201
hi
the BBS soundpack actually works on XP11 with windows. I made two folders of the Jar to compare with and without and after installing the folders as per manual (can be confusing)  you can hear the difference in the engine starting up, and spooling up when going to full throttle.
as someone pointed out during the first beta I copied everything in the mac folder of BBS to the aircraft plugins folder. Try it out it should work.
Someone stated they can change between engines?
Cheers
Norman
202
oh sound pack def works.. got people talking in the cabin etc.. so much better
203 (edited by zandoma 2017-01-22 13:05:02)
Hey i downloaded the Beta 4 today and have XP11 pb8
As i want to start i cant rotate the knob for the Altitude Autopilot.
How did u manage that?
EDIT:
After XP11 restart worked....
204 (edited by vschwarz504 2017-01-22 14:42:10)
Dear Jevgeny, sorry more and more bugs came since beta 4 with xp beta 8. see my post above.
Now, when I start the autostartsystem, the engine didnt start and I can see only the yellow sign: wait......[
After my test flight, the left engine starts after cut off, when I switched off the apu.
regards.
Volker
205
I can't set up a pitch trim before takeoff. It stay 0 an it should be 3,5. Similar problem during manual flight, a pitch trim slowly goes to 0 so i keep triming. I use xsaitekpanels 2,58 plugin. regards przemek
206
regards.
Volker
autostart works ok for me (on Windows)
207
You may remove your saitek for a time. If will be ok with THS - saitek is a sourse of issue. Please check.
208
regards.
Volker
Lets check this together. You can call me skype j.a.romanov
209 (edited by ilankrt 2017-01-23 11:39:48)
Test flight A330 2.0B4 XP11, iMac27, XL 1.1r6
during takeoff throttle stocked ! could not remove, not with the mouse and not with Saitek throttle quadrant after
repeatedly calibration...
210
Does anybody know what is the correct heading range from the auopilot heading knob ?
I'm relatively sure that it is from 000 deg to 359 deg.
At the moment it is from 001 to 360 deg.
Does anybody know the download links for BSS sound updates? I still have v1.1.
Following the workaround here:
http://jardesign.org/forum/viewtopic.ph … 157#p15157
I don't get external APU sound. Has anyone a solution?
Many thanks,
joomie
212 (edited by vschwarz504 2017-01-23 17:45:49)
Many thanks,
joomie
You should download from xplane org store. My version works. Hm Its version 2.0 for trent 700. But PW sound pack is version 1.1. I didnt have it installed for a while. I try it now.
regards
213
Addon "JAR BSS TRENT 700 Main Pack ver 2.01" no longer works with version A330 b4.
Works with A330 b1 version.
Philippe
214
Fregatidae wrote:
BSS Soundpack not working
X-Plane 11 pb6, A330 v2.0b3, BSS A330 RR V2.01
Symptoms:
No engine sounds, no air pack sounds, no button/lever clicking sounds.
APU, FO voice and aircraft alarm & alert sounds still work (audible when changing sound levels in MCDU menu)
Please help, thanks.
The problem is BSS use some datarefs in their config files wich not exist yet in XP11.
So...
Open folder: BSS/custom/cockpit
edit the sound.cfg with a text editor
On first line,
you have: mastervolume_dataref=sim/custom/xap/snd/coc_vol_01
Replace with: mastervolume_name=COCKPIT
BSS/custom/engines
Replace with: mastervolume_name=ENGINE
BSS/custom/flctrl
Replace with: mastervolume_name=FLCTRL
BSS/custom/gpu
Replace with: mastervolume_name=GPU
Others folders are good.
Now you can copy custom folder in: 330_JARDesign v2.0b3\plugins\sound3d\
You will have all the faders in sound menu for set the a330
Adjust volume like you want
When I compare with the A320 there are more sound.cfg files to be edited I guess:
mastervolume_name=APU
mastervolume_name=LDGEAR
mastervolume_name=TOW
215
Sure !
When it's for another plane, you must adapt.
216 (edited by joomie 2017-01-23 20:37:58)
Using A330 2.0b4 with XP11pb I experienced that I can not extend the spoilers/ speedbrakes.
The cockpit says "Spoilers full" and I hear the sound like having spoilers out, but they are not moving.
http://jardesign.org/forum/img/m/436/t/p1b76fjj0n1p24mfc12r21fup1po76.png
Or is there a specific maximum altitude or maximum speed? flying 260 kts in 5500 ft they are out now.
217 (edited by joomie 2017-01-23 20:41:23)
Sure !
It's for the A330 BSS v1.1.
I adapted like showing in the following listing and have great sound now. Thanks for your tip!
joomie@joomiepc /cygdrive/X/global_xp_data/Aircraft/330_JARDesign_v2.0b4/plugins/sound3d/custom
$ grep -r mastervolume_name
apu/sound.cfg:mastervolume_name=APU
cockpit/sound.cfg:mastervolume_name=COCKPIT
engines/sound.cfg:mastervolume_name=ENGINE
flctrl/sound.cfg:mastervolume_name=FLCTRL
gpu/sound.cfg:mastervolume_name=GPU
ldgear/sound.cfg:mastervolume_name=LDGEAR
tow/sound.cfg:mastervolume_name=TOW
218 (edited by laohu314 2017-01-24 18:31:58)
Had a similar issue. I couldn't extend speedbrakes on the ground with engines off. Turned out I had the electric hydro pumps turned off. When engine is running the engine hydro pumps should be on automatically and the electric pumps can be turned off.
219
I recognised, that the pushback truck starts to pushback when the park brake is set.
I voice "Release parking brake, please!" would be cool.
Also great would be a voice "Set parking brake, please!" when the parking brake is not set and the user tries to remove the truck.
220 (edited by laohu314 2017-01-24 21:33:56)
Just had a perfect flight from KEWR to KBOS XP11.00pb8 in the A330v2.0b4.
There is actually a voice that says exactly what you want. You just have to click on the right button on the radio (it's highlighted when the tractor docks and there is alert sound). The video on YouTube Eugeny recorded a while ago shows it all.
221
Did you use for your sound the JAR A330 BSS TRENT 700 Main Pack ver. 2-2.01?
222
Yes, I did.
223
joomie wrote:
Sure !
I don't understand why you need to edit it. Did you install the windows version of the sound pack? did you try moving the mac version of the sound pack into the folders? As this works fine for me  without having to edit anything. The mac folder structure is already very similar to the A330 original plugins folder
224 (edited by thomas_99 2017-01-26 07:35:26)
Hi JAR,
I have 2 more bugs in the A330, at least I think so :-)
1) FMC VIA always inserted (old bug still there):
When programming an arrival route (STAR) the FMC asks for a VIA to insert. Regardless to the answer,
the VIA is inserted in the flight plan. Even if you say "no via" the via is inserted.
Easy reproducable in "EDLP", the VIA PAD1 is directly on the airport making the route not usable. Even if you select "no via" the VIA is inserted and you have to delete it afterwards by hand.
2) FMC managed mode sinkrate goes to infinity
Usually in autopilot mode you can select a vertical rate from -3000 to 3000 ft/min.
In managed mode, this can be much more.....
a) Program a route, say EDDH to EDDL. Set SID/STAR, FL300.
b) Takeoff, do the flight until "TOD"
c) just wait some time, say 2-5 Minutes. keep current height, FL300
d) Set new height, say 10000 ft.
What happens: the FMC calculates a vertical rate to reach the height from the current waypoint. This calculation does not respect the limit.
Yesterday i did a flight which leads to >7500ft/min sinkrate :-) Sure, overspeed included :-)
By the way, sinkrates >8000 ft/min are not shown in the PFD..
There is a delay about some seconds between the display of the altitude in A320/A330 in the cockpit to my hardware-displays.
I checked the datarefs, but couldn't solve the problem yet.
It's not possible to push or pull the buttons of the autopilot of A320/A330 with a key command. If I use a joystick-button to push or pull the buttons in the cockpit, it works. So, the datarefs are okay.
