626
Yes, there are airports that are work in progress and just have not been approved and gone through the final steps like KLAX, KSNA, and KBOS just to name a few  the airport that I was posting about CYXC is not being worked on is it?
I'm working on it to get traffic....
it is in the development of the taxi-way in the beginning of the development and this is why you are getting the CTD's!
Sorry, the airport has no CTD. It never had !! Also EDNY, EDLW have no CTD, even when running for hours. And they never had !
CYXC has no  outgoing traffic at the moment, and I don't know why. It has incoming traffic, but no plane wants
to leave.....
627 (edited by letec 2016-03-21 19:34:27)
letec wrote:
thomas_99  CYXC  is not on the X-Life airport list on the map.
this is why you have a CTD,
Interesing. I have only message in red letters "XXX airport is not verified X-Live! Please use menu and" ..... etc, etc and I have this message for more than 20 airports , but whitout CTD or other problem.
Yes, there are airports that are work in progress and just have not been approved and gone through the final steps like KLAX, KSNA, and KBOS just to name a few  the airport that I was posting about CYXC is not being worked on is it? if it is then I stand corrected and i see it is on the list so there but right here is the issue; at this link ; http://jardesign.org/forum/viewtopic.php?id=1825
I am having trouble sorting out my taxiroutes to make my freeware scenery CYXC x-life compatible would someone be able to help me out.
My scenery is at the following link:
http://forums.x-plane.org/index.php?app … mentsStart
I will attach the .dat and .txt files to this post.
I see static planes when I load x-life but nothing happens with the planes they never move and there are no planes landing or taking off.
Any help greatfully received.
Not this at  airports what you say. These are my airports with my  ATC lines. I do not really know why I should my  ATC lines from my simulator to send to " some  map" That's my business what I do in the simulator !!!
628
Metallist wrote:
Good night.
Plugin Version 9.2
Fly on the route ULLI - UUEE. Set in Sheremetyevo STAR LTB06A on the 06 runway and ILS approach runway 24L.
Полет по маршруту ULLI - UUEE. Заход в Шереметьево назначен STAR LTB06A на 06 ВПП, а заход ILS дан на 24L.
Понял, спасибо за лог! Thanks!
629
I just saw the news about the aircraft that went down in Russia and I want to extend my best wishes to the Russian people in there sad time god be with you.
Yes, this is sad me.
630
Well, I've installed KSFO for testing and it works. Also there is no other airport around....
Must be something special which prevents traffic..... It's not the deluxe version, it shows the same
behaviour.....
I'll make some tests.....
Chaps wrote:
Hi thomas_99
I have CYQM, CYFC and CYSJ ( Moncton, Fredericton and Saint John , NB ) done using the beta 9.1 version ( I have tried several times to buy the Deluxe version but for some reason, am unable to ) So far, I have only been able to get one aircraft at each airport to arrive ( don't know from where) , that parks correctly at a gate. wait a long time but never did I see another one arrive.
I have had only one aircraft depart from the gate , take the wrong taxiway but did get to the correct runway hold point and stayed there until I shut down X-Plane, probably 45 mins later
I don't know if the deluxe version works any better but  the beta still needs some work I think.
Hi Jar,
what is the maximum distance between 2 x-life compatible airports ?
I've looked why CYXC has no traffic, and after fixing some problems I think is's ok
now, no errors/warnings.
But no traffic. Nothing.
I think that the problem is that I do not have any other airport installed in canada/usa which is
x-life compatible.
Is there a maximum range between 2 airports, and do I need at minimum 2 airports to get traffic ?
I hope will be better. A mothh ago there was 3 (THREE) airports only. I think/sure the map will be huge!
631
CTD while trying to generate a route and sending it to ATC.
Please post (attach) x-life.dmp file!
632
Stefan wrote:
Hi JAR,
I did a short test of X-Life. So far it worked good with my PC setup. And I think this plugin has a very high potential. A few things I would suggest:
  • Avoid X-Life aircraft overlay static aircraft of the scenery (e.g. EDDN scenery). Or use only scenery without static aircraft.
  • Make the ATC giving acoustic commands via COM radios with the corresponding frequencies.
  • Also, some basic interaction with ATC, like requesting change of FL, would be a real improvement for X-Plane.
If you could realise this, I would pay good money for your plugin.
Yes, thats all my dream too!
633
pic wrote:
Here's a latest with the new plugin win file.
LSFM-LIRF
I noticed the skies were not populated at LFMN, and the runway at LIRF suggested by x-life ATC is not ILS, nor a runway for large planes I believe. I just ignored and went to 16 instead of 7. Skyies were populated there!
Other than that, GREAT!
thanks for log and dump
634
Test flight EDDM - LOWG
crash during approach
RWy 17C has no ILS - false declaration
I recognized crash always after "Sound Play" What does it mean?
Wired is also that X-Plane ATC announces with test and voice also XL ATC ? Is it advisedly programmed ?
That was aircraft log, not from XL. Thanks for log!
635
If this is true, that's absolutely crazy.  I understand having a list of 'approved' airports, but for the plugin to fail when using another is a serious bug.  As long as the taxi network is setup correctly, there should be no reason why everything won't work.
Also, does anyone have any ideas about the plugin not being able to select a departure runway?  I still haven't heard anything about it  sad
I'm happy to include / test whatever I need to, but I'm out of ideas and need some guidance smile
http://www.jardesign.org/ticket/kb/faq.php?id=51
636
pic wrote:
In the beginning of the beta, I had no problem going from LFMN (in X-Life) to LEBL (NOT in X-Life).  I'd get all the takeoff and Flight plan info, but when landing at LEBL, I was on my own,,,there were CTD's if I asked/interacted with ATC,FM car etc.
So I guess it's a bug within a bug sorta thang. But this is why we have beta testing! And this is why JAR Beta testers are actually the BEST Beta testers working here and on x-plane!
Thanks to Mr R of course!
In the meanwhile, we just keep keeping on and reporting, and eventually we amass many goals, one of which is just that one.
Thanks again Evgeny for a beautiful piece of work.
Merci, Grazi, Спасибо
di Luigi
Merci smile This is the best beta-crew ever!
637
Hi Eugeny,
I hope that you saw my video. I forgot to copy log.txt..
This "loop" happened again and again until I went back (using Time Machine) to the last version of a successful
A330 flight (18.03) and installed at that time available XL 09.1 - Now I can fly (at least one successful flight I made today)
It seems that 09.2 has affected my A330 configuration...
Test Flight EDDM - LOWG no crash
but as often RWY 17C GNSS was declared as ILS !
to readback "when ILS alined" makes no sense, so ATC became useless....
Ye, I saw video and know what happen. Hmm.. all i need - try to get the same at my computer. I will try, but.. not sure. Thanks for info, anyway!
638
cram wrote:
Hi, one question...
There any way to choose the airlines that want to appear according to the airport?
For example LEMD, Iberia is the largest company
This time - not. I will start add features after release. Now - it is time to make XL stable and sounded.
639
JAR, I don't mean to be rude, but every time I mention this problem someone just posts a link to the video describing how to make an ATC taxi route.  I know how to make an X-life compatible route, and have posted several large airports that work correctly.  I don't need a link to a video, I need to understand why the traffic isn't working at the airports I have created recently.
If I'm doing something wrong, I'd love to know so I can correct it.  If there's a problem with the plugin, I want to help solve it.  I don't need yet another link to the taxi network FAQ / video.
Please let me know what I can do to help troubleshoot this issue - I really want to help make this even better!!
Thanks,
Evan
640
The problem is that the plugin can't decide which runway to use for departure.  It alternates between two different runways very very quickly.  I've tested is using real weather, CAVOK weather, and a manually set weather that is clearly favoring one of the runways.  Always the plugin isn't able to choose a departure.
Thanks, and please let me know how else I can be of help!
641
Metallist wrote:
Good night.
Plugin Version 9.2
What aircraft did you fly with?
642
Hi Eugeny,
Awaiting your answer ......
643 (edited by captbullett 2016-03-22 11:15:13)
Chaps wrote:
@Captbullett What are the 'certain parts' that are supposed to cause a crash?
here is the map of the airports that are approved and if it is not on the list you will have a CTD if you try to use certain parts of X-Life.
Sorry, but this is complete bullshit....
even a braindead programmer would not do that :-)
I have been Beta testing since the start and how long have you been at this.
next this is a FREE plugin if you do not like something you are not being forced to use it.
then, NO log.txt no bbox.txt or any other data to support you CTD to another issue from now on no support if you can't follow directions then and this is not up for debate you just do not get support .
and using foul language I think should get you banned after one warning now since if you did this on X-Plane you would have a 3 month time out!
Apple Developer
X-Life Beta Tester
Ps the answer to you question is we need data and the above mentioned data logs to track the code that is causing the CTD's and with out the log.txt from everyone and the bbox.txt and the other data the JAR asks us to provide is necessary for him to debug the code and that is that and the only the that anyone here really need to know is;
1) send the data "."
2) send the data "."
3) send the data "."
644 (edited by captbullett 2016-03-22 12:07:19)
OK,
ONE MORE TIME NOW
READ THIS THREE TIME TILL IT SINKS IN AND THEN READ IT AGAIN.
BECAUSE I DO NOT WANT TO HERE THE WINING,
Please note, what the airports that are present on the X-Life map (https://www.google.com/maps/d/viewer?mi … ecn3NB3GZ8) created with consultation of JAR Group and will be automatically downloaded to this folders from server, when your plugin starts first time. If new airport will be added to map, it also will be downloaded when plugin will start
then these airports work any others you might have issues with if you try to run X-Plane and the Flight Plan part of the X-Life Plugin since, the X-Life plugin is not recognizing the data from the airport in the navigation part of the program.
and most of this as testers you do not even need to know all we want you to do is Test the product and report your findings by sending you log.txt and bbox.txt (for those who are flying JAR aircraft) and any apple Problem reports from CTD's "." and then the reports in detail is that hard I do not think so when the plugin is free.
I'm trying DEMO airports (EDDM to LOWW) and I can't se dexlue features (i.e. radar map). Are dexule features disabled
even in demo airports ?
646
Deluxe features are not disabled. Not in the demo airports nor in any other airport which has ATC routes.
Maybe you have to switch the deluxe menu on via Xplane plugin  pulldown menu "x-life / deluxe" (or so).
Then you get the green deluxe menu with the icons, and from there you can switch on the radar map, route planner.....
First of all I want to thank you for this great add-on,  I think it has great potential and makes flightsimulating more realistic specially for people who don't want to fly online.
I noticed that the METAT/Weather information in the ATIS from the X-life window is different then the METAR info displayed in the Jardesign Airbus a320neo Cockpit.
This is confusing,  I hope that this can be changed
Greetings,
648
Thanks but, when I click "menu deluxe on" I get a message in green saying "Plaese use payware serial to active deluxe options" (I'm at EDDM airport)
649 (edited by ilankrt 2016-03-22 16:04:59)
Just finished test flight 0.91 A330 LOWG - LIRF
LOWG is a middle class airport with on runway and taxi way to the middle of this RWY. I had 4 aircraft holding short before me.
Nice, but ATC let me line up although aircraft on RWy...
LIRF, (One of the finest airports) again problem with APPR to RYW07 (only VOR!) but treated as ILS...
I decided to land on ILS RWY 16L - ATC is not able to recognize change at this stage...
Waiting to hear from JAR about problem or conflict between A330 and XL 0.92...
http://jardesign.org/forum/img/m/1591/t/p1aefh4kkk12fi1fmi1eclvp51n113.jpg
650
Hi, the ATC window has a text overflow see the HC.
http://jardesign.org/forum/img/m/2265/t … 71me63.png
Norbert
