551 (edited by Dewald 2016-03-17 14:11:24)
Hi Jar. I cannot thank you enough for this plugin.
I don't fly online and this is exactly what was needed.
One question though. Will it be possible to add airport sound ambience when aircraft is on the ground.
What I do now is to play (with my media player) a long sound loop that I collected and edited.
Would be awesome if the plugin can trigger a sound loop automatically.
I am obviously willing to donate my sound files. These are all files of aircraft taking of an so on.
552
I do not know about the sound i have done the same thing you have done with the sound loop. If you do some research on the org you can find some sound files also of the airports , I saw one last night.
Thank-you for your comments.
553 (edited by captbullett 2016-03-17 14:19:29)
I am running on a Mac but I am crossed trained in PC and this is a very useful thing for people using PC and Windows 10 when I saw this I knew this might be an issue and I am posting this for people that know how to work with this data.
If you do not know what you are doing you will have a bad day after making any changes to your permissions without knowing exactly how to do this.
So, this is for JAR and the developers  or computer operators that know how to change their permissions.
http://lifehacker.com/how-to-create-a-g … 1765447417
554 (edited by Dewald 2016-03-17 14:56:00)
Hello Brian
Getting and editing the sounds is really easy.
Just on my wish list that a plugin can trigger it on and of.
On when on the ground - Off when taking off --- On just after landing.
Sort of similar to soundmaxx's exterior sound loop, but triggered by plugin inside and outside of cockpit.
Inside obviously softer than outside.
https://www.youtube.com/watch?v=kHW8Iou_aI0
This is one I use --- Simply extracted the audio
555 (edited by ilankrt 2016-03-17 21:58:53)
Sorry to say, but LFML is - let say - not a good designed scenery. No signed of taxi ways, parking lots are not correct etc. I have to change my take-off airport. The author was present in this thread, so please ......
http://jardesign.org/forum/img/m/1591/t/p1ae2hpsc01c3igmp1avqrko1o9e3.jpg
556
I think about sounds, sure.
557
Another CTD in EIDW.  This time I imported the flight plan to EGLL from the FMS which worked fine.  Was taxiing to the runway when I got a CTD.
XL doesn't like EIDW!!
558
Find bug in code and fix it, thanks! Also, please check a PM!
559
Hello Brian
Until we get sound into X-life, SoundMaxx seems to work well with X-life...
560 (edited by Acei 2016-03-17 23:12:27)
Hi Eugeny, had a quick look tonight.  I just started up XP and went to calculate the route.  I got the usual CTD when trying to calculate EIDW to EGLL.  However, when I looked at the log file, I see this route at the end:
EIDW SID DEXEN UY124 LOMVO UY124 LUTIP UY124 PETUK UY124 BAGIT UY124 DOLOP UY124 AMPIT L15 RISLA L15 KEPAD L151 TELBA L151 VIDOK L151 PEPUL L151 DISIT L151 TUBSU L151 NEDEX L151 KIDLI L151 LINDY L151 MID L612 BOGNA L612 BENBO L612 HAWKE L612 XAMAB UL612 VEULE UL612 INPAX UL612 RESMI UL612 ODEBU R28 OKASI R28 OKEKO R28 OKEPI R28 MOU A3 OMANI A3 LESPI A3 BELVU A3 ONZON A3 BELEP A3 MURRO A3 AMIKO A3 MTL UY30 XATEL UY30 TUPOX UY30 RUBEB UY30 BATEX UY30 UGLET UY30 GILON A3 LUC A3 RUBIT A3 STP UM128 VAREK M623 LOKDU M623 AMPES M623 PELOS M731 MALAV M731 ARSIK M731 TEKSA M732 RAMEN M732 KOVAS M732 CAR P161 NOLSI UZ141 SIRVI G727 CBN UM739 SONAK UM395 PEGIT UM395 ABRAM T295 SKATE T295 SHELL T295 NAWRS M740 KDR G659 WLD W854 HON STAR EGLL
It makes no sense and seems to go back and forward and as far afield as waypoints in North Africa!  A typical route from EIDW to EGLL would be:
EIDW SID DEXEN UY124 AMPIT L15 KEPAD L151 UN859 HON STAR EGLL
There was no x-life.dmp file for this instance.
561
Question: in the thread I opened in X-Plane.org, there was a complain that X-Life isn't working on several airports. Are we at this stage restricted to use X-Life only for airports on your Map ? (perspective..)
X-Life works if you have ATC route defined into the scenery.  For example i have nearly finished my LEGO BRICK LTBA. Created ATC Routes by using WED, also created *.txt file by using Gate editor. X-life worked beautifully without any problem for 6-7 hours straight. (1.5x sim speed)
So, if all scenery developer give time and create atc routes (detailed or basic)  we can use x-life on every scenery.
Currently only problem is gate editor. Since X-plane WED gate definiton is not detailed enough like X-life gate editor, you need to use it.  E.g LTBA do not allow 747-8i and A380 for parking, but X-plane's WED Heavy-Jet's selection allows them.
So JAR Design created this superb addon, harras all developers, so they will create taxi routes and we can easily use X-Life which is a (and will be) must have addon for every x-plane enthusiast.
Sorry for typing a bit long and off topic. big_smile
562
Thanks for answer, I am not a scenery developer, in fact dependent on other designer. I therefore use the airports marked on the JAR google map.
563
Test Flight b.9.1 LFMN - EGLL with A330 on iMac
No crash, smooth and wonderful flight !  but
Yesterday I purchased Aerosoft EGLL scenery and I am very disappointed.
It seems not to be accurate made and to my surprise there are no marked taxi ways !!
The result - the green arrow marks led me to an empty area opposite the airport to an unmarked parking lot.
Beside this parking airliner are partly inside buildings, and one X-Life aircraft went straight through building ......
I feel that I have my money for EGLL thrown out of the window
But leastwise X-Life traffic is working well !
564
i'm very sorry for disappointment. Can you explain more please ?
I've just make the ATC Routes.
You have problems with scenery or with ATC routes ?
Try to explain your problem at first time. If it's too much difficult, perhaps we can meet on Skype but i'm not speak english very well.
Thank you for help me to make better work if i can. 'cause i can't touch to scenery.
Bye
565 (edited by Dewald 2016-03-18 09:03:27)
Hi there
I have the very same airport, and it works perfectly.
Just as a side note --- Did you disable the default EGLL?
Entry in scenery.ini should be --- SCENERY_PACK_DISABLED Custom Scenery/Aerosoft - EGLL Heathrow/
Also --- Did you install the exclusion for this airport?
The entries for your airport and exclusion should be
SCENERY_PACK Custom Scenery/Aerosoft - EGLL Airport London-Heathrow/
SCENERY_PACK Custom Scenery/Aerosoft - EGLL Heathrow zExclusions/
I attached the exclusion in case you don't have it.
Attachment icon Aerosoft - EGLL Heathrow zExclusions.zip 3.7 kb, 141 downloads since 2016-03-18
566
Acei wrote:
that was AMD OpenGL driver error, as I check via damp.
I reinstalled my AMD drivers.  I got a little further this time, but still getting a crash when trying to create flight plan from EIDW to EGLL.
The same thing happens to me (see previous posts #507 and #534 ).
EIDW-EGLL flightplan generation CTD reason finded and fixed. Thanks for info and help.
567
Hi there
I didn't disable ! thanks for advice.
If I understand you right I have only to put your folder into Custom Scenery folder...
568 (edited by Dewald 2016-03-18 13:34:41)
Hi there
Yes. Just install like you would install any other scenery.
Make sure it is below the new EGLL in the scenery.ini
If you are not sure how to, just install the exclusion, fire up X-plane and exit again.
Then attach your scenery.ini here so that I can check it for you.
569
Thanks again Dewald!
I am already curious to test EGLL ...
570
No prob. Its a lovely airport to a standard that is expected of Aerosoft, and X-Life works beautifully with it.
Am going away on vacation in a few hours, so I will check back in next week Saturday.
Happy Flying everyone.
571
Hallo sloboda, thanks for answer
I understand that it isn't your design?  To say the truth, it isn't a well designed airport. There is another scenery made by
tdg (6/2015) that seems by far to be better and with marked parking lots. If I am right you made only the taxi ways for
X-Life. Problem is that I wanted to taxi to  runway and X-Life wasn't able to guide me .
http://forums.x-plane.org/index.php?app … file=26413
Another problem was that all parking at the gates were occupied and no one of them became active (are they all dammies?)
Also after I activated X-Life one aircraft landed and because of no taxi ways, it went straight through buildings to somewhere..
Last but not least, some parking aircraft are partly with their nose in buildings..
I can only describe about problems using X-Life at this airport. I don't know how to fix it. I think that all this scenery must be refreshed especially with marking of taxi ways. It is good possible that the scenery from tdg will be the better alternative to use and prepare for X-Life (with permission from author). sorry that I cannot help beyond this remarks.
572 (edited by Sloboda 2016-03-19 06:40:36)
Hello, i will see about what you say...
For guide you to runway, use FollowMe. That's work.
No need permission for create ATC-Routes 'cause you don't touch at the scenery.
the ATC-Routes are in another apt.dat localized in X-Life.
I will see for noses in building.
Thank you, bye.
Update: I have post a Fix in downloads.
573
Evgeny, the current version of X-Life is limited to 4 "active" planes, can we somehow change that limitation? to 6 or 8 or make this limit available in settings?
http://jardesign.org/forum/img/m/1313/t/p1ae6pe70o1t0h4513md1go7tu3.jpg
574 (edited by Sloboda 2016-03-19 09:07:54)
something weird. When a route cross a runway. A plane1  wait at the hold point since the other plane2 come for landing. He wait, he wait, he wait. No problem. But, just after plane2 have landing, plane1 go thrue the landing runway for crossing just in front off plane2.
575
This depend of active independent runways numbers and different for different airports.
