1 (edited by pete80602 2017-11-22 21:21:56)
Topic: FF 757v2.1 752PF Freighter (improved) set v1.2
New improved and completed. Includes GPU, Stairs, Van, Palette Loader, two Loader(B)s, and the Fuel Truck. Replaces earlier attempt.
Updated 11/21/17 @ 13:02 Mountain Standard Time
Ah, I missed the Add File button, silly me. Here's goes! File should be attached now.
Added the safety cones and simplified some routing. I've also choreographed the vehicles so they don't run into each other when you select Drive Up All and Drive Away All, although Loader(B)-2 does come precariously close to the fuel tanker.
Now if someone can figure out how to tie into the FF 757 datarefs to open and close doors as well as making the fuel tanker the default versus FlightFactor's big ugly tanker… please make suggestions!
Thanks, Pete
http://jardesign.org/forum/img/m/4731/t/p1bvidl8denlc18ap133q9dvgm53.jpg
Re: FF 757v2.1 752PF Freighter (improved) set v1.2
no file attached?
So new to the board, that I just found the animation variables help file. So I may revise this, but I suspect that others will have their own, probably better versions posted by then.
Let me know what you think. Thanks!
Pete
