Topic: XLife not available
Hello
I have bought xlife de luxe. Installed as open sceneryX as well. But it doesnt turn up under the plug in menue. How to activate it ? By the way i have no plane from Jar ? Is that a problem ?
Christian
Re: XLife not available
Official guide may help http://jardesign.org/x-life/www/quick-start-guide-2/
Sure, another reason may exist - if so, please follow http://support.jardesign.org/ with your log.txt file just after start X-Plane and load any aircraft.
I have done everything strictly as described under the link, even downloaded EDDM(even though tghis airport was available by xplane already before). If I open xplane, selecting EDDM + a plane, it opens normal, no license page appears and xlife is not showed under plugins(but I see it in the browser under plugins). Xplane doesnt show an error, what do you mean with lopgtext file ?
I suppose this means the log file at the root of X-Plane file ... it is a   .txt document .
It helps for understanting what could go wrong in case of trouble ... and has to be attached when you contact jardesign support .
