Topic: You Should Turn on Traffic Before message - GRRRR
Hello Gang!
I am at wits end with X-Life so far.  Every time I launch X-Plane and X-File, I first turn on traffic, then once loaded (or what appears to have been loaded), whenever I click on flightplan, I get the message that says "You Should Turn on Traffic Before"...........even though traffic is on.  I have not been succesful at seeing any traffic at any airport so far.  I do have the OpenSceneryX library loaded.
Any ideas?
Is there a manual somewhere?
Dennis
Re: You Should Turn on Traffic Before message - GRRRR
DMullert wrote:
Hello Gang!
Any ideas?
Dennis
Hi Dennis,
Are you at an airport with ATC Taxi Routes?
Please post log.txt, then someone can help
3 (edited by DMullert 2016-04-12 02:10:48)
Thank You for your reply.
Yes, I am.  KMIA, KDFW, and KATL are the airports I have tried so far and these are all included in the default installation (At least I see them in the airports directory).  Attached is my Log file.
Thanks again for your response.
Dennis
