451
please check X-Plane folder for it
the dump file is not there
B.
Please check what you make full installation or (at least) install 2 new files:
win.xpl and dbghelp.dll (i just attached)
Damp memory system work on Windows only and when CTD happen only.
If you want check how is it work, you may rename OpenSceneryX folder to (example) OpenScenery_X and try to start traffic. CTD should happen and x-life.dmp should be saved to X-Plane folder.
452
XLife Beta 9, deluxe version
JAR A 330
Flight from LIRF to LOWG.
Near TOD, ATC Center tells me to approach ILS RWY 17L.
I check on A330 FMC and Navigraph charts, there is no ILS for RWY 17L. Just one ILS for RWY 35C.
RWY 17L is too small for A330 landing and has no ILS approach at all.
Alessandro
453 (edited by captbullett 2016-03-11 14:07:23)
B.
I am on a mac ... so this will not work? and I also down-loaded the full version of #9
and I found the dbghelp.dill file so I will send this the next CTD...
thank-you
454 (edited by captbullett 2016-03-11 14:24:16)
JAR A 330
Alessandro
Need bbox.txt, (if you are using a JAR aircraft if not log.txt both if using JAR aircraft) just before you close XP so we can see and re-produce the issue since, we are also working with the Flight plan otherwise the data just is not here to help not just you but the team.
also the log.txt is a must this is not up for debate we need the data to solve the issues
thank-you for your help
455
B.
thank-you
Apple crash report is always good + log.txt
456
i just finish LFML (Marseille Provence / France). It look work good.
Important city. It's be the second city of France after Paris.
Just a question: The planes seem to landing too far of the start of the start point of the runway. But i think my ATCRoute is place correctly.
http://jardesign.org/forum/img/m/1506/t/p1add5r3mkmbmubu4fp5eidga3.jpg
Scenery is here: http://forums.x-plane.org/index.php?app … file=26413
I have not remove or delete anything in the scenery, so X-Life files are make for match for it. I have not remove any statics objects. So i have ATCRoutes at else places of the static planes.
But, i have just edit a little the dsf because there's a very big mistake and the planes was roll on the grass just on a taxiway cause there was two lines were cross.
Bye
Try to install scenery via this link - no luck. Sorry but..
http://jardesign.org/forum/img/m/22/t/p1adj226281rtugm01ubi92t3qq3.jpg
http://jardesign.org/forum/img/m/22/t/p1adj22hie1qi510iln7glkda805.jpg
457 (edited by captbullett 2016-03-11 15:13:11)
thank-you
Ok thank-you I put the files into place that you posted above and also put the hot Fix in place for the A320Ne and everything is ok right now I will keep you posted. also I had a good flight with MD-80 last version
B.
458 (edited by Sloboda 2016-03-11 20:16:20)
Bye
Hello JA,
i know why ! Super !
It's because i have make corrections in the apt.dat of the airport. So its author have make the changes for put my files in his scenery and reload it on the server. I think you have download while he had do that.
I've just download the scenery from: http://xpfr.org/?body=scene_accueil&sc=88
and test my LFML.dat and LFML.txt.
""All work perfectly"", I think.... But you are the boss.
I hope that's good 'cause i have almost finish LFPO (Paris Orly). In test now...
So, you can retry to download LFML and see if my files interest you.
Thank you. Bye
459
Hello JA,
Thank you. Bye
Thanks!!
Just get this scenery worked with new link. So.. as I view .dat file, seems like a lot of places there what may be corrected for good x-life geometry and need to be 150% improvement. If you ready, please contact me skype j.a.romanov - i will show details for you online.
460
New plugin, LFMN loop, Great flight, everything worked (did not use FM car tho), then reset the fms for another, redid the flight plan everything ok, got a push from JAR truck out of gate, then called FM car, then ctd. Logs attached
461 (edited by ilankrt 2016-03-13 15:05:38)
Same experience with XL b.09, flying A330 on my iMac27.
LFMN: as I mentioned already, taxi ways are false if starting from parking lots!  Starting from gate (16B) everything works fine - Flight plan ( to LGAV), ATIS and FollowMe car.
Disabling SMP3 and I gane 30fps stable !
Now on my way to Athens at FL310 .....
In my custom scenery folder I found an older version of LGAV ( 2013, 19.6 MB). Unfortunately I didn't replace it. (now it landed in my trash. In X-Plane.org there is a newer airport version (2015) recommended  by JAR, but it has a lot of bugs and lack of taxi ways.
First contact to Center, got order to descend to FL 70, Then contact Approach, got order to descend FL100. This happened on every flight - need to be changed.
Anyway during descent frame rate sank to 1fps after X-Life became alive (traffic). Only after refreshing METAR, frame rate went back to normal. This happened sometimes during flight with the A330 without X-Life. I observed that this occurrence  was just as MEATR data appears on ND of the A330. I think it is necessary to cheek the input of METAR data on the A330.
During approach to LGAV another aircraft was in front of my aircraft so I got order to GO Around. At least landing, the FollowMe car escorted me over green fields to my parking lot ....
462
working on testing the E-175 now from EGLL/EHAM this route seems to be a good route to use for testing ...
Ps, I hope everyone is having a good day smile
463
Thaaanks! That was very easy to find a problem in code line with this memory damp file and description.
464
Hope you too, Brian! Thanks!!
465
Hello JA,
Thank you. Bye
Thanks!!
Hello JA, I have send you a message on Skype for you approve. I'm studiodecibels on skype.
466
SUPER, Mr R! that was a great idea you did to track down bugs! glad it helped as will others logs!!!
...now, I'm off to another flight smile
Everyone have a great Sunday, and remember to hug your loved ones.
467
Indeed! you too Brian!!!
468
In my custom scenery folder I found an older version of LGAV ( 2013, 19.6 MB). Unfortunately I didn't replace it. (now it landed in my trash. In X-Plane.org there is a newer airport version (20115) recommended  by JAR, but it has a lot of bugs and lack of taxi ways.
Ye, I get this (framerate down for time) both with 320/330. I not sure what a reason exactly, i should understand this better. Sometimes yes, sometimes no. I hope will do.
469
connected now
470 (edited by letec 2016-03-13 10:18:00)
Test X-Live b9, A320neo_2.6b4, AIRAC 1603, LOWI-EDDF. Crash just after take-off (as always) no more than 50 meters above the runway. For me still same.
In the rar file - sbbox_log.txt, Log.txt, LOWIEDDF.txt and  x-life.dmp
Thanks for your work.
Best Regard
471 (edited by SirOTheOne 2016-03-13 13:31:04)
Flying from LOWW to EDDm with CRJ200 with beta9 on iMac -> CTD via approach to EDDM
472
Do you have an iMac 21 or 27?
How many GB memory on your iMac?
473
iMac 27ret i7 24GB
474
iMac 27ret i7 24GB
In my opinion you must have installed either 16 (2 x 8 ) or 32 GB (4x8 0r 2 x 16) GB
Check this issue on Apple site!
It can be the source of you problems (not only with X-Plane and X-Life)
475 (edited by SirOTheOne 2016-03-13 16:57:16)
Flying from EDDL to EDDC with CRJ200 with beta9 on iMac -> CTD on ground, while cruising to stand
