Topic: FF 777-F - How to make a different set for passenger and freight
Hello all,
I have recently purchased the 777 extended pack from Flight Factor. The different models of aircraft all call the same set for ground handling. Thus, when calling for ground support for the freighter, I get all the catering and stairs for the passenger aircraft.
How can I name/rename an aircraft or set to use a different set for the freighter vs the passenger configuration?
I've attempted various renaming items, but none seem to separate one version aircraft from another.
Thanks for any help that can be offered.
Kris Roberson
Re: FF 777-F - How to make a different set for passenger and freight
Next update will support reading .set file from aircraft folder. In this case you may have separate aircraft (pax/cargo) with .set in each one.
