426
ivota wrote:
artox67 wrote:
Hey Mr. Jar
Threaded optimisation .. On
is a pain in the ass. All cores are running 98 - 100%
Not usable
Cheers
What is your pc configuration?
Intel i7700K OC4800
ASUS GForce 1070 8GB OC 2000/4700
16GB RAM 3000er
3x 500GB SSD
427
Здравствуйте!
На своей системе i5 9600K, 16GB, RTX2070 разницы по фпс с "вкл/выкл/авто потоковой оптимизации" не заметил. Но! В любом случае, если X-Life будет поддерживать потоковую оптимизацию, то это гораздо лучше. Т.к., отключение влияет и на другие игры/приложения/плагины. Даже в подобном случае это плюс.
Спасибо!
428
Sasha wrote:
Здравствуйте!
Спасибо!
Agree!!!
429
I run X-Plane 11.35 on Mac, just update to X-Life v140819 and the cooling fan seems to be coming on as soon as X-Life starts. I'm sure that didn't happen on v250719, is there anything in the update that could cause that to happen.
If there is can it be rectified or I will go back to v250719.
430
250719 work with CPU load with the same way. At least for me.
Link available, sure http://www.jardesign.org/x-life/downloa … 250719.zip
431
Thanks for the quick reply J A R I will check it out. For your info v 140819 did run perfectly with no problems. It may well be that I've never noticed it before.
432
Hello, since the new version installed every second landing will be a go around. This is maximal annoying. No Aircraft in front or on the RW.
What's wrong?
regards
Artox
433
Hi J A R, re my post number 430, I reloaded X-Life v250719 set it up and the cooling fan did not come on, in v140819 it came on immediately.
I see from the release notes that the update was to do with nVidia graphics threaded optimisation, I'm running XP on Mac using AMD graphics. Could that be causing the problem. Version 140819 does run correctly, but the cooling fan is on all the time.
434
What's wrong?
regards
Artox
Hmm.. I am not get mass report like this and we not meet this during out test flights too. May be you can give info about arrival airports what you landing with GA, how many times this happen, screenshot of your X-Life settings panel.
435
Thanks! Sure, 140819 generate much many aircraft in the air per time (and make muck more calculation fore this), and also make more calculations to make aircraft moving smooth and make many background calculation to minimize/avoid microfreezes what happen for 250719 (and early versions).
But I am notice this issue and will think about this.
436
Ok in order of my last flights:
LTAI ok
EDDK GA
LGZA ok
EDDS ok
EDDT GA
LDDU GA (one aircraft on aprox 2000FT above RW hanging and flickering) (XP traffic off no other traffic tool)
EDDT ok
LOWI ok
EDDK GA (starting from LOWI waiting on HP RW08 for 20 min every AI Aircraft was in GA)
And finally a picture from my settings. Will say everything is working very well except this GA behavior.
settings
http://jardesign.org/forum/img/m/8466/t/p1dig063jr1hu8kli369nhl1kna3.jpg
437
LTAI ok
EDDK GA
LGZA ok
EDDS ok
EDDT GA
EDDT ok
LOWI ok
settings
Thanks for this info! Anyway, Runway interval better to be set on 2,5 minutes may be. Long interval allow you to have more distance from one aircraft to another.
438
After the update x-life (Deluxe) v.4_140819:
Why does x-life close x-Plane 11, when I loading airplans witrh the button from x-life?
And new: When I installed an old version x-life, it does it too.
Why?
439
Why?
Please www.support.jardesign.org with this, and attach log.txt file (just after this issue will happen again) there.
440
When flying with Concorde, the supersonic cruise flight level at mach 2.02 is between FL 500 and FL 600, according to the remaining fuel (ascending cruise).
Unfortunately, these flight level cant be selected when using X-Life :
- when entering a flight plan, cruise level is limited to FL 410
- during a flight, the cruise level can be changed, but not higher than FL 510
- in both case, any value higher to the limits is considered as FL 5 (yes, 500 ft !)
Is it possible to modify these limits up to FL 600 ?
Antec 1200 - BeQuiet 750W 80plus platinium - Win10 pro 64 - X-Plane Steam 11.36
MSI RTX 2080 Aero 8 Go - ASUS 27" 3D 120 Hz + IIYAMA 19" - Logitech G27 - Thrustmaster T.16000M
Asrock X99 Extreme4 - Intel Xeon E5-2699A v4 (22c/44t @2.8 GHz) - Corsair H75 - 64 Go DDR4 Kingston
SSD Samsung 960 PRO 512 Gb NVMe - SSD Samsung 840 PRO 512 Gb SATA3 - HDD Western Digital Black series 6Tb SATA3
441
Set IGNORE these rules at flightplan
442 (edited by Paul-76 2019-08-19 17:39:33)
Please, can you see , where is the mistac in the log.txt?
Thank you!
443
Thank you!
The CTD happen just after:
XL: 22 : X-Life:FileIO:Cant open file D:\X-Plane 11\/Custom Data/Bluebell XL/PackP/AT42/AT42.txt
So, there is a problem with Bluebell XL pack installation.
444
Thank you for help, it is now all ok.
445
Not sure if this is just my system, but if I'm given a take off runway by X-Life v250719 and I try to change it to another runway as soon as I click that runway XP crashes.
This doesn't happen changing a landing runway.
Another small problem, I can never get take off clearance at EGKK Gatwick as there are always a lot of stationary aircraft waiting.
I generally just take off and then get a telling off from ATC.
446 (edited by nabz 2019-08-21 17:32:58)
Thanks but already tested, it doesn't work. That is the reason why i posted the issue.
As soon as you ask for "Delivery", you are required to fly FL 5 or FL 6, instead of FL 500 ou FL 600.
447
Sure, I can add this FL to X-Life. You may contact me skype j.a.romanov - I will prepare build and send it to your for tests.
448
It sounds great, thanks !
449
New xpl used with 0819 build works great for me so far with threaded optimization on for NVidia 970. Frame rates are much better and more like what I used to get with X-Life. I feel like a lot of progress has been made and overall performance is much improved. Thanks JAR! Keep up the improvements!
450
Добрый день, Евгений! Очень понравилась последняя версия x-life, особенно возможность составления флайт-плана и диспетчер. Но, при включении плагина, стал подвисать симулятор, причем очень значительно, картинка постоянно замирает на секунду, а иногда даже вылетает сим. При отключении плагина все нормально работает. Что-то можно сделать в этой связи? Комп не такой уж слабый: i5-7700, 16Гб, 1060 6Гб. Спасибо.
