Topic: X-Life framerate dropping
Hello together,
I have problems with my frame rate using x-life.
I experienced the following data (all with the same airplane (Cessna), same airport, same settings for wheather (CAVOK), grafics, monitor setting, etc.):
fps without x-life: 35-45
fps with x-life version 2.2r1: 11-12
fps with x-life version 2.2r2: 11-12
This framerate drop with x-life is threatening.
I looked for my ressources (task manager data):
x-plane with x-life took 30 % of the CPU, 5 GB RAM, 30 % GPU.
x-plane without x-life took 41 % of the CPU, 5 GB RAM, 30 % GPU.
And here are my system data:
Windows 10 Home 64 bit, 32 GB RAM, Intel Core i7-3770K CPU @ 3,5 GHz, NVIDIA GeForce GTX 1070 with 8 GB onboard RAM
What can be done to avoid framerate dropping to 25 %?
Thanks for any proposals and help.
Kind regards
Horst
