701
TKurzweg wrote:
Upload of X-Life Beta 9.3 was corrupted....start a new download for working !!!!
Yes. It is so. Now whitout problem - so far. Sound is good :-))
702 (edited by ilankrt 2016-03-26 12:46:07)
Question to JAR before I am going on testing v. 09.3.
I already purchased and installed  SoundMaxx  to have airport background traffic sound.
Can you tell me about a possible conflict with your traffic sound?
703
Hi JAR,
I've just downloaded the new Beta version 9.3 (latest download) but I'm not able to re-register it.
I still getting the same error:
EMAIL ERROR! PLEASE REGISTER AGAIN WITH EMAIL WHAT WAS USED FOR FIRST REGISTRATION!
I'm using the one and only ever used.
Please help.
704 (edited by ThommiTechnik 2016-03-26 16:40:16)
X-Plane 10.45, OS X 10.11.4, X-Life b9.3 - CTD when activating Traffic. Even with all other plugins disabled.
705
Nice flight.
Everything worked as expected.
Aerosoft EGLL to MG Sceneries LYBE
Rotate MD80
Flight plan attached (AIRAC1603).
I uploaded LYBE.dat and LYBE.txt on relevant forum.
Attachment icon EGLLLYBE.txt 136 b, 317 downloads since 2016-03-26
706
Is this happen every time when you load at this airport, please?
707
macastura wrote:
Hi JAR,
Please help.
Please contact support with your serial - we will solve this anyway.
708
I hope no, but anyway need check. X-Life sounds should work correct and independent.
709
Yes, it is. Will try another one. Give you feedback in a couple of minutes
710
LIRF is working, no CTD. No working on getting traffic wink
What I'm getting good: ATC window can be hided smile
711
My first problem with b9.3X-Plane freezes when launching X-Live. Still message - Loaded .... Please wait!
Best Regards
712
Test new v.09.3 parking and view traffik at UUEE
No crash
New sound is a huge step forward, works great. From inside I can hear aircraft passing by. Outside traffic sound, take-off and landing sound as aircraft are coming near - great.
Traffic seems to be better organized.
Pushback is now much better programated.
Now on a test flight from UMMS to UUEE.
Btw SoundMaxx seems to work well with XL, until now no conflict
Thanks JAR for your work (and quick answer ✌)
713
I see good improvements! smile
BUT: At LIRF my PC12 was routed over TW D. So far so good, makes sense. And when I was taxiing into D, I stood in front of a Airbus A320! Can you imagine the both faces, of Cpt. in A320 and me? wink
Also: I had to cross RW 07 over A. No short holding?! No permission of Tower to cross?!
714 (edited by captbullett 2016-03-26 19:20:11)
Don't get me wrong, I don't want to offend, appreciate the work, to make ATC better and better in XPL. At this moment two people are working on it (and I think, Austin too wink ).
Today I will test X-Life under VFR circumstances. Required message points, Altitudes, Restricted airspace's, and so on. Will report later, or tomorrow. Looks like most are testing with aircrafts. But VFR ist the leading activity of ATC, especially on small airports. Here I see the challenge for X-Life.
What I don't like, makes me angry:
• praising, fellowing, when people are also reporting bugs, criticizing. This is also part of tests.
• no reacting from devs (either on bugs/inputs of planes or plug-ins)
Cheers
What Developer needs from Beta tester is only Data on plugin, is what is needed, not the other way around (Beta tester does not need to know how the plug in works in detail you are just testing.)
Second, the data as before is log.txt bbox.txt and a good summery of any data you can add to the simulation instead of a complaint on the plugin on how good or bad it works we know how good and bad it works already!
Finally, Developer is too busy to answer everyone of your post and everyone of post on the website, I would not expect him to he does see what is going on and does know how to solve any issue without having to contact you directly most of the time.
Thank-you for your help,
Test flight v.09.3 UMMS - UUEE, A330, iMac
no crash
UMMS: traffic OK, taxi way and followMe car as it should be. BTW very good made scenery....
UUEE: Great scenery worth paid money. I only wish to be advised to taxi (ATC advice) to a parking lot at the main terminal
and not on an empty parking place. TT mentioned crossing RWYs, well this is indeed a problem to solve. Crossing RWYs of UUEE
was uncontrolled and in one case I could see only on radar an aircraft ready for take-off.
As I wrote already sound is great....
I hope that the prepared airport network will keep growing fast. I saw that talent user are working on it and we have
to thank them for their investment.
716 (edited by laohu314 2016-03-26 22:16:12)
Did EGLL to EDDM in A330 and XL b9.3. All went well except for a little kink in the flight plan (this was seen by others before on various routes).
http://jardesign.org/forum/img/m/1944/t/p1aeqfi4v3144h12ck1v3n12d31bkd3.png
I just did a direct from BETOS to BEGEN and all went well.
Also noticed that FM car is activated rather late after landing. Would be great if that went faster but maybe thats just due to my dismal FPS.
XL is becoming really awesome!
717
Flight from EIDW to EGLL.  Flight plan generated by XL is still incorrect (I know that's low priority).  I imported the flight plan from the FMC and that worked very well.
Couple of issues I noticed.  On approach to EGLL, another plane was very close to me (just in front of me on finals).  I was about 1nm out when I got the instruction to GA.  Is there any way to prevent this happening?  Perhaps an instruction to hold or for AI aircraft no to do this when you are given clearance for landing?
Another minor issue was with an ATC instruction.  When an aircraft is in front at holding point it says "Aircraft the in front of you".  "The" should be removed leaving "Aircraft in front of you".
http://jardesign.org/forum/img/m/683/t/p1aeqihbnv1v1n5i6l5d17eujnv3.jpg
Otherwise this is coming together very nicely.  Great work Eugeny.  Especially like the sound form the AI aircraft.
718
Thanks! This useful. All this should be improve.
719
I've been using x-life with deluxe options for a while (just at EDDM airport for now).. and its really great!
I hope this converts into the standard for AI and ATC in x-plane. Adds so much to the sim experience. smile
Just two things:
1) I have traffic density at max, but it its not near to a "big" airport traffic density. Is this restricted on purpose?
2) Didn't see any 737 / 747 / a320 / a330 / a318/19, etc of the standard airliners.. will this be added when beta finish?
Hallo JAR
Some user wrote me after they saw my blog post and videos about XL and asked for an explanation about
the adjustments. Can you made a short explanation about all parameters , and what are the limits or restrictions
in Beta stage. (It is also important for us beta tester to know about exactly)
721
And the next one: EDDM - X-Life initializes OK, I'm typing in route, going to load .txt for route -> CTD. ReStart of XPL, same airport, same route into Garmin 530, trying to take generated route from plugin -> CTD
XPL 10.45, MacOS X 10.11.4
722 (edited by ThommiTechnik 2016-03-27 15:08:35)
For my understanding: are you taking the Data from /Custom Data/GNS430?
And where can I find the crash dump of X-Life on Mac?
723
One one flight to EIDW I got to GA twice! The second time I had to navigate in selected mode and land the baby (A330) manually because the nav data for EIDW had a glitch and only gave me a RNAV approach. The passengers were relieved when we finally touched down. smile
724
When you CTD on the Mac you should automatically get a window with the crash dump that you can send to Apple. Before sending to Apple, copy the entire text into a new text file and save, then post here, please.
725 (edited by ThommiTechnik 2016-03-27 15:56:37)
Aaaahhhhhh, OK, thanks! Do it next time. Now I'm enroute wink Without X-Life wink
