kebs wrote:@ ilankart
Ok now FP EBBR/KJFK
Two certified airports
making FP with Xlife ( Generate Flight Plan ), drop it in FMS with the command "Export plan to acf and file"
result 16313 NM, what do you think ?
same result with LFPO, LFBO etc..
I forget to mention, 100 waypoints in the xlife FP generated
Generally seen there is at the moment a babylon tower situation. Everyone talks to each other in other languages, meaning that everyone on his particular machine and versions of OSX, WIN, X-Plane, X-Life and so on and so forth, has its own specified problem that the other one cannot replicated, understand and help.
For example simulating on my iMac27 OSX10.11.06, X-Plane 10.51, X-Life 1.1r6 and A330 2.7 I made more than 100 flights with the A330 without any special occurrences ! I used to fly to all JAR certificated airports and the flight plans I made were accepted all the time. (If you like to see my preparations: http://ilankrt1.blogspot.co.il/2016/12/ … e-10.html)
OK now EBBR is not JAR certificated. That alone might cause problems. Then how did you made the FP? How did you prepared and transported it into XL "Flight Planes" folder? Is it based on the actual AIRAC 1701? ...and so on. You see if I get all needed specification I can make a try to reconstruct the situation although different hard and software as I mentioned before can produce different results...
X-Plane 11.30r3 | iMac27 OSX Mojave 14.10.4, | Samsung ultra-wide screen 49-inch | Saitek equipment | MFG pedals |Gladiator Joystick | Plugins: GndHandling, RWC, SMP, SoundM, X-Life, BetterPushback, AutoGate, SoundMaxx, X-ATC-chatter, X-Camera | iPad 12.9, iPad Air 9.7 | Airliner: JAR A320/A330, FF A350XWB, FF B767, SSG B747-8 inter, Epic1000 new, TBM900
