Topic: LEBL - Barcelona EL PRAT
ATC routes for the freeware scenery: http://forums.x-plane.org/index.php?/fi … t-airport/
Tested as much as possible.
JARDesign Group Board → Custom ATC routes for XP Airports → LEBL - Barcelona EL PRAT
thanks you for uploading this! I've been using it with the payware version of LEBL from DAI-MEDIA and so far seems to work well also (with static objects off)
thanks!
Glad to hear...probably both sceneries have the same coordinates for parks and taxis. In other cases there are small or big differences from a scenery to another.
I´m using the Dai Media scenery of Barcelona... how can I select "static objects off"?
How many aircrafts can you see with X-life in LEBL?
Many thanks
thanks!
thanks!
Hi, I've tried it but it doesn't work well. Althought the program runs (with the non validated message) it does not generate traffic or allow to generate flight plans, so the ATC included does not work also.
It works well for me, more than 10 flights and all is going well, fm car included.
With last scenery version and X-plane 10.45?
Wow! I don't understand it. FM car it seems to work fine. I see the map correctly ... but i can't load traffic at LEBL or fill a flight plan...
Can mesh scenery affect? I have Spain UHD installed...
Capto wrote:It works well for me, more than 10 flights and all is going well, fm car included.
I've the same problem with LIRP..other user can see the traffic generate with my LIRP.dat but in my PC i can see nothing. Maybe the problem is related to the navigation data that x-life read!!!
I made it work at last!
I switched off all the pluggins and scenarios less airport and X.life... Then progressively switched on again and test...
I founded it was SpainUHD. I disabled the cell, and switch all the rest again... and 'voilà'!! it works nice!
Gubben wrote:Capto wrote:It works well for me, more than 10 flights and all is going well, fm car included.
HOW DO I INSTALL? WHAT FOLDERS DO I PUT THEM IN>
THANKS SO MUCH!!!
Put the ICAO.dat file into the
.../[X-Plane]/Resources/plugins/XLife/Airports/
folder and also into the
.../[X-Plane]/Resources/plugins/FMcar/airports/
folder (if you have FMcar installed)
