1 (edited by coolh 2018-08-10 01:40:43)
Topic: Wrong Pushback distance
Hi, my name is Fernando, am new with the tool and on the forum.
I am building a new airport for buenos aires city in argentina (SABE), (pending approval on scenery gateway)
I know that there is a existent ATC route for X-Life, but it don't match the real airport layout, so I built a new one matching the new airport.
The problem is that the airplanes start the turn way before the apron taxiway (check attached screenshots)
From my understanding they should detect the turn from two conditions:
- sharp turn on the ATC Route
- second node of ATC Route
None of those conditions match in the attached screenshoots.
Am using version v.4_210718 / X-Plane 11.25 / Windows 10 last patches applied
Thanks for the help!
Best Regards
Fernando-
Re: Wrong Pushback distance
Hey,  try with version 3, version 4 has many issues. Just install it , use the same user name and password and open the existing file, check if it does the same.
