1 (edited by ExocetYVR 2017-12-19 01:22:10)
Topic: KPHX: X-Life File for MisteX6 Scenery
Hello, I have revised the existing KPHX (based on Nimbus' payware scenery) ground routes for X-Life to work with MisterX6's freeware scenery (https://forums.x-plane.org/index.php?/f … rnational/).
The revision fixes the missing hold areas on all runways, simplifies the taxiways in a number of areas, and re-aligns the gate and stand locations at the terminals to match MisterX6's scenery.
Gates with scenery static aircraft are correctly marked and neighbouring gates that could cause wingtip conflicts are restricted to Code B rather than Code C.
