Topic: Takeoff (very good sound)
http://www.youtube.com/watch?v=5pPUHTGmwpQ
http://www.youtube.com/watch?v=rFeqjuy_b4M
http://www.youtube.com/watch?v=Ok18QiPkL1o
JARDesign Group Board → Screenshots, Videos → Takeoff (very good sound)
- But yes, this is what we need in JARDesign ^^
Please ?
agree, absolutely realistic sound
agree, we need it
Today im try make some RR sounds and refresh old skills RR Spool Up...
Oh yes! That sounds already pretty awesome!
I tried the same for exterior APU sound and internal cockpit sound: https://www.youtube.com/watch?v=Xcp7gJ7x0V0 Neglet the overhead pushbuttons to turn on the sounds. These have to be different. Also: when PACKS go to OFF, less pressurization sound is needed.
Give me samples of the sound on video, im try to reproduce.
A330 Exterior Sounds (HD not available): https://www.youtube.com/watch?v=aAh4mSSgpl8
- I used 5:34 - 5:48 for APU for rear xyz-position.
- 1:11 - 1:15 can maybe also be used for the APU sound but as front xyz-position.
- Would be awesome to create more 'sound positions' such as LH- and RH Wing sound positions and position sounds near the outflow valves, gears, engines etc. Not sure how 'easy' it is for you (or JAR) to create these new sound positions for 3D.
A330 Cockpit Sound (HD available): https://www.youtube.com/watch?v=SeRMg3WlA2c
This is a tricky one since the recorder changes his position pretty fast so you hear change of sound. Furthermore, you hear the PACKS as well. So, we need two record samples to manipulate the packs ON/OFF effect.
- 4:22 - 4:35 can be used as PACKS ON sound (nice rumble sound at that moment but volume has to be decreased significantly).
- 5:25 - 5:33 can be used as 'general' cockpit sound maybe (no heavy rumble sound here).
- Would be awesome to create more 'sound positions' such as LH- and RH Wing sound positions and position sounds near the outflow valves, gears, engines etc. Not sure how 'easy' it is for you (or JAR) to create these new sound positions for 3D.A330 Cockpit Sound (HD available): https://www.youtube.com/watch?v=SeRMg3WlA2c
This is a tricky one since the recorder changes his position pretty fast so you hear change of sound. Furthermore, you hear the PACKS as well. So, we need two record samples to manipulate the packs ON/OFF effect.- 4:22 - 4:35 can be used as PACKS ON sound (nice rumble sound at that moment but volume has to be decreased significantly).
Ok. On this time we need test engine pack. Im upload pack on forum for test.
Sounds really promising ...
Ok... Welcome to test http://jardesign.org/forum/viewtopic.php?pid=1753#p1753
