followed by a long serial that I had never entered.  The rest of the message was that it would cost (a small fee - not stated) to update to the latest beta.  Is this correct?  If so, I will stick to flying in XP-10 as I am retired and getting hit by update fees for everything I try to convert to XP-11 is not going to fly (pardon the pun).
John
308
Hello Eugeny,
i write for a friend who don't speak english, so...
A330 don't follow flightplan (i have sometimes the same problem),
i send you the log.txt but i don't find the bbox_log.
He have the red message from SASL say call support each time he enter flight plan in MCDU.
309 (edited by Sloboda 2017-02-17 07:25:09)
Hello Eugeny,
i have understand.
The SASL crash each time we try to enter a waypoint on the OACI departure in MCDU FlightPlan page.
Have a good day.
310
Hello Eugeny,
i have understand.
Have a good day.
I had the same problem some time ago. For me it was a broken sasl installation from inside another plane.
So you can do the following (for a short test):
- remove all planes from x-plane (move them to a differnt folder outside xplane.
- install A330 in xplane (as the one and only aircraft)
If the A330 is working, you know that one of your other planes has a problem :-)
are there any working liverys for XP11 and A330 b6?
Hello Eugeny,
i have understand.
Have a good day.
OK thanks Thomas
313 (edited by ilankrt 2017-02-19 13:58:52)
Test flight KJFK-KATL all functioning well, seems to be stable at least in this flight.
1. Annoying occurrence  is the exhaust fumes that looks awful ! (see image 1)
2. There are audio warning about other aircrafts crossing of coming near but no sign (white to red) on ND (like in the models of XP10) neither in the A320 nor in the A330) (see situation during landing 2)
3. ATC: ATIS info text out of frame (see image 3)
4. "next landing should be good" - and I thought it was a good landing (see short video) :-)
http://jardesign.org/forum/img/m/1591/t/p1b98ilujr3sntr84h1qvr11fd3.jpg
http://jardesign.org/forum/img/m/1591/t/p1b98imf951vov4j324aigf6sf6.jpg
http://jardesign.org/forum/img/m/1591/t/p1b98in0kp1nvb1dq51mk31vdg1tuq9.jpg
Video will be added soon..
https://youtu.be/FWja-srALj0
314 (edited by rsvette12 2017-02-19 20:08:34)
What a great product well done Jar have to figure out how my new ground handling purchase works with built in A320 menu options - bought BSS sound pack - great also smile now if we could get LR to fix the sky issues its pretty bad
315 (edited by rsvette12 2017-02-19 20:07:16)
Curios why does this green ring portion on engines is not there in XP version - it appears now as solid metal even though its shown on the image file to be used but not in actual sim thanks
http://i64.tinypic.com/28jic6.jpg
316
is someone know how to set door position for plave A330 correctly at autogate ?
317
Oooops should have posted in A320 forum on the green ring portion on engines - sorry
318
Hello Eugeny,
the EXT B button don't move when press on.
319
on B6.. it looks great.. but I am having trouble clearing items in FMC when I am doing a flight plan.
I am using :
iMac (Retina 5K, 27-inch, Late 2015
4 GHz Intel Core i7
32 GB 1867 MHz DDR3
AMD Radeon R9 M395X 4096 MB
mac os 10.12.3
Xplane beta 11.11 (64 bit)
X55 Saitek Pro Rhino Stick
X55 Saitek Rhino Throttle
320
I am using :
4 GHz Intel Core i7
32 GB 1867 MHz DDR3
mac os 10.12.3
You should specify what do you want to clear. Generally spoken, if you want to change parameter for example SID or STAR you just begin procedure for new and the FMC write over. You can simple delete waypoints with CLR or add new naming them and clicking on the waypoint you want to insert them...
BTW: Since I have the same computer I would lime to know how X55 Saitek Pro Rhino Stick
X55 Saitek Rhino Throttle works with XP11 and JAR A320/330. I appreciate if you can write me more detailed in private because I consider to purchase the new Saitek X56
321
In Xplane 10..in flight Factors planes and in Jar Planes.. I enter all the way points. eventually there is one line.. that says FP discontinuity.
I clear that and the flight plan is done.
but In 11.. the Flightfator planes work and so does the A320 Beta 2. But in the beta 3 of the A320 and the A330 beta 6.. they will not clear.
The throttles and all the switches work fine on the Saitek Pro Flight X 55 Rhino, befoer I got it I was using the keyboard for speed.
322
hey guys im having a problem with the A330 where when I try to input a waypoint I get a SASL red text error and it tells me to contact support any ideas
323
so I looked in the log file and im seeing a [SASL ERROR] Error updating avionics: [string "u//mcdu_fpln.sec"]:0: attempt to index a nil value any ideas how to fix this
324 (edited by thomas_99 2017-02-24 11:46:06)
You can try this: http://jardesign.org/forum/viewtopic.ph … 544#p15544
and report if it has worked...
Thanks a lot for your reports. Not all reported bugs was fixed in this beta, but will do. So.. beta 7 is out:
+ increase spoilers efficiency
+ Brake indication improved (thanks Lucas)
+ TOC/TOD indication fixed
+ Radio freq settings improved
We still expect engines/perfomance improvement from Laminars side in XP11pb12. Will see, will see..
+ Engines transparency bug fixed
+ some minor bugs fixed
