Topic: TugMaster
Hello there. I am having a small issue with TugMaster. I am using it with the Zibo Mod 737-800X and have noticed when in cockpit view, and I select LOCK on the CP, the cockpit violently vibrates (Bad turbulence levels) for a second. The same haens when I press Unlock. When I select the up or down arrow in the CP for pushback, the aircraft pushes back OK, but the cockpit view vibrates unrealisticlly (Like BAD turbulance)
I thought it may be the XPRealistic plugin affecting TugMaster, so I have disabled XPRealistic (physically moved it from the Scripts folder) so it cant affect the TugMaster plugin, but still the issue remains.
I also dont have headshake installed, so not sure what can be causing this
Chris
