126
kebs wrote:
I dont know why, but during landing I can't stop the reverse - first trouble
After that , I can't shutdown  both engines- second one
am I the only one with this problem ?
It was the same with b1.
Mac  Osx Sierra
X plane 11 b5
A330 b2
Yes, same to me.
Can one of Blue Sky still use the sound?
Thanks Robert
128
I use JAR A330 BSS TRENT 700 Main Pack ver. 2.01
if its your question
another bug
I can start both engines with fuel pumps OFF
OSX Sierra
XP11 b5
A330 b2
130
I find 2 bugs,
1- The fuel does not reduce from 10931 kg
2- Both Engines does not off.
X-plane 11B6
A330 B2
Ali
131 (edited by MikeMJD 2017-01-14 16:52:51)
Hi Jar.
V1.3R3 downloaded but no liveries in the zip file.
As this is first beta I have downloaded, can you send a zip of the liveries to me please.
Many Thanks.
Forget have downloaded from Liveries that i needed to test.
Mike
hmm
132
So.. what we have right now..
- "10931 fuel" bug is not fixed - i just send info to Laminars
- "Not active ILS/GS dots" is not fixed, cause Laminars change its working conditions - i send info to Laminars
+ Go Around plan issue fixed and will be publish with next beta
+ Menu Volume issue fixed and will be publish with next beta
+ Wrong HDG->NAV transition  fixed and will be publish with next beta
+ Unable to shutdown engines fixed and will be publish with next beta
+ about 10 minor problems
I am still work on "hold issue" and hope prepare beta 3 when done it.
133
Just programmed a flight:
Init Page:  EDNY/EDDS, FL: 150, CostIndex: 80
F-Plan Page: EDNY Dep 06, ALAG5E, NO TRANS
                     EDDS ILS07, BABE!E, NO VIA, NO TRANS
                     CLEAR DISCONT
So far looks good and correct, but NO TOC/TOD inserted and shown....
Best regards,
Distance is too short for climb to FL150 and descent for a330 parameters of vnav.
So it can't calculate TOC/TOD.
With this distance/FL, perhaps the TOC is after TOD...
Usually the fmc does not accept FL if it is too high....
Oh, seems that the FMC accespts all levels up to 410... old verson had an error "ERROR FL LEVEL TOO HIGH".
this version not clear FL if it too hi, but recalculate it to maximum for this distance and conditions, like rear a330 do with NEW CRZ FL message.
134
Is anyone have video with "preselected HDG takeoff"? I want to do this for a330.
135
@Eugeny Romanov
https://www.youtube.com/watch?v=5pPUHTGmwpQ
Lawrence
136
thanks
I find anoter bug after I install the new X-plane PB6,
the cockpit lights are turn off and I can not turn on them.
Ali
137
For some reason with B2 in both XP11pb5 and pb6, I can't get the engine hydrolics pumps to work. And also, maybe related, even with full power I can't get the bird to move. Maybe something is messing with my breaks again...
138
zasavage wrote:
@Eugeny Romanov
Lawrence
Ok, thanks. Sadly not see all details, but see common well.
139
Thanks for your reports!
+ "10931 fuel" bug is fixed now
Will continue. Sadly with every new XP beta we get doze of new troubles smile
@Eugeny Romanov
https://www.youtube.com/watch?v=WI0EM8dz170
Lawrence
Hi, I have done 3 full IFR flights now in the B2 version.
1. I think this is a known bug - the FOB countdown stops at 10,931 KG and doesn't reduce further.
2. After is stops counting down the engines can "Oscillate"with blue needles and the FF figures are erratic (up and down)
3. The aircraft has a tendency to go over-speed during descent even when I start descent early.
Otherwise great - please keep up the bug fixes!
142
May be you just have StandBy pumps left and right On.
143 (edited by kebs 2017-01-15 21:42:38)
I should  prefer a simple mistake like that, but not, alas.
Also impossible to shutdown engines
no more problems of reverse since last X11 update.
Attachment icon Capture d’écran 2017-01-15 à 22.30.22.png 449.87 kb, 119 downloads since 2017-01-15
Attachment icon Capture d’écran 2017-01-15 à 22.32.25.png 241.8 kb, 129 downloads since 2017-01-15
Attachment icon Capture d’écran 2017-01-15 à 22.35.32.png 500.48 kb, 166 downloads since 2017-01-15
144
So.. beta 3 just posted:
beta 3
+ Go Around fixed
+ ILS diamonds indication fixed
+ ILS approach fixed
+ Sound Volume page in MCDU MENU fixed
+ Impossible engines shutdown fixed
+ 10300 KG fuel "stuck" fixed
+ some of minor XP11 incompatibles fixed
XP11 bring us a lot of job and JARDesign crew migrate from "X-Plane addon Developers group" to "X-Plane addon Reworkers group" now. Just a joke.. He-He-He smile
145
No problems with reverse, but you CANT toggle off reverse if your thrust levers not at IDLE in this moment.
146
Thank you Eugeny for b3 version...
and thank you to "reworkers group"  ;-))))))))
see you for xp11pb7 !!!
Thanks a lot
148
Eugeny,
Just try b3 between FMEE-FIMP ---> all ok (but bss sound pack not work - normal sound pack ok)
Is it possible to put "fps disable and fcu manipulator knob" setting to permanently configuration as wanted ?
thank in advance
henri
enrigolan79 wrote:
Eugeny,
thank in advance
henri
You may try take win.xpl and mac.xpl files from default sound3D folder and put it to BSS sound3d folder.
Cant set Off permanently. Can I ask you attach log.txt after a330 loading - i need check how your a330 plugin was loaded, if your mousewheel not work with FCU knobs.
150
Eugeny,
I have tried : "You may try take win.xpl and mac.xpl files from default sound3D folder and put it to BSS sound3d folder."
unfortunatly not working...
sorry can't attach log.txt !!!
can attach only image : mousewheel work fine but at opening a330 fcu knob are at default configuration as in pict...
if it is possible to set in other config ? it would be nice...
thank
