Topic: KMCO - Orlando International Airport USA
By Ivan Vetrov for freeware (5 star) KMCO Orlando International Airport
When you start FMCar and/or X-Life next time, KMCO files will be autodownloaded to your /Airports/ folder.
Also, a real frequencies of airport are included to KMCO.txt
As usual I added the 'KMCO - Orlando International Airport Nostatic' scenery.
To remove the existing static aircrafts where it need, please unpack KMCO - Orlando International Airport Nostatic.zip archive to you 'custom scenery' folder. Don't forget what "nostatic" scenery must be located higher then KMCO main scenery in the scenery_packs.ini file. Please don't forget to follow this rule.
