Topic: Tugmaster crashes X-Plane with IXEG 737
Hi All,
When using tugmaster deluxe with the IXEG 737 I cannot pause the sim or watch a replay. Both these scenarios cause X-Plane to freeze and crash. I disabled tugmaster and all works as it should do.
Has this been identified before? Is there a newer version of the plugin?
Richard
Re: Tugmaster crashes X-Plane with IXEG 737
this is really weird. If you use Tugmaster in combination with the IXEG and pause the sim, a windows CMD window opens.
I have never seen this before. Would be very nice if these two Add-Ons would work together.
Greetings,
Sebastian
Greetings,
Sebastian
That is exactly what I get. I press any key as the CMD window says to do but more just open. I have disabled this plugin for the time being which is a shame
Same for me... And I liked it so much...
Greetings,
Sebastian
Ditto all the above. Pity, hopefully it can be fixed
