Topic: LEGE JustSim Girona Costa Brava
For payware JustSim Girona Costa brava
http://store.x-plane.org/LEGE--Girona-C … p_468.html
http://jardesign.org/forum/img/m/2215/t/p1aghlv4t21d1bb974gj1djq168e3.jpg
There is two difficult parking 9 and 10 for traffic. I made a little cheat for it. Taxi ways are not the same like in scenery.
2 (edited by vatech 2016-04-17 13:53:38)
Re: LEGE JustSim Girona Costa Brava
Hi!
ATC Route for LEGE by JustSim will be added to X-Life server 18/04/2016. I'm working on it now. If you look at x-life map you will see it with white star. White star means that ATC Route for this airport in developement by JAR crew.
https://www.google.com/maps/d/viewer?mi … ecn3NB3GZ8
vatech wrote:
Hi!
Regarding airports in development
What would it take to get KBOS on the map, please?
http://jardesign.org/forum/viewtopic.php?id=1884
If there is a problem with it, please let me know so I can fix it.
Many thanks!
Many thanks!
Hi!
You can contact to J.A.Romanov with this question. I'm only createing ATC Routes for X-Life. But He adds files to server. You can ask him to do so.
Ok.
So if I release my new airport I need wait when you create ATC by youself? And when to warn you that you have begun to do routes?
Why I still see a red line after traffic start. "(ICAO) airport not aproved by X-Life bla-bla... please see map" ?
6 (edited by vatech 2016-04-17 23:52:28)
rudeboy1988 wrote:
Ok.
Hi!
If you wish to create ATC Route for any airports it's your right. You can use it, or you can share it with someone. But I recommend you do not waste your time for Airports that present with white star on X-Life map, because all airports on map approved and checked by "JAR Design" crew, and only after check and edit this airports will placed on X-Life server. Every time you start X-plane, X-Life traffic connects to server for check the state of updates and new files. This is the reason why you see the red line, because your ATC Route files are absent on server, or do not match with files in your 'resources/plugins/x-life/airports' folder for the same airport on server. (If shorter, files in yor plugin do not match with files on server)
As I said, I just recommends you to look at X-Life map before you decide to do some airport, to avoid such situation, when you createing airport that will be created by JAR crew. But if you created really good and qualitive  ATC Route for airport, we can add you ATC Route on X-Life Server.
P.S.
Besides. I see a mistake at your screenshot for LEGE. Your holding points for runway entry will be not work properly.
Many thanks!
Hi!
OK Thanks!
OK Thanks!
Don't mension it.
9 (edited by rudeboy1988 2016-04-18 09:54:28)
vatech wrote:
rudeboy1988 wrote:
Ok.
Hi!
P.S.
Ok. Thanks!
