Hello. Thanks for the app, always fly with it. There is a question. I'm flying, I have a failure, urgently need to sit down, X-life what to do? 7700 and nothing happens. Thanks.
JARDesign Group Board → Updates & General Discussion → X-Life ver 4 for X-Plane 11
I have problems with the sound from the ATC. I can hear tower etc. You don't hear redback.
WIN 10 Prof, XEnviro, X-Plane 11.40
How do you fix that ATC works completely?
Thanks for your help
Everytime CTD
in log:
XL: 387 : Autogen flight: C172 g2
0:24:04.854 E/ATC: OH BOY! EDDM SEEMS TO MAYBE HAVE A ONE-WAY PATH TO A DEAD-END!
0:10:47.559 FF: Aircraft.Cockpit.MCDU1.Key1.Target
0:10:48.213 FF: Aircraft.Cockpit.MCDU1.Key19.Target
0:10:49.017 FF: Aircraft.Cockpit.MCDU1.Key16.Target
0:10:49.519 FF: Aircraft.Cockpit.MCDU1.Key1.Target
0:10:50.223 FF: Aircraft.Cockpit.MCDU1.Key20.Target
0:24:14.196 E/ATC: OH BOY! EDDM SEEMS TO MAYBE HAVE A ONE-WAY PATH TO A DEAD-END!
0:10:51.127 FF: Aircraft.Cockpit.MCDU1.Line6.Target
0:24:15.533 E/ATC: OH BOY! EDDM SEEMS TO MAYBE HAVE A ONE-WAY PATH TO A DEAD-END!
0:24:17.303 E/ATC: OH BOY! EDDM SEEMS TO MAYBE HAVE A ONE-WAY PATH TO A DEAD-END!
XL: 397 : Autogen flight: C172 y3
0:10:56.052 FF: Aircraft.Cockpit.MCDU1.Key20.Target
0:10:56.504 FF: Aircraft.Cockpit.MCDU1.Key15.Target
0:10:57.007 FF: Aircraft.Cockpit.MCDU1.Key19.Target
0:10:57.409 FF: Aircraft.Cockpit.MCDU1.Key20.Target
0:10:58.263 FF: Aircraft.Cockpit.MCDU1.Key21.Target
0:10:59.218 FF: Aircraft.Cockpit.MCDU1.Line8.Target
0:24:31.842 E/ATC: OH BOY! EDDM SEEMS TO MAYBE HAVE A ONE-WAY PATH TO A DEAD-END!
0:11:00.976 FF: Aircraft.Cockpit.MCDU1.Key30.Target
0:24:34.068 E/ATC: OH BOY! EDDM SEEMS TO MAYBE HAVE A ONE-WAY PATH TO A DEAD-END!
0:11:03.137 FF: Aircraft.Cockpit.MCDU1.Key30.Target
0:11:03.388 FF: Aircraft.Cockpit.MCDU1.Key30.Target
0:11:03.589 FF: Aircraft.Cockpit.MCDU1.Key30.Target
0:24:37.335 E/ATC: OH BOY! EDDM SEEMS TO MAYBE HAVE A ONE-WAY PATH TO A DEAD-END!
0:11:04.393 FF: Aircraft.Cockpit.MCDU1.Key15.Target
XL: 407 : Autogen flight: A320 VVC
0:11:05.097 FF: Aircraft.Cockpit.MCDU1.Key19.Target
0:11:05.549 FF: Aircraft.Cockpit.MCDU1.Key20.Target
0:24:39.772 E/ATC: OH BOY! EDDM SEEMS TO MAYBE HAVE A ONE-WAY PATH TO A DEAD-END!
0:11:06.655 FF: Aircraft.Cockpit.MCDU1.Key21.Target
0:24:41.383 E/ATC: OH BOY! EDDM SEEMS TO MAYBE HAVE A ONE-WAY PATH TO A DEAD-END!
0:11:07.409 FF: Aircraft.Cockpit.MCDU1.Line8.Target
0:11:09.368 FF: Aircraft.Cockpit.MCDU1.Line8.Target
0:24:46.092 E/ATC: OH BOY! EDDM SEEMS TO MAYBE HAVE A ONE-WAY PATH TO A DEAD-END!
0:24:49.086 E/ATC: OH BOY! EDDM SEEMS TO MAYBE HAVE A ONE-WAY PATH TO A DEAD-END!
0:11:14.243 FF: Aircraft.Cockpit.MCDU1.Key12.Target
XL: 417 : Autogen flight: C172 y4
0:11:14.846 FF: Aircraft.Cockpit.MCDU1.Key5.Target
0:11:15.499 FF: Aircraft.Cockpit.MCDU1.Key16.Target
Примерно одно и тоже каждый раз,
I think there is a small problem with EICK Cork, it's clearly shown on X-Life airport map, but trying a flight from there X-Life says airport is not verified.
I used to get a real traffic on X life but now I have like B737 Singapore airlines in LSGG. What can I do to get more easyJet, Swiss and more realistic traffic?
Thanks !
I seem to be having problems with my xlife plugin.After installing the program, the online reading of the software is very slow, xpalne will be stuck, and the weather data read is incomplete, and it will wait more than 10 minutes each time it starts or reads data. I need to unplug my network card to continue.
Аналогичная ситуация.
Everytime CTD
in log:
0:11:15.499 FF: Aircraft.Cockpit.MCDU1.Key16.TargetПримерно одно и тоже каждый раз,
Xplane crash each time loading Xlife
Osx Catalina
Xplane 11,41
thx by advance
A few requests i would like to present for evaluation:
- AI-Traffic with or without the ATC control part.
would be great if the ATC-part could be turned on or off by a simple checkbox.
I love how a flight plan is created but it does not go into my add-on plane (e.g. 737 ixeg).
- Please double or even triple the traffic density please. allow more traffic.
To date airports seem still underpopulated compared to their real life counterparts.
How about just copying the real life traffic data? (not live, but record it for a limited time.)
- Missing aircraft types and airline brands
I feel like not seeing many aircraft that can be seen in real life.
- JAR update when game launches drags performance to ground. many users report even crash.
I recommend updating x-life airports process only on demand via menu.
Too many add-on developers update their stuff at the very
game launch which has an immenent negative impact on the games overall resources management.
- i can only hear atc for my flight. why is there no conversation for the other planes?
Thanks for considering.
I just had to re-download X-Life and looking at the version running I'm seeing v231219, has there been an update not showing on the list. I can't see this version on the update list.
When I shut down XP with this version I get a message saying, X-Plane 11.41r1 quit unexpectedly, this started happening a couple of updates back, v250719 I get no message on shut down of XP, no idea what's causing the problem. Having said that X-Life works fine during a flight.
Screen shot showing the new version number and the message on shutdown attached
I seem to be having problems with my xlife plugin. The atis page is very basic and does not show any weather data whatsoever. I am using FS Global Real Weather and Skymaxx pro.
Here is screenshot and log file.
Any help would be appreciated
Ok I did find however when the METAR goes to update it displays this message in the log.txt:
XL: 16 : Airline flight: CRJ7 AFR
XL: 20 : Autogen flight: A321 SVR
XL: 24 : X-Life:Curl (CurlUpdateSheduler) = EGKK
XL: 24 : JARDesign plugin error: Unsupported protocol
XL: 24 : X-Life:Curl (CurlUpdateSheduler) = EGSS
XL: 26 : MessageGreen: The Flight Plan was submitted to ATC successfully.
As far as I know it should show like this one I found on the forum:
XL: 13 : X-Life:Curl (CurlUpdateSheduler) = KPAE
XL: 13 : JARDesign plugin: D:\X-Plane 11\Resources\plugins\X-Life\Metar/KPAE.TXT file updated.
It seems that it has trouble updating due to an unknown reason. only started happening since i updated x-plane to the latest version.
Hi. First of all, great plugin! I'm running XPlane11 on an unfortunately old CPU (i7 920!), yet XPlane (and XLife) is running quite well (30+ FPS, with good graphic settings). I previously never had other planes around, as my CPU couldn't handle it, so this plugin is a real blessing. Thanks!
Everything seems to run just fine, except one thing... When I EXIT XPlane, it seems (perhaps XLife) causes Windows to (soft) crash, as well as XPlane. XPlane will just sit there, with the spinning 'busy' mouse pointer, and if I TAB out (only possible if I CTRL+ALT+DEL to get the Task Manager, which then lets me TAB), I see the Windows Stopped Responding type of Win alert, as well as an alert for XPlane. Clicking on Close Program on the XPlane alert allows me to then exit and then just close the Windows alert. Windows is then running just fine... just a messy exit out of XPlane. Happens every time, since I installed XLife, so I'm assuming that's the cause. I'll have to do some tests.
Info from my Windows log:
Log Name: Application
Source: Application Error
Date: 16/02/2020 9:51:56 PM
Event ID: 1000
Task Category: (100)
Level: Error
My specs:
Win7 Premium, i7 920 (yikes), 12gigs RAM, XPlane11 (Steam version), NVidia GTX 1060 3G
XPlane Plugins: 124thATC, XCamera, XLife (Free), XRealistic, and the LAU LOD mod... all previously working just fine together, so it seems that (for whatever reason) XLife is having some trouble on exit.
Again, everything seems to be running really nicely, until I actually exit XPlane.
I've attached the Log file. I'm not sure where to find the dump file, though.
I hope someone might be able to tell me what might be specifically causing the 'crashes' on exit.
I'm considering getting the Deluxe version, but I want to address this issue first.
Cheers!
(Please move this post to the appropriate location if it's not in the right location)
I have a similar problem on Mac, see a couple of posts above yours. As with you X-Life works fine, I just get an unexpected quit message from XP when I shut it down.
first thanks for the great xlife plugin.
I had a problem in LIRP today. In front of me four airplanes were waiting for a CRJ2 at runway 04R. After 10 minutes the plane came in, but turned off again at 400 ft. This procedure was repeated and no aircraft was cleared for take off. Can you please check this?
Second thing:
With me on the Mac the same problem as colinah. When I finish XPlane I get a unexpected quit message.
text line for flightplan is not long enough.
when craeting a flight plan with the x-life window, the result will show along 1 line,
but you can only see half the flight plan as the text line is not long enough to show the end of it.
sizing up or down the window will not change that.
This is relevant because i need to enter the given waypoints into the airplane fms, did not find an automatic way of doing so.
any idea how i can transfer the shown flight plan line into the airplane FMS?
thanks for help.
This is relevant because i need to enter the given waypoints into the airplane fms, did not find an automatic way of doing so.any idea how i can transfer the shown flight plan line into the airplane FMS?
thanks for help.
You could go with mouse klick on text line and then go with right coursors to the end of the line to saw all plan.
For JAR planes is no problem to export to FM with press export button send to FM.
For other plane is better to make plan with Simbrief an then export to txt file for X-life and another to format that your plane use for flight plan.
Hey there! There are tons of Ai Traffic Addons lol. I have a simple Question. Is it possible to see military Flights in xplane with x-life? I live in germany and i like to fly the ECR Tornado. It would be awesome to see some in ther air and Eurofighter or F16 from Netherlands. Thx
almdudler wrote:text line for flightplan is not long enough.
thanks for help.
thanks Darko.
the cursor thing won't work, seems like what is shown in the textline is what you get, not more.
i am aware there is flightplanning tools outside the sim, but this is against my will to have a complete sim, not many fractioned applications apart from each other. A flight sim should include the whole process, from weather and route planning to weight and balance, fueling, passenger count, atc, etc. etc.
it's 2020, and time to get things done better.
if you transfer the flight plan from another source, you will net be able to have the x-life atc leading you,
unless type the whole flight plan twice or more. that is why things should be integrated (1 process).
so, you are saying the x-life flight plan is transferable to the JAR A330 but not the IXEG 737 ?
mmh,... ok.
On my setup if you hover the mouse pointer at the right end of the flight plan line and left click a fishing line appears between the letters, then use the right arrow on the keyboard and it moves to the right revealing the hidden part of the plan.
It only moves one letter at a time though, it would be a bit better if it could be moved quicker by holding down the arrow key. That would be helpful if the flight plan follows the same airway for a long distance through several waypoints.
I'm finding that gate names are being corrupted on loading of the Airport Editor. When I save changes in the editor, the corrupt special character strings are written to the xlf file. This causes X-Plane to crash to the desktop when I attempt to start X-Life. If I manually edit to xlf file to remove the corrupt character string, then X-Plane does not CTD.
Here's a picture of corrupt names. This has happened multiple times, not usually to the same gates.
Any idea what's going on here and how to prevent it?
I have exactly this experience when I want to edit RJAA.xlf for Narita, RJAA. After clicking Airport Editor I get a CTD. Not sure how to avoid it, but mine happens in #GATES/STANDS INFO, so I suspect it will disappear when I have edited the gates.
Jan
Hi JAR Design Group
Is there still a development on xlife or is the plugin only for cashing money.
Many open issues mentioned many times in this forum.
Hi JAR Design Group
What are remaining issues according to you .
For me it works perfectly …
when i open the x-life its message to me that its needed to install opensceneryX but i have the latest version of it
Hello Guys,
since Catalina i cant use Xlife
Crash when loading Xlife
Someone can help ?
Thanx by advance
