Topic: EFVA Vaasa Airport
By Dino1981, for NEXTXDSTN payware scenery.
http://secure.simmarket.com/nextdstn-va … xp10.phtml
JARDesign Group Board → Custom ATC routes for XP Airports → EFVA Vaasa Airport
How do you install these. I have copied the files the proper directory and added the entries to the airports.txt file, when I start xplane, the entries are removed.
1. be sure to have the payware scenery for EFVA
2. simply copy both files (EFVA.dat and EFVA.txt) to your "Resources/Plugins/X-Life/Airports" folder
3. there is no need to add something to an airport.txt file
4. I use X-Life-Deluxe version (should not be necessary)
