Topic: REQ ShortFinal KABQ X-Life
Can someone please upload working KABQ X-Life files. I would love to use this airport with X-Life traffic.
JARDesign Group Board → Custom ATC routes for XP Airports → REQ ShortFinal KABQ X-Life
Yes, please if someone could kindly create routes for KABQ for us. Thanks.
Sorry there is an issue with my KABQ routes that I need to figure out...
EDIT: I made an KABQ.xlf but it still has an error(s) that I can't find. Please let me know if you find it.
The scenery is the payware by MisterX6 (shortfinaldesign)
http://store.x-plane.org/KABQ--Albuquer … p_701.html
what kind of errors do you get. Other than some runways line being holding point i dont see other errors<<
Because i dont have the airport version you have i can not change anything and save the file. I will tell you where i found a couple of errors.
Runway 21 - Check the holding lines and the runway line< check picture rwy 21 and compare with yours
Runway 12 - Check the runway length, you have on rwy a holding point line check picture 12
junction twaxiway B^ with A does not have connection to the runway 08/26 see picture junction
The last one will be E1 taxiway junction with E and G i made a before and after picture to show you how i would do, but keep in mind i don`t have the airport you do, i just opened the file on default X plane 11 airport. So your might be right, i just want to show you just in case it is the same.
i have a recommendation picture to look, try to keep them simple in curves, like in the picture
let me know if this solve your problems
i just notice this: you don`t see the pictures name, i guess, but i think you will figure out from the pictures witch one i am talking about
I've tried the X-Life file that he uploaded and basically it seems that the problem is that the X-Life gates are not aligned with the actual airport gates. At least that is the only problem that I've noticed. It does pretty much ruin the X-Life experience at that airport though. ![]()
Thanks guys. I'll have another look when I get a chance. X-Life works for me at KABQ, though. It just says there is an error when I save the xlf in the airport editor but I can't find the red question mark.
Can you please upload your X-life files?
There is one, check the earliest messages.
Yeah but that xlife file is pretty messed up.
Lol, is it that bad?
I dont have the airport, and dont whant to buy it just to repair the traffic. I recently did a video on how to repair or design a new airport just with X life Airport Editor. You probably know all this steps , I dont see how bad the traffic could be, you just have to fix the problems, move the lines to match with the stands/gates.
Here is the link for the video:
