Topic: EGGW Luton EGGS Stansted
EGSS Stansted and EGGW Luton airports based on the tdg scenery packages included.
Please test them.
JARDesign Group Board → Custom ATC routes for XP Airports → EGGW Luton EGGS Stansted
Please test them.
On the subject of UK airports, would it be possible please for someone to bring this excellent Newcastle airport by tdg into the world of X-Life?
I'm working on some UK airports, luckily EGNT is among these.
Will post in a separate thread ASAP.
Marvellous!
Please test them.
As usual, these airports work fine .
Thank you for sharing .
In case you plan to develop a few french airports for X-Life ...may I suggest LFOB (Beauvais) the one used by low cost companies such as Ryanair ...
karterilla wrote:EGSS Stansted and EGGW Luton airports based on the tdg scenery packages included.
Please test them.
Thank you for sharing .jcdp
I did have notice your request on the other thread.
I do have a problem in finding any (free) charts for this airpot.
I din't spend so much time looking at it but this morning no way: nor a Jepp chart neither any other one.
Do you have it? If yes post a link. Need aerodrome info. Nor SID STAR charts at least for ground services.
Also the sceneries are not really good: the gateway one (I do prefer to use these pkg's...) is only 2D.
Can try to use this: http://forums.x-plane.org/index.php?/fi … e-airport/
but without aerodrome charts no way.
Even satellite shoots are not good in details: getting closer everything goes blur
jcdp wrote:karterilla wrote:EGSS Stansted and EGGW Luton airports based on the tdg scenery packages included.
Please test them.
jcdpI did have notice your request on the other thread.
I do have a problem in finding any (free) charts for this airpot.I din't spend so much time looking at it but this morning no way: nor a Jepp chart neither any other one.
Do you have it? If yes post a link. Need aerodrome info. Nor SID STAR charts at least for ground services.Also the sceneries are not really good: the gateway one (I do prefer to use these pkg's...) is only 2D.
Thanks for your answer .
The link you propose for the Airport is the right one .
I found a chart on navigraph about runways, gates and location of buildings ... but no link.
I printed the chart and took a picture of it .
See attached files
