576 (edited by SirOTheOne 2016-03-19 11:10:39)
Hi JAR,
flying from EDDP to EDDM with B1900 beta9.1 -> CTD see log
577 (edited by Sloboda 2016-03-19 12:01:25)
Sorry to say, but LFML is - let say - not a good designed scenery. No signed of taxi ways, parking lots are not correct etc. I have to change my take-off airport. The author was present in this thread, so please ......
http://jardesign.org/forum/img/m/1591/t/p1ae2hpsc01c3igmp1avqrko1o9e3.jpg
i'm very sorry for disappointment. Can you explain more please ?
I've just make the ATC Routes.
You have problems with scenery or with ATC routes ?
Try to explain your problem at first time. If it's too much difficult, perhaps we can meet on Skype but i'm not speak english very well.
Thank you for help me to make better work if i can. 'cause i can't touch to scenery.
Hallo sloboda, thanks for answer
I understand that it isn't your design?  To say the truth, it isn't a well designed airport. There is another scenery made by
tdg (6/2015) that seems by far to be better and with marked parking lots. If I am right you made only the taxi ways for
X-Life. Problem is that I wanted to taxi to  runway and X-Life wasn't able to guide me .
http://forums.x-plane.org/index.php?app … file=26413
Another problem was that all parking at the gates were occupied and no one of them became active (are they all dammies?)
Also after I activated X-Life one aircraft landed and because of no taxi ways, it went straight through buildings to somewhere..
Last but not least, some parking aircraft are partly with their nose in buildings..
I can only describe about problems using X-Life at this airport. I don't know how to fix it. I think that all this scenery must be refreshed especially with marking of taxi ways. It is good possible that the scenery from tdg will be the better alternative to use and prepare for X-Life (with permission from author). sorry that I cannot help beyond this remarks.
I have see the scenery of TDG. His scenery is not correct.
That's for this reason i have no choose it.
The LFML scenery was totally based on XPFR and have the same problem.
A taxiway is undergrass, i have make a correct version for the scenery of XPFR. The author have update the download link.
You understand i can't take sceneries where planes roll on the grass... If tdg want to correct, i can make a version for LFMLtdg.
Bye.
578
Hi JAR,
Try to uninstall SkyMaxxPro3
By the way, I also uninstalled SMP3 to avoid crashes, and X-Plane clouds (25%) were far more real!!!
579
Upload beta 9.2
To update from 9.0 or 9.2 need install just mac.xpl and win.xpl files
+ bugs/CTDs fixing
+ minor improvements
580
Upload beta 9.2
+ bugs/CTDs fixing
Hi Eugeny
Version 9.2 works fine .
Hi Jar,
what is the maximum distance between 2 x-life compatible airports ?
I've looked why CYXC has no traffic, and after fixing some problems I think is's ok
now, no errors/warnings.
But no traffic. Nothing.
I think that the problem is that I do not have any other airport installed in canada/usa which is
x-life compatible.
Is there a maximum range between 2 airports, and do I need at minimum 2 airports to get traffic ?
Using 9.2.   EIDW to EGLL is now calculating a flight plan without a CTD!  However, the plan isn't correct.  I'm getting:
EIDW SID DEXEN UY124 LOMVO UY124 LUTIP UY124 PETUK UY124 BAGIT UY124 DOLOP UY124 AMPIT L15 RISLA L15 KEPAD L151 TELBA L151 VIDOK L151 PEPUL L151 DISIT L151 TUBSU L151 NEDEX L151 KIDLI L151 LINDY L151 MID L612 BOGNA L612 BENBO L612 HAWKE L612 XAMAB UL612 VEULE UL612 INPAX UL612 RESMI UL612 ODEBU R28 OKASI R28 OKEKO R28 OKEPI R28 MOU A3 OMANI A3 LESPI A3 BELVU A3 ONZON A3 BELEP A3 MURRO A3 AMIKO A3 MTL UY30 XATEL UY30 TUPOX UY30 RUBEB UY30 BATEX UY30 UGLET UY30 GILON A3 LUC A3 RUBIT A3 STP UM128 VAREK M623 LOKDU M623 AMPES M623 PELOS M731 MALAV M731 ARSIK M731 TEKSA M732 RAMEN M732 KOVAS M732 CAR P161 NOLSI UZ141 SIRVI G727 CBN UM739 SONAK UM395 PEGIT UM395 ABRAM T295 SKATE T295 SHELL T295 NAWRS M740 KDR G659 WLD W854 HON STAR EGLL
It looks as though it's picking up the incorrect HON waypoint.  There is a HON to the north west of EGLL.  It seems to be picking up one in North Africa.
http://jardesign.org/forum/img/m/683/t/p1ae7foo3t7bdh81q0912to1nrf3.jpg
583
You may build route like EDDM-EDDM where is distance = 0.
Should work well for any small distance XXXX-YYYY if both airports XXXX and ZZZZ are XL compatible.
584
Thanks! For this case - routefinder should help and you can import plan from text file. Sure, I will check this route with wrong HON.
585 (edited by SirOTheOne 2016-03-19 14:24:29)
Hi JAR,
there is something wrong:
YELLOW 4-725 ist landing and THEN waiting on RWY for the following aircraft ????? see pic
situation is on EDDN
586
Yeah, thats not Ok!
587
Hi thomas_99
I have CYQM, CYFC and CYSJ ( Moncton, Fredericton and Saint John , NB ) done using the beta 9.1 version ( I have tried several times to buy the Deluxe version but for some reason, am unable to ) So far, I have only been able to get one aircraft at each airport to arrive ( don't know from where) , that parks correctly at a gate. wait a long time but never did I see another one arrive.
I have had only one aircraft depart from the gate , take the wrong taxiway but did get to the correct runway hold point and stayed there until I shut down X-Plane, probably 45 mins later
I don't know if the deluxe version works any better but  the beta still needs some work I think.
Hi Jar,
x-life compatible.
Chaps wrote:
Hi thomas_99
Hi Jar,
x-life compatible.
try to use the latest beta just came out 9.2
I figured out for me if it helps someone else..The agree and disagree button is not visible if you have panel showing..I went to  Forwards with Nothing under view and there it sat. Clicked agree and I am all set
Thanks,
Bob Morehead
590
Chaps wrote:
Hi thomas_99
Hi Jar,
x-life compatible.
CYQM, CYFC and CYSJ was not checked and approved for X-Life. If someone do ATC-taxiroutes for them - not mean what ATC-taxiroutes used by XL is Ok.
591 (edited by jcdp 2016-03-19 18:44:45)
Hi, I got same flight plan ...I confirm.
After many tries and crashes I was happy too much...seeing no crash when clicking "generate" ...
Acei you are more professionnal than me , thanks.
I was the one that made the taxi network for CYFC - I understand that it's not XL 'approved', but I've made many successful XL-compatible networks before, so I'm pretty sure the taxi network is ok.
The problem seems to be that the plugin can't choose a departing runway.  One aircraft lands and taxis to the gate successfully, but the departing aircraft never leave the gate.  In the airport data window, the runway assignment for the 1st departure changes back and forth very rapidly, many many times per second.  I think the planes never start to taxi because they don't have a departure runway.
I'm using the newest beta version, XP 10.45.  I posted about this issue before, but I think it got lost in the shuffle.
Any ideas?
Thanks!!
593
I would like to discuss an unusual idea. We beta test pilots are experiencing a lot of occurrences during flight that nobody
can see and talk about. Telling it afterwards isn't always clear as if we can see it timely. Capturing all flight and transfer  them to YouTube is an enormous project.
So has anyone an idea how can we open a channel for our flights that capture our screen while flying and enable other to see this flights online perhaps also with an audio channel....  ?
594
Good night.
Plugin Version 9.2
Fly on the route ULLI - UUEE. Set in Sheremetyevo STAR LTB06A on the 06 runway and ILS approach runway 24L.
Полет по маршруту ULLI - UUEE. Заход в Шереметьево назначен STAR LTB06A на 06 ВПП, а заход ILS дан на 24L.
595
Metallist wrote:
Good night.
Plugin Version 9.2
Good day
the airport ULLI is not on the X-Life map but UUEE is on the map this is why the flight plan did not work.
google map;
https://www.google.com/maps/d/viewer?mi … ecn3NB3GZ8
596 (edited by captbullett 2016-03-20 02:18:22)
Here is the latest version and the last route I flew EHAM/LIRF A330 no issues and it was a fun flight.
597
I just saw the news about the aircraft that went down in Russia and I want to extend my best wishes to the Russian people in there sad time god be with you.
Well, I've installed KSFO for testing and it works. Also there is no other airport around....
Must be something special which prevents traffic..... It's not the deluxe version, it shows the same
behaviour.....
I'll make some tests.....
Chaps wrote:
Hi thomas_99
Hi Jar,
x-life compatible.
Hi Brian,
Does not make any difference....
CTD while trying to generate a route and sending it to ATC.
What I have done:
trying to get traffic to CYXC airport:
  - start x-life
  - trying to generate a route from CYXC to KLAX
  - set dep Airport to CYXC
  - set arr airport to KLAX
  -> no generated route, no error, nothing. simplay an empty route.....
  - pressed "send route to ATC"  -> a route appeared: "CYXC DCT KLAX"
  - request clearance
  -> CTD
http://jardesign.org/forum/img/m/552/t/p1ae9lmqd01co71e0l7nhhkf1i6m3.jpg
http://jardesign.org/forum/img/m/552/t/p1ae9lql2q15pkcm2ntvr19egd6.jpg
http://jardesign.org/forum/img/m/552/t/p1ae9lquhi28hur4187iatdk978.jpg
Log:
X-Life plugin by JARDesign Ver.beta 9.2 190316
XL: 0 : OpenSceneryXpath find
XL: 30 : MessageRed: CYXC airport is not X-Life verified! Please use menu and check verified airports Map!
XL: 30 : JARDesign plugin: D:\Spiele\X-Plane 10\Resources\plugins\X-Life\Metar/CYXC.TXT file updated.
0:02:46.327 I/ATC: Airport flow changed at CYXC!
CurFlow: AUTOGEN: North NewFlow: AUTOGEN: West
0:02:46.327 I/ATC: Changing CYXC CabState from 0 to 1
0:02:46.327 I/ATC: All departures are done at CYXC. Advancing...
0:02:46.327 I/ATC: Changing CYXC CabState from 1 to 2
0:02:46.327 I/ATC: All arrivals are done at CYXC. Advancing...
0:02:46.327 I/ATC: Changing CYXC CabState from 2 to 0
XL: 87 : JARDesign plugin: D:\Spiele\X-Plane 10\Resources\plugins\X-Life\Metar/CYXC.TXT file updated.
XL: 87 : JARDesign plugin: D:\Spiele\X-Plane 10\Resources\plugins\X-Life\Metar/KLAX.TXT file updated.
XL: 112 : Flightplan sended to ATC: CYXC DCT KLAX
XL: 281 : ---+++--- Pilot: CANADIAN ROCKIES INT Ground ,USER123, Stand GG, A320, with information Alpha, QNH1021, request clearance
immediate crash....
2. try, same situation: Working. No Traffic but no crash....
XL: 46 : MessageRed: CYXC airport is not X-Life verified! Please use menu and check verified airports Map!
XL: 46 : JARDesign plugin: D:\Spiele\X-Plane 10\Resources\plugins\X-Life\Metar/CYXC.TXT file updated.
0:02:38.881 I/ATC: Airport flow changed at CYXC!
0:02:38.881 I/ATC: Changing CYXC CabState from 0 to 1
0:02:38.881 I/ATC: All departures are done at CYXC. Advancing...
0:02:38.881 I/ATC: Changing CYXC CabState from 1 to 2
0:02:38.881 I/ATC: All arrivals are done at CYXC. Advancing...
0:02:38.881 I/ATC: Changing CYXC CabState from 2 to 0
XL: 108 : JARDesign plugin: D:\Spiele\X-Plane 10\Resources\plugins\X-Life\Metar/CYXC.TXT file updated.
XL: 108 : JARDesign plugin: D:\Spiele\X-Plane 10\Resources\plugins\X-Life\Metar/KLAX.TXT file updated.
XL: 161 : Flightplan sended to ATC: CYXC DCT KLAX
XL: 181 : ---+++--- Pilot: CANADIAN ROCKIES INT Tower ,USER123, Stand GG, A320, with information Alpha, QNH1021, request clearance
XL: 181 : inRW=34
XL: 181 : inSidPoint=KLAX
XL: 181 : ---+++--- ATC: USER123, CANADIAN ROCKIES INT Delivery, Wrong ATIS Information
XL: 181 : ---+++--- ATC: USER123, Contact CANADIAN ROCKIES INT Delivery
XL: 190 : ---+++--- Pilot: Roger, USER123
XL: 227 : ---+++--- Pilot: CANADIAN ROCKIES INT Delivery ,USER123, Stand GG, A320, with information Alpha, QNH1021, request clearance
XL: 227 : inRW=34
XL: 227 : inSidPoint=KLAX
XL: 227 : ---+++--- ATC: USER123, CANADIAN ROCKIES INT Delivery, Wrong ATIS Information
XL: 235 : ---+++--- Pilot: CANADIAN ROCKIES INT Delivery ,USER123, Stand GG, A320, with information Alpha, QNH1021, request clearance
XL: 235 : inRW=34
XL: 235 : inSidPoint=KLAX
XL: 235 : ---+++--- ATC: USER123, CANADIAN ROCKIES INT Delivery, Wrong ATIS Information
XL: 242 : ---+++--- Pilot: CANADIAN ROCKIES INT Delivery ,USER123, Stand GG, A320, with information Alpha, QNH1021, request clearance
XL: 242 : inRW=34
XL: 242 : inSidPoint=KLAX
XL: 242 : ---+++--- ATC: USER123, CANADIAN ROCKIES INT Delivery, Wrong ATIS Information
XL: 245 : ---+++--- Pilot: CANADIAN ROCKIES INT Delivery ,USER123, Stand GG, A320, with information Alpha, QNH1021, request clearance
XL: 245 : inRW=34
XL: 245 : inSidPoint=KLAX
XL: 245 : ---+++--- ATC: USER123, CANADIAN ROCKIES INT Delivery, Wrong ATIS Information
XL: 248 : ---+++--- Pilot: CANADIAN ROCKIES INT Delivery ,USER123, Stand GG, A320, with information Alpha, QNH1021, request clearance
XL: 248 : inRW=34
XL: 248 : inSidPoint=KLAX
XL: 248 : ---+++--- ATC: USER123, CANADIAN ROCKIES INT Delivery, Wrong ATIS Information
XL: 251 : X-Life check atis info:Departure: CYXC information November. Runway in use: RW34 Transition Level 18000 ft. Weather: // Arrival: KLAX information November. Runway in use: RW25R RW24L RW25L RW24R Transition Level 18000 ft. Weather:
XL: 282 : ---+++--- Pilot: CANADIAN ROCKIES INT Delivery ,USER123, Stand GG, A320, with information November, QNH1019, request clearance
XL: 282 : inRW=34
XL: 282 : inSidPoint=KLAX
XL: 282 : ---+++--- ATC: Initial Altitude 20000 feet, Squawk 6377
XL: 282 : ---+++--- ATC: USER123, CANADIAN ROCKIES INT Delivery, Cleared to LOS ANGELES INTL, Runway 34, via  departure,
XL: 287 : ---+++--- Pilot: Cleared to LOS ANGELES INTL, Runway 34, via , Initial Alt 20000, Squawk 6377, USER123
XL: 306 : ---+++--- Pilot: CANADIAN ROCKIES INT Delivery ,USER123, Stand GG, request start up, information November
XL: 306 : ---+++--- ATC: USER123, start up approved
XL: 306 : ---+++--- ATC: USER123, Contact CANADIAN ROCKIES INT Ground
XL: 307 : ---+++--- Pilot: Roger, USER123
XL: 315 : ---+++--- Pilot: CANADIAN ROCKIES INT Ground ,USER123, Stand GG, request start up, information November
XL: 315 : ---+++--- ATC: USER123, start up approved
XL: 332 : ---+++--- Pilot: Start up approved, USER123
XL: 334 : ---+++--- Pilot: CANADIAN ROCKIES INT Ground ,USER123, Stand GG, request taxi
XL: 334 : ---+++--- ATC: USER123, CANADIAN ROCKIES INT Ground, taxi to holding short runway 34, via X,A,B,Taxi
XL: 363 : ---+++--- Pilot: Taxi to holding short runway 34, via X,A,B,Taxi, USER123
XL: 389 : ---+++--- Pilot: CANADIAN ROCKIES INT Ground ,USER123, Stand GG, request FollowMe car
XL: 389 : ---+++--- ATC: USER123, CANADIAN ROCKIES INT Ground, expect FollomMe car 1 minute
D:\Spiele\X-Plane 10\Resources\plugins\X-Life\fmpath.txt
Find FMCar route file at D:\Spiele\X-Plane 10\Resources\plugins\X-Life\fmpath.txt
XL: 408 : ---+++--- Pilot: Roger, USER123
XL: 553 : ---+++--- Pilot: CANADIAN ROCKIES INT Ground ,USER123, approaching holding short runway 34
XL: 553 : ---+++--- ATC: USER123, CANADIAN ROCKIES INT Tower, line up runway 34, and wait
XL: 553 : ---+++--- ATC: USER123, Contact CANADIAN ROCKIES INT Tower
XL: 559 : ---+++--- Pilot: Roger, USER123
XL: 562 : ---+++--- Pilot: CANADIAN ROCKIES INT Tower ,USER123, approaching holding short runway 34
XL: 562 : ---+++--- ATC: USER123, CANADIAN ROCKIES INT Tower, line up runway 34, and wait
XL: 666 : ---+++--- Pilot: Lining up and wait runway 34, USER123
XL: 666 : ---+++--- ATC: USER123, Set Transponder, Squawk 6377
XL: 680 : ---+++--- Pilot: Transponder On, Squawk 6377, USER123
XL: 680 : ---+++--- ATC: USER123, runway 34 cleared for take-off, wind 256 degrees 6 knots
XL: 695 : ---+++--- Pilot: Cleared for take-off, Runway 34, USER123
XL: 747 : ---+++--- ATC: USER123, contact CANADIAN ROCKIES INT Approach 124.6
XL: 754 : ---+++--- Pilot: Contact CANADIAN ROCKIES INT Approach on 124.6, USER123
XL: 757 : ---+++--- Pilot: CANADIAN ROCKIES INT Approach ,USER123,  departure, passing 4100 feet, climbing to 8800 feet
XL: 757 : ---+++--- ATC: USER123, CANADIAN ROCKIES INT Approach, radar contact, climb to FL 200
XL: 765 : ---+++--- Pilot: Climbing to FL200, USER123
Clean exit from threads.
!!!! DO EXIT disable
JARDesign 3D Sound Engine Disable
JARDesign Ground Handling 3D Sound Engine Disable
XL: 818 :
XL: 818 : ATC LOG -----------------------------------
XL: 818 : > Pilot: CANADIAN ROCKIES INT Tower ,USER123, Stand GG, A320, with information Alpha, QNH1021, request clearance
XL: 818 : > ATC: USER123, Contact CANADIAN ROCKIES INT Delivery
XL: 818 : > Pilot: Roger, USER123
XL: 818 : > Pilot: CANADIAN ROCKIES INT Delivery ,USER123, Stand GG, A320, with information Alpha, QNH1021, request clearance
XL: 818 : > ATC: USER123, CANADIAN ROCKIES INT Delivery, Wrong ATIS Information
XL: 818 : > Pilot: CANADIAN ROCKIES INT Delivery ,USER123, Stand GG, A320, with information November, QNH1019, request clearance
XL: 818 : > ATC: Initial Altitude 20000 feet, Squawk 6377
XL: 818 : > ATC: USER123, CANADIAN ROCKIES INT Delivery, Cleared to LOS ANGELES INTL, Runway 34, via  departure,
XL: 818 : > Pilot: Cleared to LOS ANGELES INTL, Runway 34, via , Initial Alt 20000, Squawk 6377, USER123
XL: 818 : > Pilot: CANADIAN ROCKIES INT Delivery ,USER123, Stand GG, request start up, information November
XL: 818 : > ATC: USER123, Contact CANADIAN ROCKIES INT Ground
XL: 818 : > Pilot: CANADIAN ROCKIES INT Ground ,USER123, Stand GG, request start up, information November
XL: 818 : > ATC: USER123, start up approved
XL: 818 : > Pilot: Start up approved, USER123
XL: 818 : > Pilot: CANADIAN ROCKIES INT Ground ,USER123, Stand GG, request taxi
XL: 818 : > ATC: USER123, CANADIAN ROCKIES INT Ground, taxi to holding short runway 34, via X,A,B,Taxi
XL: 818 : > Pilot: Taxi to holding short runway 34, via X,A,B,Taxi, USER123
XL: 818 : > Pilot: CANADIAN ROCKIES INT Ground ,USER123, Stand GG, request FollowMe car
XL: 818 : > ATC: USER123, CANADIAN ROCKIES INT Ground, expect FollomMe car 1 minute
XL: 818 : > Pilot: CANADIAN ROCKIES INT Ground ,USER123, approaching holding short runway 34
XL: 818 : > ATC: USER123, Contact CANADIAN ROCKIES INT Tower
XL: 818 : > Pilot: CANADIAN ROCKIES INT Tower ,USER123, approaching holding short runway 34
XL: 818 : > ATC: USER123, CANADIAN ROCKIES INT Tower, line up runway 34, and wait
XL: 818 : > Pilot: Lining up and wait runway 34, USER123
XL: 818 : > ATC: USER123, Set Transponder, Squawk 6377
XL: 818 : > Pilot: Transponder On, Squawk 6377, USER123
XL: 818 : > ATC: USER123, runway 34 cleared for take-off, wind 256 degrees 6 knots
XL: 818 : > Pilot: Cleared for take-off, Runway 34, USER123
XL: 818 : > ATC: USER123, contact CANADIAN ROCKIES INT Approach 124.6
XL: 818 : > Pilot: Contact CANADIAN ROCKIES INT Approach on 124.6, USER123
XL: 818 : > Pilot: CANADIAN ROCKIES INT Approach ,USER123,  departure, passing 4100 feet, climbing to 8800 feet
XL: 818 : > ATC: USER123, CANADIAN ROCKIES INT Approach, radar contact, climb to FL 200
XL: 818 : > Pilot: Climbing to FL200, USER123
XL: 818 : ATC LOG END ----------------------------
XL: 818 :
!!!! DO EXIT stop
0:15:36.278 I/JOY: UNREGISTER Joystick device: LUFA Joystick wFFB - VID:1003PID:8270
0:15:36.278 D/HID: HID Bridge Shutdown
----- X-Plane has shut down -----
