Topic: LPPT Lisboa and LPPR Porto X-Life APTs
Here X-Life Lisboa LPPT and Porto LPPR airports based on XP gateway scenery packages (reworked to add more gates).
The scenery are part of the zip file.
Please test them.
JARDesign Group Board → Custom ATC routes for XP Airports → LPPT Lisboa and LPPR Porto X-Life APTs
Please test them.
Here the corrected LPPT Lisboa set.
Deleted gates conflicting with static planes.
The scenery are part of the zip file.Please test them.
In Portugal unzipped I found a file LPPR.txt and one LPRR.dat ....normal?
karterilla wrote:Here X-Life Lisboa LPPT and Porto LPPR airports based on XP gateway scenery packages (reworked to add more gates).
Hello I've add to this a zip of the 2 APTs: should contain 2 zip files with the modded XP gateway scenery packages and 2 files for each airport: LPPR.txt and .dat and LPPT.txt and .dat
Let me know.
I've tried to re-open this one with WinRAR and the zip contains 6 files. Seems to me the zip it is OK.
jcdp wrote:karterilla wrote:Here X-Life Lisboa LPPT and Porto LPPR airports based on XP gateway scenery packages (reworked to add more gates).
jcdpHello I've add to this a zip of the 2 APTs: should contain 2 zip files with the modded XP gateway scenery packages and 2 files for each airport: LPPR.txt and .dat and LPPT.txt and .dat
Let me know.
Yes there are 6 files ...but for Files used for X-Life there are two with a different name :
I mean instead of having "Airport.dat" and "Airport.txt" we have LP P R.txt and LP R R.dat
I mean two different names for Airport.
PS
Is it only a mistype?
karterilla wrote:jcdp wrote:Hi
Let me know.
I've tried to re-open this one with WinRAR and the zip contains 6 files. Seems to me the zip it is OK.Hello
Yes there are 6 files ...but for Files used for X-Life there are two with a different name :I mean instead of having "Airport.dat" and "Airport.txt" we have LP P R.txt and LP R R.dat
PS
Yes it is.
Thanx this is the correct file for Porto airpots for X-Life
jcdp wrote:karterilla wrote:Hello I've add to this a zip of the 2 APTs: should contain 2 zip files with the modded XP gateway scenery packages and 2 files for each airport: LPPR.txt and .dat and LPPT.txt and .dat
Let me know.
PS
Is it only a mistype?Yes it is.
Thanks for your follow up and for sharing your work
hi karterilla,
in LPPR there were any bug and wrong routes. I have corrected this issues.
Please, work accurate and insert all possible stand/gates.
ps:
1. make as less nodes as possible, make taxi routes on outline tangents and not in the middle of marklines, insert pocket turns on rwy end, if possible.
2. in gate editor make correct params
greetings Mike
Let me know.
PS
SirOTheOne thanks for the info, hints and rework.
In LPPR XP gateway scenery there are around 10 static planes already at the stands. Did you already check to esclude (there is a way in X-life to mark stand already busy?) overlaps? I cannot check the files right now.
I'm working on some spanish APTs and for example in LEVC there are many many GA stands (even in the gateway scenery): these are really needed for a simulation where besides a certain number of planes cannot be handled? I've tried to leave them there but even using GA planes they are too many e too close...
Also charts sometime gives stands/gates position with only few decimal digits (and so they overlap or are too close in XP) or group stands together.
I'm using also Google Earth or flightradar24 satellite maps to position stands (which frequently differs from charts coordinates).
I do also sometime prefer to leave for XP Gateway scenery their taxi routes (when they are present): these are "sponsored" by XP itself it is correct to modify them?
Anyway thank you.
