Topic: KJAX ATC routes registration
The process of adding airports to xlife is a little difficult. I am about 1/2 way through working on my version of KJAX and just having completed the ATC layout, would like to have the airport be recognized by xlife. Is sending the .dat file plus the airport picture the only way?
I have not released the airport yet, do you require a copy of that too?
One last inquire, can I produce the .dat and .txt myself or does it have to be processed by you only?
Thanks for the help.
Re: KJAX ATC routes registration
If you use WED then you go to Export APT and create the "your ICAO".DAT   Once you test it in x-life you can use the gateeditor to create the txt file. There is a good vid of jar which you can watch to see how it is done
PPL holder, 4790k+gtx1070+32gb , win10
Thank you.
quick question, where is the gate editor and do you know the name of the video?
