1 (edited by MasterTRL 2016-05-19 10:22:30)
Topic: LESB - Aeródromo de Son Bonet (on Mallorca)
These are the ATC Routes for the freeware LESB, included in the Mallorca scenery pack.
http://www.helgo11335.de/     <--  You can download the Scenery here!
http://jardesign.org/forum/img/m/2594/t/p1aj48f1rl1mnn14bpu3359n8q13.png
The LESB.dat has all the available stands and gates.
The LESB.txt.static has the stands and gates with static objects set to Static. (remove the .static for usage)
The LESB.txt has all stands and gates set to active. (use only with "AAA_LEMH_No_Static")
The AAA_LESB_No_Static.zip contains the files for removing parked static aircraft and maybe some equipment that was in the way. (unpack the folder "AAA_LESB_No_Static"into your "custom scenery" folder and make sure that it is located ABOVE the actual LEMH scenery inside the scenery_packs.ini)
A big thanks goes to vatech for helping me with the tricky runway!
Of course, if you find any mistakes or if you have suggestions on how to make the layout better, feel free to tell me.
Cheers
Chris
