Topic: Request for KRSW
I would like to request KRSW (found here http://store.x-plane.org/KRSW--Southwes … _436.html) if anyone is able to do it.
Thank you for your consideration.
JARDesign Group Board → Custom ATC routes for XP Airports → Request for KRSW
I second this request, this is a sorely overlooked airport that has some great approaches over southern Florida.
The problem is paying the $25 to start the operation
Here's a first go at KRSW (I also love this airport) -- it should have all the gates + cargo / FBO area spots from the scenery.
This set assumes you are not using any static aircraft from the scenery (the optional Earth nav data folder)
I haven't done anything with the north apron though. I couldn't find pictures / depictions of any sort to figure out if it's in use and if so how things are oriented, etc...
Feel free to suggest / modify!
Thank you so much!!!!!!!
