Hello Eugeny,
sorry to say like that but... You must see absolutly this BUG.
Because i described it since the first version. So, it exist on XP10 and 11.
It's impossible to fly with a330 from LFPG.
The bug mostly appear when we go to runway 26R.
It appear not sometime but each time we do that.
I'm not alone with this bug
It's only with a330JAR
It's with all LFPG sceneries (XPFR, TDG, Aerosoft)
i have make a video for you, say me when i can delete this video:
https://www.youtube.com/watch?v=p9K3pk5g_0E
Many thanks
UPDATE: video is deleted
Problem will be solved by Eugeny
Jardesign A330 needs the navdata in X-PLANE 11/Custom Data/GNS430/navdata. Putting navdata in the A330/_navdata will crash XP11. After putting the navdata into X-PLANE 11/Custom Data/GNS430/navdata, A330 works, but the XHSI-ND only shows the waypoits as GPS-Data, not in waypoit-names. Airport-names are okay.
A330/_navdata is Ok, but that was wrong data in ZIP. Now, I just reupload ZIP and include good _navdata
A330-200Beta 2 , when selecting pushback truck , we had a Crash to Desktop , Image and Log included.
Emma Bentley
Apple Mac Studio M2 Max , 38 Core GPU
pic wrote:
We test it right now before publish. Soon..
Looks like x-plane Beta5 has a tone of problems, especially with frame rates. Lots of reports of having 30+ in PB3 and when 4 and 5 hit, their lucky if they get 5fps! YIKES!
I missed the update and will copy my 11 iin order to have a semi stable version and then continue helping LR get it right...so, probably safe to say a beta Airbus will need to wait for PB6?
I just set all to minimum to fly somehow. Sure, i get 30-50 frametate. Possible to test some. Again - beta is for beta-testers - people who unrerstand what trouble of product may be more when pleasure of it.
OK...I updated xplane 11 to PB5 as a second copy, and before you updated 330 just now, earlier I flew a stock ac and flew smooth as a silk sheet, absolutely no problems most peeps having..but, I've never used the reflections nor the ai ac. NOW, just back from running errands and I'm downloading the new beta 330 (cannot wait to fly her!)
Will report back asap!
Thanks Geni!
I have noticed some graphical texture issues I have attached some picture http://jardesign.org/forum/img/m/1424/t/p1b64e3ibd1a5btq1ui8bv17d5.png
107 (edited by Sloboda 2017-01-10 15:32:12)
X-Plane musn't crash, but... You can't call pushback if the GPU is connected.
108
Just finished first flight on xplane11 PB5, absolutely no major problems. (TNCM-TJSJ)  After doing the restart after entering code, FMS worked flawlessly with my flight to Miami, which I did a re-direct to SanJaun Puerto Rico, mainly to shorten the flight. The plane flys wonderfly, nice work Eugene. Small problem with XHSI with showing stars as numbers.
I will do an extensive flight when I can, but this short one gave me a good handle on what I will look at next time.
Incidentally, my nav data was updated last month, haven't did the latest from last week, but the data was being used from the xplane root file custum data, gns430.
One thing. On taxi, the copilot said 10 then nice landing when I was pulling up to the gate. He did call out on the actual landing as well.
Also, sounds were low despite changing them in the fms.
I give you my files for your ref. OH..cannot find the BB file..no more?
Again...great work!
Just did a short flight from EDNY to EDDL:
Here are some screenshots:
Switch to flight plan without plan, then enter something:
http://jardesign.org/forum/img/m/552/t/p1b64q1qt23dc1p3fm7ubmo1nct3.jpg
Simple Plan from EDNY to EDDL makes a loop:
http://jardesign.org/forum/img/m/552/t/p1b64q1qt21r3vh771e5a1ko2194n4.jpg
Pressing "b" for park break switches break off, but not on. Switch is somewhere between on and off:
http://jardesign.org/forum/img/m/552/t/p1b64q1qt211v5ptnpei12hv5ck5.jpg
plane goes really deep...
http://jardesign.org/forum/img/m/552/t/p1b64q1qt2cl8lt1keh1rp51oo06.jpg
Graphics errors:
http://jardesign.org/forum/img/m/552/t/p1b64q1qt31933opc1pdvd6u1gde9.jpg
http://jardesign.org/forum/img/m/552/t/p1b64q1qt2eodn8i1ta41pt4db17.jpg
graphics erors:
http://jardesign.org/forum/img/m/552/t/p1b64q1qt3g31ggj1obgl115sla.jpg
http://jardesign.org/forum/img/m/552/t/p1b64q1qt3180n1p86176ksca1fu88.jpg
http://jardesign.org/forum/img/m/552/t/p1b64q1qt31g29ukm1ssff835sob.jpg
best regards....
110
kentabj wrote:
Hello, downloaded last beta and when i run it  i get a message that i should download microsoft visual c++ 2010 redistributable package ,i have that installed already still get the message in the plane,i redownloaded the visual c++ and still the same.
thx for a great plane btw .
If this message distrib you, you may delete "diagnost" folder from a330 plugins folder
Wouldn't it be better to resolve the bug ?
Seems that there are some different versions of the "c++ 2010 redistributable package". When I try to install
the original package downloaded from microsoft, I get the error "a newer version already installed".
So this error message is maybe due to different versions of the package. I have the version 10.0.40219
installed and I get the error message within the A330.
Did you guys get rid of the thing where if you hit terrain twice it would show a taxi cam?
where can i buy download beta version a330 for x plane 11 please
113
Hi, it's on the 1st page in this forum...
- All users who bought the A330 AFTER the X-Plane 11 presentation event (October 2016 and later) may use their serials with X-Plane 11. If problems - please http://www.support.jardesign.org
- All users who bought the A330 BEFORE the X-Plane 11 presentation event (October 2016 and later) may update their serials (get new one) to make it worked with both - XP10 and XP11. This service should help http://jardesign.org/a330-jd-x-plane-11-update/ Update fee is about $19,95 (not include VAT for your country). Sure, you own a330 for X-Plane 10 and may continue to use it with X-Plane 10 simulator with no problem. No update need in this case. Support is continue.
Sure you are right to buy it. Eugeny's planes are marvelous !
Good flight
114 (edited by jesse.industries 2017-01-11 09:26:33)
http://jardesign.org/forum/img/m/3508/t/p1b66dgepe1i751dlk126d48duqh3.png
Found purely cosmetic bug "hollow engines", when engines running.
115 (edited by hawk4base 2017-01-11 23:35:33)
Test flight report for V202b A332
Route : EDDF/25L EGLL/27R
BIBT4F BIBTI UZ29 NIK UL179 SASKI UL608 LOGAN WEAL1E
Remarks
FOB 14.000 KG BLOCK
CRZ ALT FL400
TOW 168.000  KG
CI 30 CRZ SPD /0.76 M
Bug's fund
LNAV stopped working @ T/C , was able to regain ops with DIR to next Way point with no further fails.
ENG RPM N2 shown on display after start 23% till Cruise Alt was reached
ENG RPM N2 shown @ CRZ 19% , on descend N2 17%
ENG OIL temp after start @ 153 C for both
ENG oil temp @ CRZ 138 C for both
ENG OIL temp during decent rising form 138 to 150 C
ENG OIL pressure remained static @ 100 PSI for No.1 and 103 PSI for No.2 with changing Oil temp and RPM
Fuel on Board counter stopped working @ 10.399 KG
Fuel used counter stopped working after 3.065 KG of fuel was used by the Engines
Fuel Flow counter keep working true the flight
116
Incidentally, that info (below) was just a NEWS update, not a complaint smile I've been here beta testing ALL your excellent products a long time to know that, Eugene smile Grazi
117
Remarks
FOB 14.000 KG BLOCK
CRZ ALT FL400
TOW 168.000  KG
Bug's fund
I am sure you really need redounload more fresh beta 2. Please use link at first post of this topic. Thank you for report.
118
Beta flight on xplane beta 5 and A330 V2.0B2
Some minor FMS issue on Flight from TNCM-KMIA (About 3hr flight). Used the new Ground Handling plugin and X-Life.
Seemed like a flawless flight, everything working and looking great. However, could not change livery.
Then, on my STAR approach, suddenly a loop formed on the ND without any input. So I just did a DIRECT to the next proper star to continue with my approach, then final. (Did a go-around too)
Noticed on replay, the speed brakes did not deploy/Animate on landing and ground system called out too low and flaps for no apparent reason.
Ground Handling worked excellently, and X-Life gave a good response and data as well (her voice is a little low)
Attached is my log fyi
wink
119
Just programmed a flight:
Init Page:  EDNY/EDDS, FL: 150, CostIndex: 80
F-Plan Page: EDNY Dep 06, ALAG5E, NO TRANS
                     EDDS ILS07, BABE!E, NO VIA, NO TRANS
                     CLEAR DISCONT
So far looks good and correct, but NO TOC/TOD inserted and shown....
Best regards,
120
                     CLEAR DISCONT
Best regards,
Distance is too short for climb to FL150 and descent for a330 parameters of vnav.
So it can't calculate TOC/TOD.
With this distance/FL, perhaps the TOC is after TOD...
121
                     CLEAR DISCONT
Best regards,
Usually the fmc does not accept FL if it is too high....
Oh, seems that the FMC accespts all levels up to 410... old verson had an error "ERROR FL LEVEL TOO HIGH".
You are right
Is it possible to put BSS A330 custom sound pack into A330v2.0b2 ?
Thank you in advance.
124
I have with good results. Cheers
125 (edited by kebs 2017-01-12 22:08:12)
I dont know why, but during landing I can't stop the reverse - first trouble
After that , I can't shutdown  both engines- second one
am I the only one with this problem ?
It was the same with b1.
Mac  Osx Sierra
X plane 11 b5
A330 b2
