1 (edited by Kenom87 2016-04-26 04:21:05)
Topic: problem with x-life ATC please help!!
Hello there, the problem that I have is when I filling my flight plan to use x-life ATC x-life tells me "Depart airport not x-life compatible' and I do not understand why. I can see the traffic, aircraft taking off, landing and taxiing using my custom ATC taxi routes and everything works good but when I try to use the ATC x-life keep saying "depart airport not x-life compatible" and is just with this airport MDPC because when I use TJSJ with my custom ATC taxi routes ATC works perfectly, someone has any idea what is happening?
Thanks for your help guys.
Re: problem with x-life ATC please help!!
It means that your airport is not listed in the approved airports but you can still use it without a problem. Your airport has to be approved and listed by JAR developers/testers in the Airports folder for you to not see that message.
3 (edited by Kenom87 2016-04-26 13:41:24)
Ok I understand what are you saying but I don't think that's the reason because it says "Depart airport not compatible with X-Life" in the FlightPlan Window,  the other airport that I use TJSJ it's not approved neither, but works perfectly with x-life ATC, got to be something else that I missing.
