1 (edited by dunbie 2016-08-02 15:37:42)
Topic: LZIB Bratislava
Hi, friends,
I've just finished taxiroutes for amazing LZIB scenery from tdg.
Please, test it, seems it's working well so far...
Dunbie
2 (edited by Watauga 2016-08-04 00:42:12)
Re: LZIB Bratislava
Dunbie,
I tested your LZIB X-Life files.  I flew from LZIB to LOWK.  I received a message that a ground departure route could not be built.
XL: 27 : MessageWhite: LZIB airport is not X-Life verified! Please use menu and check verified airports Map!
XL: 27 : JARDesign plugin: D:\X-Plane 10.45\Resources\plugins\X-Life\Metar/LZIB.TXT file updated.
XL: 27 : MessageGreen: Seems like impossible to build Ground Route from Your Gate/Stand 14 to RW 31
XL: 27 : MessageGreen: Scenery Problem detected.
XL: 27 : MessageGreen: Will try to build route for you from nearest Taxiway point
Taxi instructions stop before route was given.
XL: 642 : ---+++--- ATC: N370EJ, BRATISLAVA Ground, taxi to holding short runway 31, via
While taxing down the taxi way, parallel to runway 31, I notice a UPS jet taxing down runway 13.  At the end of the runway it may a 180 degree turn to the left and took of from the grass, parallel to runway 31.
Complete log.txt attached.
I did notice there is another LZIB dat and txt file by SirOtheOne on page 7.  The original txt file was corrected on March 31, 2016
Hope this helps.
Ron West
