1 (edited by cpfoto1964 2018-07-30 21:46:29)
Topic: Help needed: FILE NOT FOUND when trying to enter SID/STARS (A320)
Dear simpilots,
I am new to JARDESIGN and installed the JARDESIGN A320 successfully under LinuX and X-Plane 11 (last version).
I loaded a Flight Plan into the FMC :
EDDM SID RIDAR L173 GUPIN DCT KOVAN T893 DISKI STAR ELLX
when I try to select SID/Stars from the lines (first line for EDDM), (last line for ELLX) I always get the message
"File not found" in the FMC.
Any help would be appreciated,
kind regards Christoph
Re: Help needed: FILE NOT FOUND when trying to enter SID/STARS (A320)
JarDesign can be complicated at the beginning. Do not worry though, you can find the answers in this forum or at rush essays. You will learn a lot for sure and that will help you get more out of JarDesign.
This is exactly what I’ve been looking for. It solved very quickly the problem I was having.
gmail login
