1 (edited by vatech 2016-04-19 16:42:32)
Topic: KRIC - Richmond Intl USA
For freeware (5 star) KRIC - Richmond International airport.
http://forums.x-plane.org/index.php?/fi … romLogin=1
http://jardesign.org/forum/img/m/2234/t/p1agnm2atd89b15kr7m11ckh31i3.jpg
http://jardesign.org/forum/img/m/2234/t/p1agnm2ho81jdv2b516ac1ejai925.jpg
When you start FMCar and/or X-Life next time, KRIC files will be autodownloaded to your /Airports/ folder.
Also, a real frequencies of airport are included to KRIC.txt
As usual I added the 'KRIC - Richmond International Airport Nostatic' scenery.
To remove the existing static aircrafts where it need, please install "KRIC - Richmond International Airport Nostatic" scenery to you 'custom scenery' folder. Don't forget what "nostatic scenery" must be located higher then KRIC main scenery in the scenery_packs.ini file. Please don't forget to follow this rule.
Attachment icon KRIC - Richmond International Airport Nostatic.zip 2.14 kb, 465 downloads since 2016-04-19
2 (edited by laohu314 2016-05-21 05:24:28)
Re: KRIC - Richmond Intl USA
Even though the KRIC Nostatic loads before the main airport I still see all the static aircraft. Why is that?
3 (edited by captbullett 2016-05-21 03:47:30)
no log.txt no help .int files can't be opened on other peoples computers ! it can cause Malware and computer security will not allow this .int file to be opened on any other computer but yours.
your scenery order will be on the log.txt and we can tell from there what to do this is why we ask for the log.txt it provides all the details a developer need to diagnose anything that X-Plane or X-Life has wrong with it.
4 (edited by laohu314 2016-05-21 05:31:18)
It's a text file. If you worry about the .ini just rename it to .txt but I can do that for you, too
The log file doesn't tell anything more.
It's not a XL issue. It's about how the NO_Static version of the airport works (or not). Presumably, the exclusion zones over the static AC block them out but not for me and I was wondering why that could be and if anyone else had seen this.
5 (edited by captbullett 2016-05-21 14:44:36)
yes, I am wanting to help you because, once and a while it takes a try or two to get the pack in the right order for them to work on the Mac but where is it in relation to the KSEA Demo it should be i do believe below the KSEA and the KSEA Demo pack.
so I did not need to look at you int file I just need ed to talk you through the process.
and most of the files that have the aircraft exclusions need to be below the KSEA Demo scenery pack for X-Life.
Ps, everything above your SCENERY_PACK Custom Scenery/Aerosoft - EBBR Brussels/
needs to be put in to order you have 'DD files that should be at the bottom of the list just above your  zz files
Now that I have seen you .int file this si what I want you to do .
1) Take your old .int file and put in in a file and label it old .int file put it on your desk-top.
2) Re-start X-Plane and let the X-Plane App re-build the .int file and then see if you get the Aircraft exclusions to work.
3) if it still did not work then take a look at the new file and make sure the exclusions were re-built under the KSEA demo airport and move to the place in the list that make sense to you.
4) if the int file is working then leave it alone and let the x-plane  work the int file.
also I numbered the way the KSFO should be in order in the int file this is a must for KSFO to work right  have you had issues .
5)SCENERY_PACK Custom Scenery/KSFO - SanFrancisco V2.01/
1)SCENERY_PACK Custom Scenery/KSFO - San Francisco Cable Cars/
2)SCENERY_PACK Custom Scenery/KSFO - San Francisco Nostatic/
3)SCENERY_PACK Custom Scenery/KSFO - Traffic Golden Gate Bridge/
4)SCENERY_PACK Custom Scenery/KSFO - Traffic Oakland Bay Bridge/
I know you have re-built the int file but then added several airports that have compiled onto of the Aerosoft airports there should never be any thing on top of the Aerosoft airports as a rule of thumb.
standing by to assist if needed,
6 (edited by laohu314 2016-05-21 23:44:17)
Thanks captbullet!
I figured out the issue with KRIC. It was an extra folder level in the No-statc folder. Works now.
Regarding the other suggestions, very much appreciated. I never quite know what the order should be.
Regarding KSFO, shouldn't the No-static be on top so it masks the aircraft in SF v2.01?
Thanks captbullet!
but below the cablecars and there is one you are missing it is the aircraft flying i just have to change computers again to find the name of the folder.
Thanks captbullet!
I see, thank you!
