1 (edited by Wangenheim 2016-03-19 07:00:50)
Topic: UMMS Minsk International (Minsk-2)
Scenery 1 by vsritterman.ru:
Available here
Login: uiun
Password: elf;!_tR8O_Hs
Free for personal use, and prohibited for commercial.
Last update: December 2015
Compatible with Seasons (to support autumn and winter need to remove or disable photo terrain folder in scenery_pack.ini)
Scenery 2 by Moter from avsim.ru:
Available here.
Last update: March 2016
Not Compatible with Seasons.
UMMS.zip - taxiways for Scenery 2 for X-Life and FollowMeCar
Re: UMMS Minsk International (Minsk-2)
WoW! Thanks a looot! Please post a link where user can download Minsk scenery!
Also.. Can I Upload this .dat & .txt to server to be possible download this files for every user? And sure, in this case I will add this Scenery to compatible Map.
http://www.avsim.su/f/x-plane-scenarii- … 58171.html
4 (edited by Wangenheim 2016-02-07 14:48:53)
Here the page with Airport Scenery Link. It is not created by me, but it's free for personal use.
Minsk 2 scenery can also be downloaded from x-plane.org and avsim.su (link above)
Cool scenery!!! Thanks for link!
Just test and rework ATC-taxiroutes a little - add taxiway K, stands 35-44 and remove unused datas from .dat file.
http://jardesign.org/forum/img/m/22/t/p1aaugp372d44q1731t50gg03.jpg
http://jardesign.org/forum/img/m/22/t/p1aaugp372lec171b1qvascd7v94.jpg
So, Wangenheim, may I upload .dat and .txt to server to make it available for every user, and also, if yes - will add it to MAP?
Of course, that why I posted it here.
Ok, good. Спасибо, добавил на карту и залил на сервер для autodownload пользователями.
Added existing sceneries to first post with links.
9 (edited by jcdp 2016-03-10 16:14:02)
Post cancelled ...
10 (edited by Wangenheim 2016-03-19 06:02:12)
Added taxiways for Scenery 2 (by Moter) to first post.
How to install: Replace files in X-Life\Airports and FM\Airports with files in archive. You should have Scenery 2 installed.
