1 (edited by J.A.Romanov 2015-05-01 11:33:45)
Topic: v1.1b3 distributive (Windows 7/8, MAC OS)
Please install it as clear installation, not use custom sound pack, not mix files with other version, but sure, install NavData update if need.
I am very interesting with info about both - good flight and flight with CTD. Please discuss this Beta here, at this topic. Please post your MAC flight info and CTD reports here. Most appreciated are MAC Crash reports (need attach log.txt file and MAC crash report file)
Download link http://jardesign.org/a330/download/inst … v1.1b3.zip
Whats new: Please use v1.1 tag like this http://jardesign.org/forum/search.php?a … ;tag_id=52
Also, please check "whats new"with link above. Please not post old issue what always reporter but not done/fix at this version.
2 (edited by flydav 2015-05-02 04:27:31)
Re: v1.1b3 distributive (Windows 7/8, MAC OS)
CTD before taxi
Please disable the captcha key I have to solve the puzzle for every file I upload  it's a ridiculous waste of time! Thanks!
thanks for report!
without capcha will be a lot of botspam. i will try to change settings
The Co-pilot CHRONO button is just a dark black hole, the pilot side is fine
Mac OS beta 3
5 (edited by Franz007 2015-05-02 15:40:56)
Thanks for the beta 3! The final reserve fuel amount is now correct (3.0T/30Min), but the EXTRA fuel quantity vs time is now wrong (look at the attachment). 13.9T would be around 2h30 of flight time and not 6h58. Is there a way to correct that in the next beta?
Thanks & cheers
Franz
good day,
I just down loaded B3 , and now I don't have the keys to start <?>
the aircraft I only have it installed on one computer and I do have back-up disk
what to do? I was asked to enter the key two times ? why ?
I was able to re-install B1 from back-up so all is not lost.
and it was working well.
thank-you for a re-set if the key. [I do believe I have used three up to this point]
7 (edited by Luke173 2015-05-02 16:31:32)
First try, first CTD
Mac OS X 10.9.5
XP 10.35 r1
HAd the FP Set up, released Brakes, rolled 3 meters, ctd
Mac log is also in the log.txt
good day,
a log.txt would help to solve the issue.
Mac OS X 10.9.5
XP 10.35 r1
the first post never lets me add files, so I do have to edit the post, which may take some 1-2 minutes wink
First try first crash.
MacOS 10.10.3, XP 10.35r1
Preflight -> Push back -> lining up -> Accelerated on RWY -> CTD
All betas are not stable, not flyable for me right now.
Version for me with nearly no CTD was/ is V1R2.
Sorry problems attaching crash report files. Immediate CTD on all attempts to fly whilst taxi before takeoff. Version with occasional crash V1R2 as above. Same version of OSX as Homer.
good day,
if you want some help read the txt i attached:
http://jardesign.org/forum/misc.php?act … str=49t995
good day,
Mac OS X 10.9.5
XP 10.35 r1
Attachment icon captbullett's instructions on CTDs.rtf 14.37 kb, 411 downloads since 2015-05-02
Thanks & cheers
Franz
Yes, I am an idiot - fix all, but not this smile sure, will fix today!
14 (edited by Homer.Simpson 2015-05-02 17:35:27)
So trying to do a second test flight with 1.1b3 but now with all sound plug-ins (3D sound 2D sound 1D sound plug in) disabled. Same result CTD when accelerating on RWY. So to my mind the failure which results in the CTDs is in the main plug-in or SASL plug in.
Accidentally I closed the Mac Crash report and couldn't recover it. So only XP log and bb log attached.
good day,
Sorry, I an not sure what understand about keys. What wrong exactly?
As I see, all typical MAC log have crashed tread like this
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   mac.xpl                           0x00000000a10c733f 0xa107d000 + 303935
1   mac.xpl                           0x00000000a10c40c3 0xa107d000 + 291011
2   mac.xpl                           0x00000000a10d08e6 0xa107d000 + 342246
3   mac.xpl                           0x00000000a1095384 0xa107d000 + 99204
4   mac.xpl                           0x00000000a10a2d7e 0xa107d000 + 155006
5   mac.xpl                           0x00000000a1080ded 0xa107d000 + 15853
6   XPLM                              0x0000000013751291 XPLMDispatchDrawingHook(int, int, int) + 121
7   XPLM                              0x00000000137515bc XPLMDisplayDoDrawingHook(int, int) + 740
8   com.laminar_research.X-Plane      0x0000000100927492 XPPDoDrawingHook(int) + 114
9   com.laminar_research.X-Plane      0x00000001007916bd APP_update_panel(panel_draw_type, int) + 1069
10  com.laminar_research.X-Plane      0x000000010092dad3 grab_one_panel_texture(OGL_framebuffer*, int, int, int, int, int, panel_draw_type, int, int) + 1395
11  com.laminar_research.X-Plane      0x000000010092e476 grab_panel_textures(int, int, int) + 2198
12  com.laminar_research.X-Plane      0x000000010060f44f WORLD_scene_per_frame() + 3071
13  com.laminar_research.X-Plane      0x0000000100b22f95 APP_update() + 3061
14  com.laminar_research.X-Plane      0x0000000100b256d2 MACIBM_post_event_proc() + 226
15  com.laminar_research.X-Plane      0x0000000100c793cb WIN_run_app + 43
16  com.laminar_research.X-Plane      0x000000010061d053 main + 1075
17  com.laminar_research.X-Plane      0x00000001004918c0 start + 52
So, "0" is a crashed module with crashed functions.
It is SASL base plugin mac.xpl with different functions address. As the man who build this mac.xpl set debut options disable and as result we can't read name of this (crashed) functions, just its address, what can give nothing. So, I talked with Ramzess and he promise give build and give for tests mac.xpl with debug functions on. If will be, we will understand what function(s) called from lua give mac crashes. Thats a plan, but need wait MAC OS SASL build with debug info option.
So did a third test fly but this time with deactivated A330 plugin (plugins/330/mac.xpl). Well had to take off with cargo doors open, but go no CTD. Did a fourth flight, on which I activated it again and while standing on the gate got a CTD. So maybe the mysterious failure is located in this plugin? or Was it just randomly
Reports of the 4th flight.
18 (edited by Luke173 2015-05-02 19:28:25)
Here's my clean XP installation 1v1b3 CTD
Mac OS X 10.9.5
XP 10.35r1 without no nothing (not even terrain scenery...)
Mac didn't give me no crash log this time
I was just climbing out of LSZH, was a bit to slow, hit the AP button, ctd
If my plugin - a reason for CTD, this very easy to determinate, course all my plugins include debug info and easy to check in what place of code error happen. As example - 330 plugin -
I just put for test a crash-call error to main function to string 159 and build mac.xpl and start a330.
Get a CTD and check "0" string in crashed thread. As you can see - crash reporter point us to string with bug code - Main.cpp file, "Main" function, string 159. - Easy to determinate.
http://jardesign.org/forum/img/m/22/t/p19kb3htkc1ltl763ns61kt01jgt3.jpg
http://jardesign.org/forum/img/m/22/t/p19kb3ihgb1a95pg7v66lcv1fa05.jpg
Easy with my plugins but not easy with SASL mac.xpl
I downloaded version b3 and when I wen to enter the key I was asked to enter it two times , the aircraft would not load and I wait for your instructions ?
no more keys and did not use all of them as i did not need them i have one computer installed with your aircraft
thank-you
good day,
21 (edited by J.A.Romanov 2015-05-02 22:57:54)
thank-you
good day,
Ask key 2 times - not normal. Better and easy way - redownload it and reinstall it clear. You can send me serial for check direct from form here http://jardesign.org/a330/
issue resolved, I was using the A320neo key instead of the A330 Key
My Bad …
thank-you for the help
thank-you
If problems are not resolvable because of SASL Mac.xpl. Does this mean this aircraft will never be stable on Macs ? Not a critique, just a question.
I don't know exact future. It is not depend from me, but until a lot of SASL-based aircraft have this problems, we will hope to resolve it.
Thanks for the response.
Kevin
