Topic: KBOS Boston
By laohu314.
JARDesign Group Board → Custom ATC routes for XP Airports → KBOS Boston
By laohu314.
I'm updating the KBOS ATC Taxi Routes. It was my first attempt (learning the ropes) and there is some smoothing to be done.
Hopefully by the end of today I'll upload the update with link to scenery and map.
Here is the updated KBOS file.
Scenery is from here:
http://forums.x-plane.org/index.php?app … file=12363
I am still working on this so there will be another update next week.
Here is a new update for KBOS
Final (for a while, at least) update for KBOS ATC Taxi Routes
I found that the Taxi Routes didn't quite match the taxi lines so here is the correction
oook!
Finally got the ramps connected properly to the Taxi Routes. Added new KBOS.dat file. The scenery is the same as before.
I still cannot use the airport in X-Life. Gate editor does not start either. What am I doing wrong?
please use skype j.a.romanov to contact me. Forum is good place to post, but not to discuss a lit of detailes
There's another KBOS from the same author, which is newer: http://forums.x-plane.org/index.php?app … file=15851
This is the one, which is installed on my Sim. So, if I put your .dat into the Airport-folder of X-Life, I get the message "Not compatible". What to do?
Thanks in advance, Thomas
Here is KBOS with Gates/Ramps. The original file I posted was the entire apt.dat file into which I had added the ATC traffic routes. In a later update I separated the ATC traffic routes but didn't include the gates/ramps and so it didn't work properly.
Scenery: http://forums.x-plane.org/index.php?/fi … ff0103cdd4
In X-Life, traffic works but ATC will not generate a flight plan. Maybe thats due to the fact that it is not on the "approved" list...
Finally hope to have gotten it right. Thanks to Eugeny for helping me! Here is the version that should comply with all requirements according to JAR.
Scenery (KBOS Summer): http://forums.x-plane.org/index.php?/fi … ff0103cdd4
KBOS adapted to newer scenery. Removed a Taxi Route that is in the up-to-date chart for KBOS but NOT in the scenery.
http://forums.x-plane.org/index.php?/fi … o=download
