151 (edited by kebs 2017-01-16 13:33:29)
for mac users ,JAR A330 BSS TRENT 700 Main Pack ver. 2.01 installation
with Xplane11 b6 and A330 b3 just put  Custom folder and BSS folder  ( BSS Pack ) into
A330/Plugins/sound 3d
and that works perfectly
FORGET absolutely Mac Version folder ( BSS pack ).
Is it possible to save  "fps disable and fcu manipulator knob" setting to permanently configuration as wanted ?
thank in advance
regards
152
Exact! BSS don't work
153
enrigolan79 wrote:
Eugeny,
Just try b3 between FMEE-FIMP ---> all ok (but bss sound pack not work - normal sound pack ok)
Is it possible to put "fps disable and fcu manipulator knob" setting to permanently configuration as wanted ?
thank in advance
henri
You may try take win.xpl and mac.xpl files from default sound3D folder and put it to BSS sound3d folder.
Cant set Off permanently. Can I ask you attach log.txt after a330 loading - i need check how your a330 plugin was loaded, if your mousewheel not work with FCU knobs.
Eugeny, In a330, there's no BSS sound3d folder. Just a Custom folder to place in Plugins/sound3d.
There's no win.xpl or mac.xpl
154
Just ran Beta 3, ran smoothly no problems in flight. There was a small problem with the radios, auto does not set the course for the chosen landing runway. In the flight I did it used the right frequency, but as I say the course was wrong. It could not be changed on the radio stack or on radio in the FMC.
However it did not effect the landing, the ILS was picked up correctly.
I think Eugeny is aware of this.
155 (edited by kebs 2017-01-16 15:17:28)
I can ear every BSS sounds perfectly, RR engines or PW engines ( Blue Sky Star A330_1.1_PW_expansion )
156
maybe you are on Mac ?
I'm win7 user and no bss sound with xp11pb6 and a330v2.0b3 !!
157
same for me,on win 10 and the BSS sound don't work.
158
Yes on mac
osx el capitan
Xpl11 b6
A330 b3
159
contact Konrad of BSS if problems
he is very reactive
amrussinc@gmail.com
160
Ok merci beaucoup ;-)
161
I've got the same problem with bss. Exactly the same error inside the log.txt
162
enrigolan79 wrote:
Eugeny,
thank in advance
henri
So, i need someone with this trouble call to my skype j.a.romanov
We will check how this work and what need to do.
163
BBS sounds not working (win 10)
164
Hi Eugeny,
i have an issue with SASL each flight.
A big message say contact JAR and give log.txt
So, i do...
165
JD330XP11v2.0b3, Windows 7 xp11pb5
...besides most of above (BSS sound pack not working), I noticed a contrail in front of, and sometimes 90 degrees right of the cockpit.  In this screenshot, it's barely noticeable in front center but more noticeable in real time flying.  The normal contrail in back of the plane is still there.
http://jardesign.org/forum/img/m/70/t/p1b6lf6bh1prm19leqqc1ug51n5e3.jpg
I also had problems with AT during my approach at 5000ft, it took me overspeed so I had to take over manually, which I normally do anyway at 1,000ft unless I'm experimenting with autoland.
Finally, the Altitude button was moving on its own, up and down (in and out) quite fast. It stopped with a right click.
Hope this helps
166 (edited by Fregatidae 2017-01-17 12:47:45)
BSS Soundpack not working
X-Plane 11 pb6, A330 v2.0b3, BSS A330 RR V2.01
Symptoms:
No engine sounds, no air pack sounds, no button/lever clicking sounds.
APU, FO voice and aircraft alarm & alert sounds still work (audible when changing sound levels in MCDU menu)
Please help, thanks.
167
2.03
1. No speed reduction to 250 below 10000 feet. DES mode.
2."Land green"-LAND- is lit while other message says LND INHIBIT (speed breaks were up, flaps not fully extended)
Thanks,
Dan
168 (edited by Sloboda 2017-01-17 15:22:04)
Symptoms:
The problem is BSS use some datarefs in their config files wich not exist yet in XP11.
So...
Open folder: BSS/custom/cockpit
edit the sound.cfg with a text editor
On first line,
you have: mastervolume_dataref=sim/custom/xap/snd/coc_vol_01
Replace with: mastervolume_name=COCKPIT
BSS/custom/engines
Replace with: mastervolume_name=ENGINE
BSS/custom/flctrl
Replace with: mastervolume_name=FLCTRL
BSS/custom/gpu
Replace with: mastervolume_name=GPU
Others folders are good.
Now you can copy custom folder in: 330_JARDesign v2.0b3\plugins\sound3d\
You will have all the faders in sound menu for set the a330
Adjust volume like you want
169
Exellent Sloboda, Thank you.
170
Thank you very much big_smile
171
And the next bug: ILS diamonds not working in manual mode. Tried 3 times....
1) Load Plane, press "hot start".
2) take off (manual), and go back to the airport (here: EDDL)
3) set NAV frequency to ILS, here: 109.30, switch on LS
4) look at the pictures....
Frequency:
http://jardesign.org/forum/img/m/552/t/p1b6mqppammt1nqa10e1glt129o3.jpg
PFD:
http://jardesign.org/forum/img/m/552/t/p1b6mqppame111c5ohbr18bg1rso4.jpg
EDDL Info:
http://jardesign.org/forum/img/m/552/t/p1b6mqppammuclstbclfc7dch5.jpg
Problem:
http://jardesign.org/forum/img/m/552/t/p1b6mqppambh11muh1mu21d00156r6.jpg
http://jardesign.org/forum/img/m/552/t/p1b6mqppami7tq4k15sf1fir1tri7.jpg
http://jardesign.org/forum/img/m/552/t/p1b6mqppam15dbgh71qoiukvuga8.jpg
Hi Eugeny,
So, i do...
Hello Eugeny,
Bss a330 sound pack work well now.
But I have same issue now than Sloboda !!
173 (edited by Sloboda 2017-01-17 19:52:44)
enrigolan79 wrote:
Hi Eugeny,
So, i do...
Hello Eugeny,
Hello Enrigolan,
the problem is the navdata.
Remove navdata in Customs and just use original _navdata in the a330 folder.
Test it.
174 (edited by Sloboda 2017-01-17 20:09:30)
Frequency:
PFD:
EDDL Info:
Problem:
Sorry but it's not the ILS diamond. It's the G/S diamond.
So...
Have you active LS(OK) + APP ???
I say that because if you just active LS, it's not a bug. It's normal.
G/S is captured if APP is active and Approach Phase activate in FMS Perf Page
175
How do we update new beta versions? Do we back up the old folder and then install the new version and re-enter the serial key?
