1 (edited by karterilla 2016-10-08 07:00:56)
Topic: LEMG Malaga and GCLA La Palma
Here the files need for these two spanish airports of Malaga LEMG and Canaria La Palma GCLA.
Had to rework the tdg scenery since the airport is different now: it has only one runway and not 2.
GCLA comes from XP gateway.
Please test them.
Re: LEMG Malaga and GCLA La Palma
I tried both a while, and everything seems to be ok. Thanks so much for your effords. Specially Spanish airports.
Gracias!
Sorry if I've missed it but is there a Las Palmas/Gran Canaria and Tenerife North and South Airports?
Do not know: did you check XL google map or this forum for the APTs you are looking for? If I'm not wrong one of the Tenerife APT is in the official XL map.
I did develop only GCLA (which is La Palma and NOT Las Palmas) a not so easy airport to land at.
The map hasn't been updated for several months and I can't find it so far on this forum so I guess it's not been created yet. Thanks anyway for the reply.
If I find a good scenery package can try to set up XL files for those two.
Cheers
Gran Canaria
http://forums.x-plane.org/index.php?/fi … n-canaria/
Tenerife South
http://forums.x-plane.org/index.php?/fi … ort-spain/
Tenerfie North
Hello early morning today I did develop GCXO based on XP gateway scenery: do you want to test this anyway instead of the link for Tenerife North you have provided?
9 (edited by Sid Star 2016-10-02 08:52:57)
Hi Karterilla, yes of course thanks!
10 (edited by kebs 2016-10-02 09:10:42)
thanks for your job
just a little mistake, dat and txt file in SPJC.zip are named SLLP
I rename all and try SPJC airport, it dont work.
OK will post it toghter with south, based on X gateway packages in a separate post.
Test them.
New version of GCLA La Palma
