301
Yeah, I know that there were recently some complaints about this bird but unfortunately I have to add another one to it. Till v3r4 I flew this bird just as usual.
Today I updated to r5  and well I can't get the activation window to pop up. Furthermore I get the message warning in the lower left corner that SASL could not initialize because the aircraft is not activated. Well this makes sense to me but does not help me in any fashion to get this activation window to pop up and to activate it.
I run the bird on Win10 as an admin, I have the latest JAVA version isntalled and all Win C++redistributes are installed.
Any help is highly appreciated.
P.S.: I also deactivated many plugins to avoid any issue on this side.
302
ola boa noite alguém tem o  Ciclo Navigraph AIRAC 1810 do JD330 pq baixei e não veio fico muito grato....
303
windows 10 newest c++ and java, x-plane 11.25, JD A330 3 r5 mcdu is dead, no sound, ND display is dead.
My Fleet: FF A320U, FF A350, FF B763, FF B757v2 ext, JAR A330, JAR A320, ToLiss A319
Utilities: X-LIFE Deluxe, FMcar, EFASS, XEnviro, X-Camera
304 (edited by jim912137 2018-09-25 09:33:10)
I use JD330 r5 for x plane 11.25.
The plane will slight turn left when it is landing ground about 40ft even if no wind.
I have testing other plane but haven't occurred the problem at same environment.
Kindly JAR team test the situation and fix the problem, thank you.
305 (edited by wesader 2018-10-01 13:13:50)
Hi JD330 products not work at all activation window doesnt appear. cant activate product i dont why cuz it is allredy activated.
Problem solved !! smile
306
Hi, recently i downloaded the latest version r5, and following step by step "how to install", but when i start X-plane 11.25 the aircraft even shows in the X-plane window. Any help? i'm doing something wrong?? appreciate your answers...
307 (edited by alain.bo 2018-10-08 05:48:12)
sorry wrong board
308
I also have the problem with the sound and MCDU and ND being dead.
Some help is appreciated.
309
I found these error's in the log file.
E:\SteamLibrary/steamapps/common/X-Plane 11/Aircraft/JD330XP11/plugins/fmgs/win.xpl : Error Code = 1114 : A dynamic link library (DLL) initialization routine failed.
E:\SteamLibrary/steamapps/common/X-Plane 11/Aircraft/JD330XP11/plugins/sound1d/win.xpl : Error Code = 1114 : A dynamic link library (DLL) initialization routine failed.
E:\SteamLibrary/steamapps/common/X-Plane 11/Aircraft/JD330XP11/plugins/sound2d/win.xpl : Error Code = 1114 : A dynamic link library (DLL) initialization routine failed.
310 (edited by Errandil 2018-10-10 18:21:06)
I did a rollback to R4.
MCDU Works now, only still no sounds
311 (edited by Vrumugun 2018-10-14 23:53:04)
Vrumugun wrote:
i have a strange issue and i'm not sure what is causing it. Usually it get quite good frame rates when i'm flying the JAR A330: Around 40 fps on the ground and up 60-70 fps while flying (depending on weather and other stuff).
But when i'm doing long haul flights sometimes the frame rate will drop down to 20 or even below (18 or something) and it will stay like this.
I did another long haul flight today. 11 hours from ZSPD to EDDF. I did remove all custom scenery and many plugins (i still use the following plugins: ground handling, better pushback, X-RAAS2, fly with lua, project Fly). When i was near my destination i had again performance problems. The default scenery for EDDF did not load correctly (runway lights missing).
Is anyone else doing long haul flights with the JAR A330? I'd like to know if this is a local problem with my system or if this is related to the airplane (maybe some memory leak???). I have the BSS sound installed for the A330, maybe i will reinstall the JAR A330 and test it without BSS sound.
I'm using X-Plane 11.26r2. Maybe i will try to reinstall X-Plane...
Some days agon i did a 16 hours flight with another airplane and i did not have any issues.
Any opinions on this? I would like to fix it, because the JAR A330 is my favorite airplane right now and i really like to do long haul flights. sad
312 (edited by yarplaz 2018-10-16 10:40:25)
Hey! I have the exact same issue with longhauls! When a flight is longer than 6 hrs or something like that!
I was thinking I have something wrong with the sim, but it's the plane's issue!
Also, my GPU usage frops to like 30% and even lower, fps dives down to 25-30. I have GTX 1070, i5 8600k, 16 gb ram.
So disappointing, cause I bought this plane specifically for longhauls!
UPD: could it be related to projectFLY? I am using that too smile
313
Just updated to the latest A330 and A320.
Unable to Activate either aircraft.
I get a "Error activating aircraft" message.
Thanks in advance
314 (edited by Vrumugun 2018-10-21 15:45:26)
Nice to see that i'm not the only one with this issue. smile
I did a test flight Friday to Saturday with the following changes:
- reinstall JAR A330 (no BSS sound)
- remove all custom scenery
- minimal number of plugins (only Ground handling and better pushback, no XPUIPC, no projectFly, ...)
- deactivate GeForce Experience ingame overlay (not sure if i really need to do this).
I did fly from LFPG to SBGL (11+ hours) without any issues, landing with 40-50 fps. I will do another test flight from EDDF to ZSPD.
315
Ok, please tell me the result!
I got rid of HD mesh scenery and did a longhaul ULLI - FIMP, over 11 hours without problems.
However, most of the flight was above the sea, so not really resource  intense...
Will try another one tonight.
316
As an update for the JAR Team, just did a flight in the A330v5 with XP 11.30b1. No problems with the handling, everything was OK, one slight issue, the weather radar does not work. When switched on a blue segment appears across the screen. Strange thing is that if the terrain radar is on the blue segment does not appear, but I don't know if the weather radar is working.
I see on start up of the A330 that there are problems with the update Mojave, I wonder if when correcting that it would be possible to make the MCDU screens work independently of each other. It would be good having different information on both screens.
317 (edited by Broccoly 2018-11-02 10:39:36)
Hello. First of all, thank you JAR for this wonderful aircraft ! I really love flying with it, but as of lately my A330 is experiencing a big problem with the rudder. In windy conditions, the rudder (and aileron it seems too) starts to flutter randomly to the point that I am not able to fly this plane.
I am using version 3r5 of the A330 in X-Plane 11.26 .
Here is a list of things I have already tested with no effect:
- Plugging out the rudder pedals (Thrustmaster TFRP)
- Plugging out the Joystick (Thrustmaster T16000M)
- Plugging out the Throttle (comes with above Joystick)
- Turning Autopilot on and off
- Turning on/off every other button that can be
- Starting from Cold and Dark, and with the "Hotstart" feature
- Disabling all Hydraulics (Yes, it still flutters!)
The fluttering only appears in windy conditions (small winds too).
It also does not happen on ground, only in the air.
I suspect that something with the flight model or systems (yaw damper?) is wrong, but don't know for sure.
I made a video of this issue here : https://youtu.be/i9IuEIQFwaM
These are my PC specs:
- Processor : Ryzen 7 2700X @4.25 GHz
- Motherboard : ASUS ROG STRIX X470-F Gaming
- Memory : Corsair Vengeance DDR4-2666 32GB
- Graphics Card : ZOTAC GeForce GTX 1080
Edit: I use the BSS soundpack.
318
i fucking put  manually airac cylce 1813 folder to Jara330 _navdata and fmgs navdata folder and fmc doesnt see this cycle. Even my free 737 Zibo can see airac 1813 but your shit plane doesnt see.
319 (edited by jcdp 2018-12-13 18:25:38)
Before claiming you should suppose you have done something wrong ...
Correct path is "aircrafts/JD330xp11/plugins/fmgs/navdata/  "
The other way is to install GNS430 in "xplane11/custom data" …
PS :1 )    _navdata folder is in A320 aircraft, there is no _navdata folder for A330
      2 ) only the content of "airac cylce 1813 folder" is to be used , not the folder itself .
aircrafts/JD330xp11/plugins/fmgs/navdata/  in this folder has PROC folder and i copied new PROC file which include airac 1813 coulndt see by my A330.
Thanks for help.
321 (edited by jcdp 2018-12-13 19:23:58)
Thanks for help.
There are also 4 files (+ cycle info file)
Airports, ats, navaids and waypoints …   .txt files
I must say I have also :earth_awy.dat , earth_fix.dat and earth_nav.dat files
PS: I must say that in this folder there are files of Airac 1410 (when we install the aircraft)
they can be kept like they are .
A330 uses data from gsn430 (which is not with Xplane 11) it is necessary to copy it from Xp 10 … or to create a folder to install it with data from Navigraph (last AIRAC) :
Xplane11/custom data/GNS430
Thanks for help.
First= 1-) İ have already Custom Data/GNS430 Folder and fhis folder has new airac 1813 and my zibo and toliss a319 and all xplane 11's default aircrafts can read this file except JAR A330. İ still dont understand. Jar ROmano said in first page A330 can read Customdata/gns430 but mine cant read it. İ am done so i will simulate with AIRAC 1410 smile
323 (edited by jcdp 2018-12-17 12:31:06)
mertovic23 wrote:
Thanks for help.
Well, you are the only one …
I can only suggest to reinstall the aircraft …
324 (edited by Webrichard 2019-01-19 02:00:59)
http://jardesign.org/forum/img/m/7927/t/p1d1htah2f6u81k0alml9l2fn3.png
Good night guys. I bought the a330 and activated normal, but this is happening. Help me. thank you. I'm using google translator.
325
hi JD
I found one small bug.
https://x-plane.vip/xtdr/static/?upload … 34369773e9
I found "A330" is not registered aircraft ICAO
https://www.icao.int/publications/DOC86 … earch.aspx
A332, A337, A338, A339 are aviable, but there is no A330.
I think .acf can be fixed
