Topic: ver 2.7 beta 1,2,3 WIN/MAC 64 bit
ver 2.7 WIN/MAC 64 bit
WHAT NEW:
+ MAC OS Sierra compatible
+ New PW1100G Engines 3D model included (need to select by MCDU MENU)
+ Pause at TOD added (MCDU MENU Page 2)
+ Possible to unlock and then to open cockpit door
+ New cabin ("Sky interior") lighting system
+ New cockpit "Dark cockpit" lightins system (please use "Dark cockpit" option by MCDU MENU)
+ New cockpit manipulator system "mouse wheel control" (need to select by MCDU MENU)
+ New ground equipment set, include new lighting system
+ Working sunshields
+ Cockpit textures and details improved
+ Cockpit Integ.light/light system improved
+ New cockpit and cabine windows set
+ Visual Ice detector added, include icing effect
+ Few bugs fixed
+ Some PFD/ND details changes
+ Wipers operation effect and some rain improvements added
+ New cockpit “reflecting” glass effect added
+ New cabin windows textures added and fixed issue with “missing strobe glass” for cabin view
+ Fixed wrong left wiper handle orientation
+ Fixed wrong “Cold & Dark” Ground power and battery voltage indication
+ New controls for door switch and trimmer handle added
+ Possibility to control Flaps and Speed brake lever by mouse added
+ Some issues with wheel mouse control fixed
+ New ground Handling
- be sure, that you use X-Plane 10.50 (64 bit only, MAC OS Yosemite-to-Sierra or Windows 7-8-10)
FMS NAVDATA Update:
v.2.7 use NavData from ../X-PLANE 10/Custom Data/GNS430/navdata/ folder
- “a320/330 Native format” or (the same in fact)
and put new cycle to ..X-PLANE 10/Custom Data/GNS430/navdata/ folder
Note: If you are using a custom livery and wherein have problems with the mapping of ground equipment, you need to copy "Ground.png" file from the main aircraft "Objects" folder and paste it into the appropriate "Objects" folder of your custom livery with replacement.
DOWNLOAD:
http://jardesign.org/a320/download/inst … V2.7b3.zip
New PaintKit (PW engines included):
http://jardesign.org/a320/download/pain … intkit.zip
—————— "BETA" is version for Beta-testers!!! ———————————
This is beta version for X-Plane 10 64 bit. "Beta" mean what some may work wrong. Please report about wrong thing, but only thing what changed in this beta.
Please not discuss things what are not in "whats new" list. Please post your opinion direct here. When you post some, please follow some rules like this http://jardesign.org/forum/viewtopic.php?id=861
