Topic: Ground Hanling Screwing IXEG 733 Sounds
I just bought the IXEG 737-300 plane,
I had an issue with it as some sounds where missing, not playing at all, (radio altimeter, GPWS, Some buttons and the Mach Clicker)
I was asked by their support team to remove plygins to see if that was not a conflict.
It seems that the issue was with Ground Handling.
I do not own the "deluxe" version but I have A JARDesign A330 (including the normal version of Ground handling which works only with A330).
It Seems the last GHD version you issued corrects the conflict with IXEG but, the version in the A330 has not been updated to my knowledge. ( I have A330 1.2r3)
Will you issue an updated version of ground Handling for the A330 As well ?
Re: Ground Hanling Screwing IXEG 733 Sounds
Hi, i just saw the other topic, will download the update sorry for Double post.
