I'm having many issues with V4, previous version worked well.
1) The new menu is very large and gets in the way of your instruments. After takeoff, regardless of if you have filed a flight plan or not, this menu always pops up, covering the complete cockpit, or outside view. This menu should stay hidden unless the user commands it open! The menu in the previous version was much small and more transparent.
2) Once the menu is open, i can find no way to close it! Pressing the red dot in the corner does nothing??
3) I have the deluxe version, but see no options for the deluxe menu which was very convenient
4) To solve most of the issue above, keep the menu closed unless the user asks for it to open, either view a small menu like before, or, a very good solution would be a key press which toggles the menu open and closed, this would be perfect, and could be mapped to a joystick button. Currently I use the keyboard to do the commands, but there seems to be no keyboard command for menu open close.
5) The problem of departing aircraft taking off to fast is still there, they seem to go 400kts immediately after takeoff so you always have TA/RA warnings after takeoff as all following aircraft fly past you! It would be good if they had a 200kt limit to 2000ft agl then 250kt to 10'000ft, that would solve the issue completely.
6) A suggestion, I fly 50% with flight plan, 50% withouth. It would be really good if you could have aircraft at the arrival airport, even without a flight plan. One way I do it, is turn of X-life in cruise, then about 10nm from the arrival airport, turn it back on, and traffic is generated at the airport (usually). Would it be possible for traffic to be auto generated at airports within say 20nm and when your aircraft is under 5000ft?
7)I seem to often have a bug where the runway is use is opposite to the wind direction, not always, but quite often. Is this a known bug? For instance, ENBR, Bergen, wind 300 at 10 kts, RW in use 17?
8) Lastly, it would be nice if you chose not to file a flight plan, that the ATC just ignored you, traffic generation at destination airport would be great in this instance (see point 6).
For now I am back to the previous version, I can post pics or videos of the problems mentioned above.
1. it is resizeable with mouse wheel. Please read manual.
2. fixed with v4_210718
3. "deluxe" menu exist only at free version to allow you register plugin and get Deluxe version
4. Custom command already exist. Please read manual.
5. "seem to go 400kts" - really seems, speed is Ok and below 250/10000 at least
6. To know what airport should be used as arrival, plugin expect from you short plan, at least EDDF DCT EDDM as flightplan.
7. Plugin read wind from real servers and select RW using this data. If you not use real weather in your sim - yes, this may happen.
8. No way to know what apt should be used as destignation. For v4_210718 you may turn on traffic and no more - you will get departure and transit traffic in this case.
v4_210718 will be posted today.
