Topic: Help - MWCR Airport in Cayman Islands
Hello All, Could someone modify the MWCR airport for X-Life traffic?
Thanks in advance.
Re: Help - MWCR Airport in Cayman Islands
I tried to modify this airport using the airport editor and everything went well and I saved the airport. As soon as I turn the traffic on, the sim crashes.
All I did with the editor was make sure the holding areas are correctly identified and that the taxiways and gates were connected. The only "?" marks were from the ground traffic route.
What could be causing the crash?
You will have to do it again. After opening the editor save the file first, close the editor and re-open , all the "?" Mark's for the ground traffic will disappear. You will now see only the x -life traffic that need to be fixed.
