Airbus.Italia wrote:
I do not understand anything ... ...the  new beta versions of the A330 and 320 which will be available on the forum won't be compatible with x-plane 10?? Yes or no?
If aircraft was saved in XP11 PlaneMaker - it cant be compatible with XP10, XP10 cant read it.
then, there will be two sections for download, one for x plane 10 and 11 other pears x plane?
Yes, 2 different ZIPs should be? for 10 and for 11.
kebs wrote:
Yes
no problem for me with BSS
are you on windows? when I look in the folder structure of the soundpack and the folder structure in the A330 XP11 version
the engine folders don't really match.
Yesterday I could download ghd pack. Thanks! Link works well, true.
80 (edited by thomas_99 2017-01-08 12:04:04)
I have a SASL ERROR while entering a flight plan.
LOWI -> EDNY, Arrival at EDNY, temp flightplan insert -> no reaction.
There is a red text for 1/10 second, saying SASL error contact JAR with log :-)
Looks like i solved the SASL ERROR:
If you have a plane with SASL which is scanned "before" the A330 AND has an older version of SASL, XPLane 11B5 will use the older version, which will maybe NOT work with A330.
I replaced the SASL plugin on CT182 with the one from A330, and now my SASL Error was gone and I can enter a flight plan.
When will the next beta appear? Another test makes no sense at the moment. ATM i have problems with the views, saved over the numpads..
We test it right now before publish. Soon..
83 (edited by lukascaptain 2017-01-09 10:19:19)
Hey smile
I downloaded this beta for using it in XP11.
When loading first time the 330, these two messages occured. Has anyone an idea how to fix?
Thank you smile
Looks like x-plane Beta5 has a tone of problems, especially with frame rates. Lots of reports of having 30+ in PB3 and when 4 and 5 hit, their lucky if they get 5fps! YIKES!
I missed the update and will copy my 11 iin order to have a semi stable version and then continue helping LR get it right...so, probably safe to say a beta Airbus will need to wait for PB6?
UPD: Ok, link to ZIP is updated. Beta 2 come. So.. continue..
beta 2:
+ rework ND drawing, please test
+ vertical profile calculation reworked
+ sound issues fix
+ diagnostic plugin improve
Need reinstall full aircraft (or just install another copy)
For now, the solution is to set AI aircraft to 0 and reflection detail to minimum. That seems to solve the frame rate and flickering problem for most people. I've always had those setting so all I have seen is an improvement in fps relative to XP10.
I just set all to minimum to fly somehow. Sure, i get 30-50 frametate. Possible to test some. Again - beta is for beta-testers - people who unrerstand what trouble of product may be more when pleasure of it.
Hello, downloaded last beta and when i run it  i get a message that i should download microsoft visual c++ 2010 redistributable package ,i have that installed already still get the message in the plane,i redownloaded the visual c++ and still the same.
thx for a great plane btw .
If this message distrib you, you may delete "diagnost" folder from a330 plugins folder
90 (edited by thomas_99 2017-01-09 17:40:43)
Does not work at all, CDT while loading....
activation works, but with red "SASL ERROR"
After activation could not load plane, CDT.
91 (edited by laohu314 2017-01-09 18:59:05)
Test flight with latest beta, X-Life, SMP4, RWC1.1, X-RAAS
1.) Still issue with PATSS DCT NELIE (no idea why). used it anyways, works in A330 not in XL
2.) No TOC, no TOD on FMC nor ND
3.) FOB doesn't count down (see screenshot)
4.) Flight path discontinuities (on turns) on ND (screen shot)
5.) Engines still do not shut down (screenshot)
6.) Liveries not showing - just get "House" Livery EDIT: on reload, liveries show!
Disregard sound errors, I installed BSS in flight (I know, not a good idea...)
92 (edited by cole12j 2017-01-09 19:37:00)
The A330B2 doesn't even load for me. There seems to be something wrong with the 'scratchpad'. The activation works, but there is a SASL error message. When I reload the aircraft, X-Plane crashes.
[SASL] Path to panel: H:\Games\X-Plane 11\Aircraft\Airbus\330_JARDesign\aircraft.key
[SASL] Loading avionics...
[SASL INFO] loading    panel
[SASL INFO] including    navdata.lua
[SASL INFO] "panel"    ERROR: NavData source not found
[SASL INFO] "panel"    SASL components loading...
[SASL INFO] loading    first
[SASL INFO] loading    drf2tbl
[SASL INFO] loading    sstick
[SASL INFO] loading    init
[SASL INFO] loading    animation
[SASL INFO] loading    reload
[SASL INFO] loading    rectangle
[SASL INFO] loading    draw_test
[SASL INFO] loading    pfdcalc
[SASL INFO] loading    fadec
[SASL INFO] loading    adirs
[SASL INFO] loading    ap
[SASL INFO] loading    menu
[SASL INFO] loading    fl_cont
[SASL INFO] loading    sound_sys1
[SASL INFO] loading    sound_fo
[SASL INFO] loading    sound_st
[SASL INFO] loading    sound_sys2
[SASL INFO] loading    ground
[SASL INFO] loading    icerain
[SASL INFO] loading    radio
[SASL INFO] loading    phase
[SASL INFO] loading    view
[SASL INFO] loading    light
[SASL INFO] loading    hotstart
[SASL INFO] loading    textureLit
[SASL INFO] loading    switchLit
[SASL INFO] loading    clickable
[SASL INFO] loading    mcdu_mng
[SASL INFO] loading    mcdu_acstat
[SASL INFO] "mcdu_acstat"    12.16 version info 2.0 FOR X-PLANE 11
[SASL INFO] loading    mcdu_radnav
[SASL INFO] loading    mcdu_prf_to
[SASL INFO] loading    mcdu_prf_clb
[SASL INFO] loading    mcdu_prf_crz
[SASL INFO] loading    mcdu_prf_des
[SASL INFO] loading    mcdu_prf_appr
[SASL INFO] loading    mcdu_prf_ga
[SASL INFO] loading    mcdu_int
[SASL INFO] loading    mcdu_intb
[SASL INFO] loading    mcdu_data
[SASL INFO] loading    mcdu_menu
[SASL INFO] loading    mcdu_prog
[SASL INFO] loading    mcdu_calc
[SASL INFO] including    tables.lua
[SASL INFO] loading    mcdu_fuel
[SASL INFO] loading    mcdu_draw
[SASL INFO] loading    gpws
[SASL INFO] loading    weather
[SASL INFO] loading    ext_anim
[SASL INFO] loading    pfddraw
[SASL INFO] loading    nd
[SASL INFO] including    magvar.lua
[SASL INFO] loading    isis
[SASL INFO] loading    mtr
[SASL INFO] loading    plate
[SASL INFO] loading    counter
[SASL INFO] loading    sys_apu
[SASL INFO] loading    sys_elec
[SASL INFO] loading    sys_hyd
[SASL INFO] loading    sys_bld
[SASL INFO] loading    sys_cond
[SASL INFO] loading    sys_drs
[SASL INFO] loading    sys_oxy
[SASL INFO] loading    sys_press
[SASL INFO] loading    sys_whl
[SASL INFO] loading    sys_fctl
[SASL INFO] loading    sys_fuel
[SASL INFO] loading    dr_refuel
[SASL INFO] loading    dr_sheet
[SASL INFO] loading    sys_eng
[SASL INFO] loading    sys_eng_sys
[SASL INFO] loading    sys_flaps
[SASL INFO] loading    sys_fwc_nor
[SASL INFO] loading    sys_fwc_abn
[SASL INFO] including    abn_table.lua
[SASL INFO] loading    dr_panel
[SASL INFO] loading    mcdu_fpln
[SASL INFO] loading    scratchpad
[SASL ERROR] can't load component    scratchpad
[SASL ERROR] Error loading panel: [string ".../scripts/init.sec"]:0: attempt to index a nil value
Same problem for me
Hi!
Same problem for me
Got the Problem. You have to copy
../X-PLANE 11/Custom Data/GNS430/navdata/ folder from X-Plane 10
It does not work with _navdata included in the A330 Package.
For the first look no problems with b2 and XP11b5. Frames are good about 35 - 45 f/s.
You did a good job!
Dieter
96
please be sure what you have _navdata folder inside your a330 folder
Hi!
Same problem for me
Eugeny, could you please confirm this. I copied the files from the GNS430/navdata folder into the _navdata folder of the A330 and
didn't have a problem. Should I not have done that?
Many thanks,
Hans
98 (edited by Sloboda 2017-01-10 07:07:02)
Hello Eugeny,
sorry to say like that but... You must see absolutly this BUG.
Because i described it since the first version. So, it exist on XP10 and 11.
It's impossible to fly with a330 from LFPG.
The bug mostly appear when we go to runway 26R.
It appear not sometime but each time we do that.
I'm not alone with this bug
It's only with a330JAR
It's with all LFPG sceneries (XPFR, TDG, Aerosoft)
i have make a video for you, say me when i can delete this video:
https://www.youtube.com/watch?v=p9K3pk5g_0E
Many thanks
Hi!
geodix wrote:
Same problem for me
Many thanks,
Hans
The real problem what not all needed files was pack into ZIP. My fault. So, please redownload ZIP again, delete old _navdata folder from installed a330 and put new _navdata folder from ZIP there.
Hello Eugeny,
Many thanks
Thanks for video. I need to get this bug at my computer. Can I ask you contact me with skype - we will try to found issue?
