Topic: 3 Spanish APTs: LEAL, LEVC, LEZL
Here are 4 Spanish airports for X-Life.
Please test them.
LEAL Alicante
LEVC Valencia
LEZL Sevilla
Scenery packages beside XP gateway ones, are a little bit reworked.
Please test them
JARDesign Group Board → Custom ATC routes for XP Airports → 3 Spanish APTs: LEAL, LEVC, LEZL
Please test them.
LEAL Alicante
LEVC Valencia
LEZL Sevilla
Please test them
Please test them.
LEAL Alicante
LEVC Valencia
LEZL SevillaScenery packages beside XP gateway ones, are a little bit reworked.
Please test them
Hi I installed LEAL folder and the 2 files into XL airport folder. I got error massage that a specific library is missing and that
the airport will not be uploaded. End result an empty airport place.....
(X-Plane 10.50b6, iMac 27, X-life last version)
Yes you need external libraries.
I forgot to include links to the forums-x pages. Sorry for this.
Here are the link to the originals scenery packages.
LEAL: http://forums.x-plane.org/index.php?/fi … ort-spain/
LEVC: http://forums.x-plane.org/index.php?/fi … a-airport/
LEZL: http://forums.x-plane.org/index.php?/fi … e-airport/
LEAL and LEVC are working ok. It seems that LEZL package you uploaded is not the same of the link you put today. I had Seville airport made by TDG and the files are not the same you uploaded. Maybe you used the XP gateway instead?
Tnx a lot for your work.
X-Plane 10.50b6, PC, X-life last version
Try this.
It uses only OpenSceneryX and custom objects included.
Anyway I reload the pkg.
Seems to me this it is not a tdg scenery but it is not a gateway one either.
Thanks to test: more LE** APTs to come (LERL LELA LEIU LECI LEBZ LEAT need a little bit of time. All gateway ones but I did not already check if they are already on this repository, check them).
Try this.
Seems to me this it is not a tdg scenery but it is not a gateway one either.Thanks to test: more LE** APTs to come (LERL LELA LEIU LECI LEBZ LEAT need a little bit of time. All gateway ones but I did not already check if they are already on this repository, check them).
Tnx karterilla, but I think I´ll keep TDG scenery because its more detailed. I think its important to use always the best scenery possible for X-Life, an TDG does a great job, better than gateway ones.
Tnx for all LE**, present and future.
