Topic: v.2.0b1,b2,b3,b4,b5,b6,b7,b8,b9 for X-Plane 11 (Windows, MAC OS)
This is next public version of a330 for X-Plane 11. Both, a330 and simulator are on beta stage and have a numbers of issue. Please take part in this beta-tests if you really want be beta-tester. If you want fly-ready product - please just wait.
What is this and what happen with old XP10 version:
beta 1:
+ objects and textures was reworked according with new material system of XP11. Reworked.
+ NavData was removed from XP11 by Laminar Research and this was fixed for a330 (add _navdata with old Aerosoft cycle direct to a330 folder). Fixed.
+ a330 soundsystem was broken, cause X-Plane mastervolume datarefs. Now, you can use volume selectors from upper Plugins->Sound3D menu). Reworked.
+ a330 rain system was broken. Reworked.
+ add Diagnostic plugin, what can help if some installation was wrong (red message at screen if problem happen)
+ Framerate (FPS) is too low, compare with XP10, please use minimum visual settins to get normal framerate.
- Perfomance and fuel calculation was broken in XP11 and we will rework it at last stage, after XP11 release.
+ Navigation system was broken and FMGS was reworked to be compatible with new XP FMS. Sure, it have several issue now, like wrong flying on hold and wrong course to first air point. Please report. I will fix.
+ Cockpit buttons night lighting was broken. Fixed.
beta 2:
+ rework ND drawing, please test
+ vertical profile calculation reworked
+ sound issues fix
+ diagnostic plugin improve
beta 3
+ Go Around fixed
+ ILS diamonds indication fixed
+ ILS approach fixed
+ Sound Volume page in MCDU MENU fixed
+ Impossible engines shutdown fixed
+ 10300 KG fuel "stuck" fixed
+ some of minor XP11 incompatibles fixed
beta 5
+ APU fuel cons. fixed
+ Tow crash fixed
+ COM radio freq tuning fixed
+ cockpit light fixed
+ minor bugs fixed
beta 6
+ SPEED mode unstable fixed
+ LVR CLB flash fixed
+ vertical profile improved
beta 7
+ increase spoilers efficiency
+ Brake indication improved (thanks Lucas)
+ TOC/TOD indication fixed
+ Radio freq settings improved
+ Engines transparency bug fixed
+ some minor bugs fixed
beta 8
+ engines retune to make compatible with XP11pb13
beta 9
+ as Laminars just rework ILS "dot" datarefs and system, we fix this too
Download link: outdate
Please install new version of Ground Handling to be well-compatible with XP11
Download link: http://jardesign.org/gndserv/download/GHD.zip
- be sure, that you use X-Plane 11.00beta8
- copy unziped "330_JARDesign" folder to ..\X-Plane 10\Aircraft\ folder
- please visit download more fresh version of Ground Handling plugin. It work with JARDesign 330 without registration (for free). Please note what “Deluxe” version of this plugin (may work with other aircrafts) is payware.
a330 use NavData from
../X-PLANE 11/Custom Data/GNS430/navdata/ folder
../X-PLANE 11/Aircraft/330_JARDesign/_navdata/
and put new cycle to ..X-PLANE 10/Custom Data/navdata/ folder
About serials and activations:
- All beta-testers, who have personal serial from JARDesign may use it with XP11. If problems - please skype me or http://www.support.jardesign.org
- All users who bought the A330 AFTER the X-Plane 11 presentation event (October 2016 and later) may use their serials with X-Plane 11. If problems - please http://www.support.jardesign.org
- All users who bought the A330 BEFORE the X-Plane 11 presentation event (October 2016 and later) may update their serials (get new one) to make it worked with both - XP10 and XP11.
This JARDesign service should help for any users, what have a330 from any shop http://jardesign.org/a330-jd-x-plane-11-update/
Update fee is about $19,95 (not include VAT for your country). Sure, you own a330 for X-Plane 10 and may continue to use it with X-Plane 10 simulator with no problem. No update need in this case. Support is continue.
As you know may be, you may use some my tricks from facebook to take a330 for XP10 and make it loadable with XP11. Please note what some old XP10 features not supported by XP11 more and you will get aircraft with not 100% compatible 3D, perfomance and (after saving with new PlaneMaker) FMGS navigation part.
Please note what this time we have beta of X-Plane 11 and beta of a330 ("beta" - product for testing and may not work well, hare errors and so on). If you need release, need stable version, please wait.
Thank you!!!!
Info BSS:
Guys, Blue Sky Star Simulations A330 sound pack does work with this version, you don't need to change anything, just get the latest version using the same link provided to you when purchased, if purchased from our store. Version name should be 2.01, read the instructions and make a clean install. If bought from X-plane.org, their version must be up to date to. If you have lost the link, or link no longer works, contact amrussinc@gmail.com with proof of purchase (email used at transaction)
Regards, BSS
